Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 05-16-2013, 11:26 PM   #1
fastblueufo
Visiting NASIOC Timeout
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Default A little 2.5i supercharger love
Event: E-tune
Dyno: Virtual Dyno
Tuner: Fast Performance Tuning
Stock hp/tq: ?
Fuel: 93 unleaded
Car: 06 impreza 2.5I manual tranny
Temp: 80's
Elevation: 300'
Mods: Raptor Supercharger, STI injectors, Walbro 255, Intercooled, few other things
I usually don't post a bunch because I don't have time but I thought this was different and worthy of a post. This tune has literally taken months due to the owner moving from usvi to the states. Plus had to work out a few issues that popped up while tuning. After all is said this tuned turned out better than I thought it would from when I started on this. Owner loves the car and says it pulls great. I wish the SC was smaller and would boost up sooner but it looks like a really fun N/A convert to pressure.
Thanks to airboy for correcting me on the gear ratios. Here is a revised couple of pulls. One is with 4 perams logged and one is with a few more perams added.
fastblueufo is offline   Reply With Quote
Old 05-16-2013, 11:44 PM   #2
revin-it02
Member#: 287184
2005 RS-T
www.turbotime.us
I'm sorry but no way is this making 270 on 5psi of boost. Especially when people with actual dyno graphs barely get into the 230s with 9 psi/intercooling.
What's your smoothing?
revin-it02 is offline   Reply With Quote
Old 05-16-2013, 11:59 PM   #3
fastblueufo
Member#: 212154
02 billet crank
Smoothing is 3. I used 06 wrx sedan in vd and changed the weight to 3015 since that's curb weight. Everything else is the same as wrx as far as gearing and frontal area. I did add 200lbs for driver. I wish I had a log from a bone stock 2.5I logging same perams. Its got a 9 psi pulley on it iirc so I'm really not even sure if the map readings are accurate or what the stock sensor will read accurately up to. A wrx map is being installed very soon so the map numbers may change?
Btw, I've seen some real dyno graphs from same supercharger and they go from 230 up to just over 300 depending on dyno and mods. Or 2.0 and 2.5. But its within the range of others posted
I do know stock 06 2.5 wrx on same settings but with a 3200 curb weight does around 230 or so so the car is def doing better than that because of the weight settings being less on this car. Add more weight on same settings and you get more hp. I've got numerous logs and all are within a few hp tq from the others but this was the final log so that's what I used.
Go hate on another thread, its def a far cry more than the stock hp and at 10 to 1 cr it has to be a pretty peppy and fun ass car to drive.
Old 05-17-2013, 06:52 AM   #4
revin-it02
Member#: 287184
2005 RS-T
www.turbotime.us
I will hate until there is an actual dyno run. Virtual dyno is screwy with the NA cars. You can enter the gearing, weight... etc. And its still off. Example: when I just had cams it was telling me I had 200whp consistently with a smoothing of 3. Got it dyno'd and it was at 155 (not a mustang). So just saying, virtual dyno is more than likely inflating it by 40 to 50 hp.
I know the car drives radically different than stock. So does mine with boost. But does that back up the close to 300whp virtual dyno... no.
Old 05-17-2013, 09:46 AM   #5
Airboy
Member#: 72829
2006 WRX
EFR6758
Gearing (3rd) for the 2.5i is 1.448 with final drive of 3.9
Gearing (3rd) for the wrx is 1.366 with final drive of 3.7
Airboy is offline   Reply With Quote
Old 05-17-2013, 10:39 PM   #6
fastblueufo
Member#: 212154
02 billet crank
Thanks for those ratio's. First post is updated.
Old 05-17-2013, 10:46 PM   #7
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Nice update to the numbers. Looks right now. Seems like a fun like change from na. It's fun to see different builds that stray from the typical.
Slimsti is offline   Reply With Quote
Old 05-18-2013, 03:12 AM   #8
VIsubi
Member#: 187834
06 2.5i impreza
Red
This may be true put MAP is reading 5.?? psi while the actual pulley is 9 psi pulley so if the flaw is in the MAP then very possible its still adding more boost than what is read. Either way bulls like a banshee and an awesome linear powerband. Once i get ahold of that MAP though we will see.
But thanks for your doubt haha
VIsubi is offline   Reply With Quote
Old 05-18-2013, 03:13 AM   #9
VIsubi
Member#: 187834
06 2.5i impreza
Red
Fast thats the same guy that was bashing raptor superchargers..ahh funny how he continues to tool in garden. haha. Dynos are toolsso if you live by your tool I guess you'll brag by it too.
Old 05-18-2013, 03:19 AM   #10
VIsubi
Member#: 187834
06 2.5i impreza
Red
You do this while breathing whats new... hahaha and he's just being honest with settings once those settings where corrected. Who are you to say they are still wrong. Enjoy your Turbo I'll enjoy getting blown instead. lol
Go some place worth flaming haha. if you physically rode in car on a chassis dyno. You still wouldn't believe your own eyes haha
Old 05-18-2013, 09:28 AM   #11
revin-it02
Member#: 287184
2005 RS-T
www.turbotime.us
Ohhh boy here comes the know it all known as VI. Sometimes you just need to know when to keep your mouth shut to not make yourself look like an idiot.
Hate to tell ya, I WAS RIGHT JACKASS. Those numbers look much better.
Old 05-18-2013, 11:20 AM   #12
VIsubi
Member#: 187834
06 2.5i impreza
Red
we new something was off jackass but you running your mouth like a time square call girl. Is just that, used up and abused. LoL whats funny is those numbers are not to far away once I find proper cams, ported head and 3 angle with valves and springs. For this set up.
Again like stated before go run your mouth on your own bragging thread cause no one likes an unwiped crusty a$$ walking around. haha
Hey fast once I can save for Water to Air and MAP we'll take it from there. Maybe I can find someone to swap a brand new FPR with for one.
Yeah Slim I love that its linear so she just keeps screaming to the top of the RPM. Thinking of either Meth injection like someone mentioned to me to get some more out of it with some tuning from FastBlue see where this will take us. Car only has 28k on motor with compression in 174,174,175,173 ( not in any order think #4 is 75) so she's still nice and at par.
Old 05-18-2013, 12:14 PM   #13
revin-it02
Member#: 287184
2005 RS-T
www.turbotime.us
Really, you knew something was off even though your boy called me a hater when I called him out on those numbers?
And when did I ever mention anything bragging about my boosted setup?
You've taken stupid to a whole different level.
Old 05-18-2013, 01:11 PM   #14
ProfessWRX
Member#: 323379
06 WRX
It's apparent that some of you don't understand superchargers.
Also, the na map will not read over 5 psi. It's making over 5psi.
ProfessWRX is offline   Reply With Quote
Old 05-18-2013, 01:55 PM   #15
04trailsti
Member#: 179170
In all honesty who cares what a dyno says, fastblue if you like it then rock on with your bad self. it's all how about what you want if the car pulls like a banshee but the dyno says 78 whp then awesome you have the best 78 hp car
04trailsti is offline   Reply With Quote
Old 05-18-2013, 02:24 PM   #16
Shortpersonbk
Member#: 319017
12 sti 700+whp
it wants to be a evo
VD is not the most accurate but is a good indicator....im sure its pretty close to those numbers
i am making 320 ish on a 18g xt on a 2.0L 21 psi according to vd and that seems to be what people are making on real dynos... i can easily see this guy making 230whp if thats what vd says
Shortpersonbk is online now   Reply With Quote
Old 05-18-2013, 04:57 PM   #17
Back Road Runner
Member#: 60082
2004 Forester STI
Nice power curve. The Raptor super charger seems to work really good at getting rid of the top end drop naturally in the NA. Plus you're always at positive pressure and making reasonable power.
I should note to people that question the output, this is as far as I'm aware a stock compression engine, aka 10:1, so torque will be higher and resulting HP will be higher for a given boost level versus the 8.5:1 and 8.2:1 turbo cars. I've done NA road dyno and real dyno tuning. Getting numbers correct is a matter of scaling. It's not so important the raw numbers as it is the curve shape. In comparison to my road and real dyno testing on a NA engine stock to reasonably modified, OP isn't really way out there. If we're talking worst case, he might be 20 to 30 ft-lbs and subsequently HP high. However, it's hard to compare because everyone's expecting massive torque peaks which isn't happening here. Instead, it's just light boost and hold all the way up. A TD04 will be peaky but drop way off on the top end. You'll put down 210 to 230 HP on a TD04, but you're down to 10psi or a little more on top, on a low static compression engine. The NA will make more power off less boost because of both the higher static compression and also higher dynamic compression (still using stock cams I would assume). At the end of the day, this car is still realistically making north of 200whp and likely pretty close to what a TD04 puts down, minus the gobs of midrange torque. My bolt on modified NA makes 145 wheel ft-lbs, conservatively with no boost, backed by more than one real dyno and scaled down to the most conservative one. An NA with 1psi positive pressure should not be hard to make north of 150 ft-lbs, which is around where he's at.
Old 05-29-2013, 12:19 AM   #18
VIsubi
Member#: 187834
06 2.5i impreza
Red
HAHA I agree lmao I'm gona claim that number for now on hahaha more than likely they won't beleive that. if it is capped at only 5 psi guys then she probably is boosting higher. Gottah get on a used or new MAP sensor off a WRX yikes..but gottah deal with FASTBLUE first thats later. I cna't be any more grateful and FASTBLUE is a beast and as hell I'll be sending as much tunes and builds his way..Revin-it seriously your a waste of keyboard keys I'm done with you say what you want..plus we didn't need you to point out guano had that stated way before your hate. Man I love this SC on this EJ...wonder how it would fell on an H6
Old 05-29-2013, 06:31 PM   #19
ProfessWRX
Member#: 323379
06 WRX
The car is making more than 5psi.
Anybody that thinks that boost flat line is possible I'd love to hear the explanation.
Old 05-30-2013, 07:09 AM   #20
revin-it02
Member#: 287184
2005 RS-T
www.turbotime.us
So then how would one tune for this if you don't know what psi the car is seeing? You just shooting in the dark?
Old 05-30-2013, 09:26 PM   #21
ProfessWRX
Member#: 323379
06 WRX
Gauge. Or a different map sensor.
Old 05-30-2013, 09:35 PM   #22
revin-it02
Member#: 287184
2005 RS-T
www.turbotime.us
Still confused as to how this car is tuned correctly if it can't read the true psi?
Old 05-30-2013, 09:54 PM   #23
Wicked Performance
Member#: 265606
Im not a big NA guy, but nothing tuning related on that car should be related to the MAP, only to airflow from the MAF. The MAP is just there for a few basic functions.
Wicked Performance is online now   Reply With Quote
Old 05-31-2013, 12:01 AM   #24
ProfessWRX
Member#: 323379
06 WRX
I didn't say it was tuned correctly or incorrectly.
Old 05-31-2013, 09:16 AM   #25
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
I have a stock STI MAP sensor if you need one. $30 ship cont. US address.
http://forums.nasioc.com/forums/show...2#post39919682
