Old 05-18-2013, 10:29 AM   #1
inspectorgadget
Member#: 149448
Default What Front End Work Should I do while I'm changing Wheel Bearings?
I have an 04TS wagon with just over 100k on it. Last year I replaced the clutch, headgaskets and a bunch of other miscellaneous stuff while I had it taken apart. I posted a similar topic thread and got tons of great input. Looking for same thoughts here, although I am going to be replacing my front wheel bearings.
I have a wheel rate rub noise which sounds like its coming from the driver side but I am not sure. I put the car on the ramps and didnt see anything noticeable but its probably time to replace some of steering, suspension and wheel parts. I haven't changed the pads recently, prob 30k ago. So I could check those and see if that solves the noise but I have a feeling its time to do the wheel bearings.
If I do the wheel bearings what else should I replace while I'm at it? Rotors? Tie Rods? Suspension?
TIA.
inspectorgadget is offline   Reply With Quote
Old 05-20-2013, 03:35 AM   #2
blubug_768
Member#: 324962
02 WRX
its kinda just see what you need type of thing, when I did my wheel bearings my front rotors were out of spec, my parking brake pads were gone and my ball joints were beat too, I went in at about 145k on mine. what I thought would be nice would be to get some billet knuckles and do away with that pesky abs stuff. and speaking of abs I took off the sensor ring then put in the new bearings and then realized I couldn't put the ring back on with the hub in place, ruined that bearing before it was ever even on the car.
blubug_768 is offline   Reply With Quote
Old 05-20-2013, 04:17 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
tie rod ends and ball joints....lca bushings
Old 05-20-2013, 12:52 PM   #4
teiva-boy
Member#: 22825
Add to this, steering rack bushings, and performance alignment.
teiva-boy is offline   Reply With Quote
