Old 05-21-2013, 01:09 PM   #51
dysh@
Member#: 217880
'98 JDM TypeR
EG33TT
Some thing is wrong with numbers.
Why did you cut out CF on VD graph?
dysh@ is offline   Reply With Quote
Old 05-21-2013, 07:57 PM   #52
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
Bc I copied it in paint, I'll be happy to post a full picture with the same data
Better?
Originally Posted by lil'redwagon View Post
from what i recall, and i'm happy to be corrected on this, but the 3,200-3,350 lb baseline weight figure that's published about our cars and used in these programs like Virtual Dyno and Airboy, includes a full tank and topped off fluids. so for anything less than a full tank, you should be subtracting from that number. but again, it's loose info, so i'm happy to be wrong about it.
it seems high,but when you consider an 04-07 STi on VD = 3350lbs and then add 3 passengers (average at 175) then you are around, that's right at 3850, and I used the one for the 08 STi for the gearing so it added 30 lbs to weight.
mxturboracer86 is offline   Reply With Quote
Old 05-21-2013, 10:57 PM   #53
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
they are great numbers but the dynojet readings are about 5% higher than what a normal dyno reads found in many shops. I ussually use the virtual dyno w/ cf=1.0 when i compare my numbers with the VD program. either way everyone should see he is making huge power on the stock block. much more than an ej25 engine can ussually take before its ringlands **** the bed.
WhiteBgeye02 is offline   Reply With Quote
Old 05-24-2013, 11:47 AM   #54
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
OP Nicely put together car and my "some day" setup as well. Sorry to hear about the clutch. Get that puppy fixed and enjoy!
Matt nicely tuned as usual!
Another Matt 555 tune
Will this car see the track? Curious about actual trap speed
jmlaser is offline   Reply With Quote
Old 05-24-2013, 01:23 PM   #55
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
why was the pull done in 3rd gear vs 4th? i thought 4th was closer to the 1:1 desired? wouldnt a lower gear produce inflated trq numbers and hence inflated hp number?
someone please correct me if i'm being stupid right now lol.
gsrcrxsi is offline   Reply With Quote
Old 05-24-2013, 02:23 PM   #56
207STi
Member#: 197062
1998 Swapped Impreza
black
I know a lot of people don't feel comfortable doing a pull to 100 plus on the street. Third gear is usually around 80 at 7500 rpm on the 6mt.
207STi is offline   Reply With Quote
Old 05-24-2013, 06:41 PM   #57
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
it's just as accurate as long as the correct gear ratio is loaded into the dyno. you could do it in first if you load up the ratios, but you wouldn't load the car as much as the higher gears, and the resolution would be bad since you're sweeping across the tach so quickly. for best numbers, a higher gear would be better, but if you did it in top gear, it would make for a 160+ mph dyno pull. and if you're tuning, you'd be on a bad spot for a long time. so something like 3rd or 4th is a good compromise.
lil'redwagon is offline   Reply With Quote
Old 05-25-2013, 07:57 PM   #58
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
It will be at the track after the clutch is sorted out, can't wait to see what it does myself.
Is your car almost ready for the track?
Old 05-25-2013, 11:20 PM   #59
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
In this case 3rd is OVER 100 at an 8200 redline.
4th would be way too much gear for a safe pull in most areas, nearly 140 MPH.
Concillian is offline   Reply With Quote
Old 05-26-2013, 12:09 PM   #60
207STi
Member#: 197062
black
Didn't realize it was an 08+ 6mt, I stand corrected.
Old 05-30-2013, 02:51 AM   #61
ReflectiveAuto
Member#: 354199
Nice nice!
ReflectiveAuto is offline   Reply With Quote
Old 08-11-2013, 11:10 PM   #62
hummelsubaru
Member#: 220153
'05 WRX JBP WFC#207
GTX3076 ViPec V44
marked, great setup and great number mate! your thread solves a lot of suspescious for my build! thanks for that.
btw how big your injector is? 1000cc? 1300?
hummelsubaru is offline   Reply With Quote
Old 08-12-2013, 03:00 AM   #63
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Thanks for the link.
Great build, nice results.
Scuby04STi is offline   Reply With Quote
Old 09-25-2013, 02:06 PM   #64
Overboosting04
Member#: 202417
Wrx Stock EJ207
[email protected]
Its been awhile but I finally got around to bringing my car to the track, during the Subaru shootout at Byron. It was my first time ever at the track and ended up running a best of [email protected] with a small hiccup shifting into 2nd. Ended up getting 2nd in the modified 2.0 class
Overboosting04 is offline   Reply With Quote
Old 09-25-2013, 05:50 PM   #65
shomspeed
Member#: 166371
2007 WRX STI
Originally Posted by Overboosting04 View Post
Thanks this engine has been making over 350whp on a mustang dyno for over 3 years now, but its been on e85 ever since ive owned it also
Congrats guys on your success so far on a stock ej207, high octane gas and stock parts is a very very good idea
shomspeed is offline   Reply With Quote
Old 09-25-2013, 06:33 PM   #66
dr20t
Member#: 311246
Well done mate
Loving the ej207 big power builds coming out
dr20t is offline   Reply With Quote
Old 09-25-2013, 10:37 PM   #67
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Originally Posted by dr20t View Post
Well done mate
As it seems the WRX and STi will be going to two liters in the future, let's hope the next turbo version will be built like the ej207!
Dave D. is offline   Reply With Quote
Old 09-25-2013, 10:54 PM   #68
dr20t
Member#: 311246
The fa20 is looking promising, and from what I've seen and read, the heads flow amazingly well
So yes I believe they're going back in that direction
Still gotta love jdm ej207 power
Old 09-26-2013, 07:59 AM   #69
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
Nice car and nice numbers
alexandern05 is offline   Reply With Quote
Old 09-26-2013, 02:20 PM   #70
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
The design is torquey and it's not going to have the redline that an ej207 has.
It does look, however to be able to make power. I see it being more like a DI EVO 2 liter and less like a DI EJ207. This may limit redline, but it should have plenty of balls. The question will be how much boost it will be able to take (reliably) and how long will it be before a "community friendly" engine management solution comes to the scene.
Don't be surprised to see spool like an EJ25x turbo does. The higher CR afforded by DI will make up a lot of the displacement difference, so torque should also be in the same ballpark as the 2.5L. I don't expect the new engine to have a lot of trade-offs other than the complexity of the new technology. Overall the direction should have benefits for everyone who isn't building an all-out race car. It should ultimately perform much like the EJ25 turbos do while getting significantly better MPGs.
Old 09-27-2013, 03:15 PM   #71
shomspeed
Member#: 166371
2007 WRX STI
what are you guys using for a catch can?
Old 09-29-2013, 10:31 AM   #72
Overboosting04
Member#: 202417
Wrx Stock EJ207
[email protected]
not currently using a catch can, have the pcv eliminated and the the hoses routed towards the ground
Old 09-29-2013, 05:55 PM   #73
shomspeed
Member#: 166371
2007 WRX STI
have you found with this setup, you are losing oil on the ground?
Old 10-02-2013, 03:49 PM   #74
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Just saw the vid. Wow
wrxsubiemod is offline   Reply With Quote
Old 10-03-2013, 04:00 PM   #75
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
How many miles have u put on this setup?
02rex62 is offline   Reply With Quote
