Old 05-17-2013, 10:50 AM   #26
dux10
Member#: 235338
2002 Faggin Wagon
srp
Originally Posted by nmlittlebigman View Post
Your car is NOT happy. Definitely get a tune ASAP. You had some massive knock and it appears that the tune on your car has some workarounds like disabling AF learning above 1100 RPM. If I were in your shoes I would have Steve tune it. I hear nothing but good things about him.
I'd agree with the car not being happy. I know its a cruise log, and its kinda hard to tell what the map looks like from it, but with the IAM @ 0.5 and it pulling 10* is scary considering that the car was tuned for an IAM value of 1...
Send me the rom and let me take a look if you want.
Steve @ Pullz-On Tuning
dux10 is offline   Reply With Quote
Old 05-17-2013, 10:54 AM   #27
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
After ECU reset, the car starts at .5 IAM. I'll have to wait until I get home from work today, and i'll snag the ROM off my other laptop. Could the Walbro be causing this?
BeastianSTI is offline   Reply With Quote
Old 05-17-2013, 11:09 AM   #28
dux10
Member#: 235338
2002 Faggin Wagon
srp
It starts at 0.5? Most tuners set it to start at 1. That right there scares me. If he tuned it with a IAM of 0.5 and the ecu can effectively double the KCA yet he hasn't seen the car behave under those conditions. And who knows if he even anticipated those conditions...
I've never seen a walbro cause knock. I have seen it alter fueling if the stock pump couldn't keep up.
Old 05-17-2013, 11:22 AM   #29
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
It's probably too much timing at cruise or just when you step into it to climb a hill. If you want help you can pm me. But it won't always show up in learning view.
Bamofo is offline   Reply With Quote
Old 05-17-2013, 11:51 AM   #30
BeastianSTI
Member#: 310506
2005 WRX STi
Yeah, I was doing the Vishnu reset to get my IAM up.
I think the tuner put it at .5 to make sure that everything is good before allowing it to run really hard, should any issues arise? I'm not a tuner though
Old 05-17-2013, 12:37 PM   #31
dux10
Member#: 235338
2002 Faggin Wagon
srp
Ehhh.... Let's say I tune a car and datalog it with an IAM of 1 and have 15* @pk torque and 22* @redline with no knock after repeated abuse and I decided to leave it there. The car will never see more timing that 15-22 degrees all other conditions being the same.
Now let's say I tune a car and datalog it with an IAM of 0.5 and have 15* @pk tourque and 22* @redline with no knock after repeated abuse and I decided to leave it there. The car can then add up to 50% of the Knock Correction Advance table to that 15-22* if it feels that it can. Problem is, I never datalogged the car with more timing so its possible that the car is gonna start knocking until, at the absolute least, IAM drops back down.
50% of the KCA table could be 1 degree or it could be 4 degrees or even more depending on how the tuner set it up. An addition 4* at peak torque is a very hazardous proposition....
Not sure if any of that makes any sense or not, but I can try to break it down better if you need me to.
Old 05-17-2013, 01:15 PM   #32
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
It's very common for tuners to set the initial IAM to 1 while tuning, and then change it back to the stock 0.5 when they're done. There's nothing wrong with that practice. Now if you TUNE the car WHILE the IAM is 0.5, of course that would cause a problem, but I've never heard of a tuner being that dumb.
Old 05-17-2013, 01:27 PM   #33
dux10
Member#: 235338
2002 Faggin Wagon
srp
look at the log and then see what you think...
Old 05-17-2013, 01:40 PM   #34
BeastianSTI
Member#: 310506
2005 WRX STi
I mean - Scott Siegel tuned it before, which was pretty renowned for a while, but hmm..
Old 05-17-2013, 02:06 PM   #35
dux10
Member#: 235338
2002 Faggin Wagon
srp
Its possible he did what eggroll said, but it should not be that much timing in spots regardless...
Steve @ Pullz-On TUning
Old 05-17-2013, 06:58 PM   #36
BeastianSTI
Member#: 310506
2005 WRX STi
True - i'll go download the ROM now!
Old 05-18-2013, 11:19 AM   #37
dux10
Member#: 235338
2002 Faggin Wagon
srp
Never got anything from you?
Old 05-19-2013, 03:22 PM   #38
BeastianSTI
Member#: 310506
2005 WRX STi
Sorry for being so late to get back - had issues with my laptop trying to pull the ROM.
Here is a DL to the rom:
http://s000.tinyupload.com/?file_id=...56074243675935
Old 05-19-2013, 10:57 PM   #39
dux10
Member#: 235338
2002 Faggin Wagon
srp
When did the rich business start? The fuel pump could be the culprit.
Usually a fuel pump change won't cause this, BUT you were professionally tuned before you got it. The tuner could have easily been compensating for a drop in fuel pressure from the insufficient pump by jacking up the MAF scaling. Now that the fuel pressure problem has been fixed with the new pump, that MAF scaling adjustment would now be making you run too rich.
Just looked at the OP's rom and egroll hit the nail on the head. I compared the OP's maf scaling to my own scaling on a 70mm APS intake that's utilized by several cars and they were identical (+/-1%) to the OP's- until ~3.3v at which point the OP's scaling just keeps increasing. By 4v its 10% higher and by 4.5v its nearly 25% higher than my scaling.
Numbers displayed is percent.
Old 05-20-2013, 02:03 AM   #40
BeastianSTI
Member#: 310506
2005 WRX STi
Hah - interesting. I wonder how hard it would be to just adjust the scaling for the new fp
Old 05-20-2013, 02:28 AM   #41
dux10
Member#: 235338
2002 Faggin Wagon
srp
Datalog wideband in conjunction with romraider and tune. If u want I can send you your rom with my maf scaling to get you close?
The problem is, all the load scalings for the timing maps and OL fueling will be skewed. They'd all have to be reduced on the high end but it would be a bit of a guessing game as to how much.
Old 05-20-2013, 01:16 PM   #42
BeastianSTI
Member#: 310506
2005 WRX STi
I need a special connector for that to the laptop right? Aux to usb?
Old 05-20-2013, 02:04 PM   #43
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
I don't know if you have the LC-1 or an AEM 30-4100 but I hope this helps: http://www.evoxforums.com/forums/showthread.php?t=21747
You can generally get what you need from radio shack. Once you have made the connection to you laptop with either a db-9 or usb then you can select it as an external sensor in romraider and log.
And another link on how to: http://forums.nasioc.com/forums/show....php?t=2079034
nmlittlebigman is offline   Reply With Quote
Old 05-20-2013, 03:21 PM   #44
BeastianSTI
Member#: 310506
2005 WRX STi
I have the Innovate LC-1 wideband
Old 05-21-2013, 11:13 AM   #45
dux10
Member#: 235338
2002 Faggin Wagon
srp
Not sure what you need with the Innovate to log as most of my customers have a UEGO. lol
Breeze through the product documentaion that comes with the unit and it should say
Old 05-21-2013, 11:21 AM   #46
Member#: 51961
2005 STi
2012 WRX
The LC-1 has a 1/8" headphone style plug that carries the serial data. With the LC-1 you should have received a 1/8" to DB9 cable, then you just need a DB9 to USB adapter to get it into your computer. Like this one:
Amazon.com: Keyspan by Tripp Lite USA-19HS Hi-Speed USB Serial Adapter, PC, MAC, supports Cisco Break Sequence: ElectronicsAmazon.com: Keyspan by Tripp Lite USA-19HS Hi-Speed USB Serial Adapter, PC, MAC, supports Cisco Break Sequence: Electronics
Old 06-03-2013, 06:31 PM   #47
BeastianSTI
Member#: 310506
2005 WRX STi
I've ordered the cable, and am waiting for it to get here!
Old 06-04-2013, 10:42 AM   #48
GulfCoastMotorworks
Member#: 358317
6266 Built Bugeye
GulfCoastMotorWorks.com
So who tuned your car in the Tampa area anyway?
I think I already have an idea
/Drunkmann
GulfCoastMotorworks is offline   Reply With Quote
Old 06-04-2013, 11:43 AM   #49
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
Apparently this guy tuned it. I have learned to completely ignore peoples names. There are very few well known tuners that have absolutely 0 bad rep. **** happens and that is life. Visconti , phat botti, etc etc. I have heard nothing but good things from people tuned by them, but I have also fixed their tunes on people who had a bad time with them. It can be a roll of the dice depending on when you go and meet your tuner. If hes super busy, you may not get the experience you want.
endrswrd is offline   Reply With Quote
Old 06-04-2013, 01:16 PM   #50
dux10
Member#: 235338
2002 Faggin Wagon
srp
I agree 100% with this. You'd be surprised how many hack jobs some of the big names do. Does it work? Sometimes, but its not the right way to do it and can cause many problems. The biggest thing is using the OL fueling table to tune boost and use the stock maf scaling. Some don't even touch AVCS or do so poorly. Others don't tune tip-in at all. It really is crapshoot as to what you could end up with. Sad part is, the customer rarely knows better/different unless they can compare it to another tuner...
Scott was known to be the one of the best until he got too busy to keep doing it. He was well known in the south east.
