Vancouver Impreza Club
Old 05-18-2013, 03:04 PM   #1
Ronald_Type-R
Member#: 200886
2000 Legacy Wgn STi
Default (New Member) My First Subaru: 2000 Subaru Legacy Outback Wagon
Hi everyone I've been a lurker on here for a few years now, but never really posted anything because I didn't exactly own a Subaru until recently!
What I have here is an STi swapped 2000 Subaru Legacy Outback Wagon This car popped up for sale late last year in Calgary, and I just had to buy it because I've always wanted a Legacy Wagon with an STi powerplant for the longest time. The wagon only had 110,xxx kms on the chassis, and 58,xxx kms on the motor. Rumor has it that the motor was pulled out of a brand new '05 STi with only 15 kms on it, before a lot boy totaled it
Long story short, I drove 12 hours to Calgary in the November blizzard in my B18C5 swapped '93 Honda Integra on a Friday, traded that car with this one (with cash on top, of course lol), and drove this Subie back to Vancouver on the Sunday. It only took me 8 hours to get back to Vancouver, even though the road condition was more or less the same as when I was heading to Calgary! The 4WD and the STi motor did wonders!
Here is a mod list of this car, parts I've added to it (in bold), and some plans I have for this car in the future!
ENGINE
- '05 USDM EJ257 STi Ver.8 Engine Swap
- BeatRush Engine Mounts
- Crawford Air / Oil Separator V2
- Spearco 900cfm Weld-On Aluminum Top Mount intercooler
- DEI Gold Heat Reflective Tape
- Tial Q 50mm Blow-Off Valve
- Samco Silicone 2.4" Turbo Inlet Hose
- AEM Silicone Throttle Body Coupler
- Perrin Silicone Intercooler Elbow
- JDM STi by Samco Silicone Radiator Hoses
- Injen Short Ram Intake
- Grimmspeed Port & Polished OEM Intake Manifold
- Grimmspeed Port & Polished OEM Drive-By-Wire Throttle Body
- Grimmspeed TGV Delete Kit
- Grimmspeed Phenolic 8mm Intake Manifold Spacers
- Grimmspeed PnP Exhaust Manifolds
- Grimmspeed PnP Crosspipe
- Grimmspeed Catless Uppipe
- Grimmspeed Manifold to Head Gaskets
- Grimmspeed Manifold to Crosspipe Gaskets
- Grimmspeed Manifold to Uppipe 12-layer Gasket
- Grimmspeed Uppipe to Turbo Gasket
- Stromung 3" Bell-Mouth Downpipe
- Killer B Oil Pickup
- Killer B Oil Baffle Plate
- iON Performance Stage 1 VF39 Turbo Upgrade (Port & Polished Factory Turbo, w/ Ceramic Coating)
- JDM Cusco Turbo Heat Shield
- Perrin Lightweight Crankshaft Pulley
- GFB Underdrive Power Steering Pump Pulley
- Komoto Racing Stainless Steel Midpipe
- Custom Made 3" Stainless Steel Muffler Delete w/ Angled Tip
- A'PEXi High-Capacity Race Aluminum Radiator
- JDM BE5 Legacy B4 S401 STi 1.3Bar Radiator Cap
- JDM BE5 Legacy B4 S401 STi Radiator Hoses
- Deatschwerks 320lph Fuel Pump
- NGK 1-Step Colder Iridium Spark Plugs
- Beatrush Radiator Cooling Plate
- Beatrush Alternator Pulley Cover
- Greddy Magnetic Drain Plug
- SYMS Aluminum Oil Cap
- SYMS Aluminum Brake Fluid Reservoir Cap
- SYMS Aluminum Clutch Fluid Reservoir Cap
TRANSMISSION
- OEM 5-speed Manual Transmission w/ JDM STi Ver.5 RA Cryo-Treated Gearset
- Cryo-Treated STi Ver.5 Shift Forks
- Quaife Cryo-Treated Front LSD
- JDM BE5 Legacy B4 S401 STi Transmission Mounts
- JDM BE5 Legacy B4 S401 STi Short Shifter Linkage
- Kartboy Short Shifter
- Kartboy Rear Shifter Stay Bushings
- Beatrush Polyurethane Shifter Bushings
- Lightweight Aluminum Race Flywheel (Unknown Brand)
- OEM STi Clutch Disc & Pressure Plate
- Beatrush Solid Aluminum Pitch Control Rod
INTERIOR
- JDM BE5 Legacy B4 S401 STi Instrument Cluster
- JDM BE5 Legacy B4 S401 STi Pedal Set
- JDM BE5 Legacy B4 S401 Aluminum Door Sills
- NRG Short Hub
- WorksBell Rapfix QRSII Steering Wheel Quick Release Kit
- ATC Rallye International Type 95 330mm Steering Wheel
- Sparco Dual External Horn Buttons
- Bride FO-Type Seat Rails & Sliders
- OMP WRC VTR Bucket Seat [Driver]
- OEM GDA STi V5 Bucket Seat [Passenger]
- Beatrush Titanium 5-speed weighted 220g Shift Knob
- Circuit Hero Shifter Extender
EXTERIOR
- JDM GDB STi V-Limited Front Lip w/ Optional Rubber Add-On Flap
- JDM BH5 Legacy Kouki Rev.D Headlights w/ HID
- JDM BH5 Legacy Kouki Rev.D Taillights
- JDM BH5 Legacy Kouki Rev.D Rear Spoiler
- JDM Pink STi Rear Emblem
- Ganador Carbon Fiber Powered Aero Mirrors
- WorksBell Carbon Fiber Hood
- JDM Zero Sports Front Grille
- Tein Hood Struts
FOOTWORK (SUSPENSION/BRAKES/CHASSIS)
- BC Racing BR-Type Short-Stroke Coilover Damper System w/ custom Swift Springs [16kg/mm Front & Rear]
- Beatrush Front Performance Bar
- Beatrush Front Strut Brace
- JDM Legacy BE5 Spec B Forged Aluminum Front Lower Control Arms
- Megan Racing Rear Upper Control Arms
- Megan Racing Rear Lower Front Control Arms
- Megan Racing Rear Lower Rear Control Arms
- Beatrush Driveshaft Carrier Hardened Bushings
- Beatrush Rear Differential Carrier
- Zero Sports 23mm Front Sway Bar
- Zero Sports 21mm Rear Sway Bar
- Whiteline Front Sway Bar Adjustable End Links
- Whiteline Front Control Arm Lower Inner Front Bushings
- Whiteline Front Control Arm Lower Inner Rear Bushings (Anti-Lift Kit)
- Cusco Rear Lower Arm Bar Stiffener Ver. II
- Whiteline Rear Sway Bar Adjustable End Links
- SuperPro Rear Trailing Arm Lower Front Bushings
- Beatrush Rear Strut Brace
- OEM WRX Front 2-Pot Brake Calipers
- Technafit Stainless Steel Brake Lines
- Axis Rear 2-pot Big Brake Kit
- ARP Extended Studs
WHEELS/TIRES
- JDM Work Meister S1R 18x9" (Glim Silver) w/ 225/40ZR18 Bridgestone Potenza RE-11 [Summer]
- JDM Work RS Extended Open Ended Anodized Red Lug Nuts
ELECTRONICS
- Cobb Tuning Access Port V2
- Innovate MTX-L Wideband O2 Sensor & 52mm Gauge
- JDM A'PEXi Voltage Stabilizer & Ground Kit
- JDM Blitz DTT DC Turbo Timer
- Rockford Fosgate 10 Farad Hybrid Capacitor
- Pioneer AVIC-Z140BH Double Din Head Unit
- Phoenix Gold MS-2125 SQ Amplifier x2
- Focal Polyglass 165VB Component Speakers
- Focal Access 27 Twin Lux Subwoofers & Box
Future Build List
ENGINE/DRIVETRAIN
- Beatrush Lightweight Alternator Pulley *acquired*
- Beatrush Driveshaft Solid Aluminum Bushing Kit *acquired*
- ZeroSports Air Diversion Plate *acquired*
- Cobb Tuning SF Air Intake Box
- Grimmspeed Electronic Boost Control Solenoid 3-Port *acquired*
- Cosworth Kevlar Timing Belt
- Cosworth Timing Belt Guide
- Okada Projects Plasma Direct Coil Packs
- Okada Projects Plasma Spark Plug Boots *acquired*
- Tomei Arms M7960 Single Scroll Turbo Kit
- APS 65mm Cold Air Intake Kit
- Deatschwerks 850cc injectors
- Perrin V2 Sidefeed Fuel Rails & Fuel Lines
- Grimmspeed External Wastegate Up Pipe w/ Dump Tube 44mm
- Tial 44mm External Wastegate
- TurboXS 4" Bellmouth Catless Downpipe
- Custom 3.5" Stainless Steel Catback Exhaust
ENGINE/DRIVETRAIN
- JDM Subaru STi Ver.7 6-speed transmission (TY856WB1CA)
- JDM Subaru STi Ver.7 3.90 Rear Diff
- OEM Outback 4EAT Driveshaft
- OEM '06-'07 WRX Front Driveshafts
- ACT Xtreme Pressure Plate
- ACT Street Clutch Disc
- ACT Prolite Flywheel
INTERIOR
- JDM BE5 Legacy B4 S401 STi Carbon Rear View Mirror Cover
- Recaro RA-R STi Spec-C Carbon Fiber Bucket Seats
- Recaro Aluminum Side Mounts
- Beatrush Front End Roof Brace
- Beatrush Longitudinal Roof Brace
- Beatrush Rear End Roof Brace
EXTERIOR
- JDM Rando Traitor D Form Front Bumper
- JDM Rando Traitor D Form Fog Lights
- JDM Gialla D Form Type-R Sportivo Side Sills
- JDM Gialla D Form Type-R Sportivo Rear Lip
- JDM C-West D-Type Eyelids
- JDM BH5 Legacy Spec D Kouki Mid-Rise Aluminum Rear Spoiler
- JDM Denso/Koito 2.5" Bi-Xenon projectors *acquired*
- OEM Honda S2000 projector lenses *acquired*
- E46 Xenon replica shrouds *acquired*
FOOTWORK (SUSPENSION/BRAKES)
- OEM STi Ver.7 Brembo Front & Rear Calipers
- KNS Brakes Rear Brembo Caliper Adapters
- DBA5000 Front & Rear Slotted Rotors
- Ferodo DS2500 brake Pads
- Beatrush Front Frame Support Brace *acquired*
- Beatrush Rear Frame End Brace *acquired*
- Whiteline Rear Lower Control Arms
ELECTRONICS
- Defi Advance BF 60mm Boost Gauge
- Defi Advance BF 60mm Oil Pressure Gauge
- Defi Advance BF 60mm EGT Gauge
- Defi Advance BF 60mm Oil Temp Gauge
- Defi Advance BF 60mm Water Temp Gauge
- Defi Advance BF 60mm Fuel Pressure Gauge
- Defi Link Advance Control Unit
- Compustar RF-P2W901-SS
- Varad LED Scanners
- Odyssey PC925 Lightweight Race Battery
The wagon when I first got it 6 months ago:
The wagon already came with most of the knick knacks on it, but the previous owner(s) haven't exactly taken a good care of the car, and the footwork really showed it. Blown Cusco coilovers, mismatched ball joints, ripped CV joints, and many more =(
Since then, I've added a few more parts on to the car (mostly suspension parts), and I'm planning to do a few more things to it this year!
Here are some photos of the car after I've gotten my hands on it these last 6 months
I ordered a set of wheels for the car as well, which took 4 months to arrive in total lol but they finally came in a few weeks ago, so I decided to throw them on and take some quick pics!
Ronald_Type-R is offline   Reply With Quote
Old 05-18-2013, 03:05 PM   #2
Ronald_Type-R
Member#: 200886
2000 Legacy Wgn STi
And what's sitting under that fully faded, Works Bell Carbon Fiber Hood..
Engine bay is still dirty, but I plan on cleaning it up when I do engine upgrades within the next month or two!
Anyway, I just thought I'd introduce myself, and my car, and I hope that I'd get a chance to meet a lot of the members on here soon! I've always been a Honda guy, and this is my first Subaru, so I'm totally new to the game! I hope I will be able to learn from all of you as I continue to put more work on my wagon!
Here are a few pics of my previous project cars:
(2002-2009) 1990 Honda Accord with H22A4 swap, full wire tuck, full spherical bearings to replace suspension bushings, custom chassis reinforcement braces, Wilwood Superlite Big Brake Kit, 17x9" +20 Work Meister S1, one off Greddy front lip, few weight reduction parts that brought the curb weight down to 2,750lbs with me in it..
(2010-2012) 1993 Track-prepped Honda Prelude with JDM F20B swap w/ bolt-ons, Quaife LSD, MFactory 4.64FD, tuned to 200whp and 165 ft/lbs, full wire tuck, custom BC Racing Coilovers with 18kg/mm Front & 12kg/mm Rear spring rates with short stroke, 27mm Rear sway bar, 17x8.5" Volk Racing TE37 running 245/40/17 tires up front, Chargespeed front lip, Recaro SPA Carbon Kevlar bucket seat, A bunch of carbon parts that brought the curb weight down to 2,500lbs with me in it..
Thanks for looking everyone, and hope I can make some good contributions to the NASIOC VIC community!
Ronald
Old 05-18-2013, 03:21 PM   #3
zagarus
Member#: 305343
1996 WRX STI Wagon
Dark Mica Blue
Ronald! Good to see you finally post pictures of this beauty!
zagarus is offline   Reply With Quote
Old 05-18-2013, 03:44 PM   #4
kyleyap
Member#: 214088
1995 WRX Type RA
JDM YO!!
Such a sick car! Nice meeting you at the last Surrey meet
kyleyap is offline   Reply With Quote
Old 05-18-2013, 03:49 PM   #5
Ctogo
Member#: 338399
2002 Impreza WRX
Nice!
Ctogo is offline   Reply With Quote
Old 05-18-2013, 05:37 PM   #6
m3lv_VIII
Member#: 188174
2008 evo x
wicked white
sick ride Ronald !!!! nice to meet you !!!!
m3lv_VIII is offline   Reply With Quote
Old 05-18-2013, 06:56 PM   #7
ShiftGear
Member#: 130493
1999 v5 STi
Love IT
ShiftGear is offline   Reply With Quote
Old 05-18-2013, 07:27 PM   #8
ShadowDancer
Member#: 57441
07 STI
CGM
Got a pic of the Spec C seats?
I see an OMP bucket and standard STI seat in the pics.
ShadowDancer is offline   Reply With Quote
Old 05-18-2013, 10:13 PM   #9
mazdan
Member#: 322018
That looks awesome. I bet it's fun.
mazdan is offline   Reply With Quote
Old 05-19-2013, 12:24 AM   #10
HRCboy
Member#: 167075
08 STI & 999R
Big thumbs up!
Can't wait to see it in person at a Friday meet.
HRCboy is offline   Reply With Quote
Old 05-19-2013, 01:25 AM   #11
RE3Rotor
Member#: 162465
04 Forester XT
12 Outback 2.5i
You need to replace the Impreza pink badge with this.
RE3Rotor is offline   Reply With Quote
Old 05-19-2013, 01:39 AM   #12
Ronald_Type-R
Member#: 200886
2000 Legacy Wgn STi
Thanks for the kind words everyone And it was nice to meet people at both last night's meet and the Surrey meet last Tuesday..Always nice to be able to put faces behind the usernames in online forums!
I wish I have the Spec C seats! I believe you were looking at the "Future Build" List haha my apologies, I put the Future Build List directly below the current mods list! I have been trying to find a set of those seats, but no luck so far..I'm not even sure if I'll ever be able to find one! Perhaps one day
I love driving it! It may not be the quickest car around tighter corners, but overall it's still a blast to drive
Haha yes! I've actually found a Zero Sports front grille to replace this one..I've always thought the current chrome trim front grille is a little bit out of place for this wagon!
Old 05-19-2013, 02:20 AM   #13
ap3x
Member#: 356238
JDM bunta's car
hey dude i love everything about ur wagon, it was nice meeting u yesterday (i was with jess)
ive always been a honda guy and have built a few setups myself but subies r just a whole new world for me lol
ap3x is offline   Reply With Quote
Old 05-19-2013, 03:41 AM   #14
jpoon
Member#: 314339
07 Sti Ltd
I've seen your prelude before. So happy you're now a subie owner! Btw, check your PM!
jpoon is offline   Reply With Quote
Old 05-21-2013, 04:30 AM   #15
Ronald_Type-R
Member#: 200886
2000 Legacy Wgn STi
Hey man, thanks, it was nice meeting you as well! And yeah I know what you mean haha I can do an H22A swap with my eyes closed, but right now I don't even want to change out my intake manifold on the Subie with the PnP one I have in the garage because I'm scared I might screw something up lol! I feel like such a n00b with these Subies it's almost embarassing! Oh well, hopefully I can learn as I go along without messing up too many things!
Thanks!
Old 05-21-2013, 02:15 PM   #16
tora
Member#: 5851
09 Forester XT
+ NA Miata
Very nice, I've always had a soft spot for the wagons.
tora is offline   Reply With Quote
Old 05-22-2013, 02:24 PM   #17
Fleek04
Member#: 56738
2014 Scion FRS
Asphalt
I saw you yesterday when you were in Coquitlam? It was the intersection of Guildford and Pinetree way. Very nice car.
Fleek04 is offline   Reply With Quote
Old 05-22-2013, 03:17 PM   #18
pope_face
Member#: 274373
1997 Impreza OBS
Blue - "Mishka"
Hey, I remember this from Byrne last week! I had no idea who's it was, and I don't think I clued in that it was an STi swap. Very nice...
pope_face is offline   Reply With Quote
Old 05-22-2013, 04:52 PM   #19
ap3x
Member#: 356238
JDM bunta's car
Thanks!
Yeh i know what u mean, every component used r identical its just that were not too sure if there r other extra steps with removal/installation of parts... What i dont really like is how subies dont have a dizzy, its just so much easier to adjust and diagnose timing from there.. Also how the engine bay is super packed vs honda where theres so much room lol
Old 05-23-2013, 07:05 PM   #20
cruz-in
Member#: 228858
2007 STI
wow dude. wow.
i remember i bought a few things off you in the past when you still had your accord, and how you have THAT!?
props to you dude, props.
cruz-in is offline   Reply With Quote
Old 05-25-2013, 01:15 AM   #21
FRStan
Member#: 354796
2015 Impreza 2.0i MT
Spotted at Pearl Fever right now. You live around Coquitlam? See this around quite a bit... Lookin' good
FRStan is offline   Reply With Quote
Old 05-25-2013, 04:28 AM   #22
Ronald_Type-R
Member#: 200886
2000 Legacy Wgn STi
Thank you!
Haha yes I'm in the area a lot, my girlfriend lives in Coquitlam Thanks for the kind words! I haven't gotten a chance to wash the car this week, so it's pretty filthy right now lol..
Haha yeah I know what you mean, Hondas are just so easy to work with! But that's ok, I think once I get used to the layout of the Subie's engine bay, I'll do just fine..I'm already used to its suspension and brake setup haha
Originally Posted by cruz-in View Post
wow dude. wow.
Haha thanks bro! Car definitely still needs a bit of work here and there, both maintenance and upgrades, before I can be completely happy with it, but it's a work in progress! Which parts did you buy from me last time?
Ronald
Old 05-26-2013, 04:10 AM   #23
sixthgear
Member#: 127691
11 VW CC
97 del sol dohc vtec
I remember seeing this wagon on CL last year. I've also read your build thread on your BB4, so if you're gonna put the same amount of attention on this legacy as you did with your prelude...VIC is going to be in for a treat! I can see this making Top Scoob in the future
sixthgear is offline   Reply With Quote
Old 05-27-2013, 02:34 PM   #24
white rocket
Member#: 329829
2007 STI Limited
Satin White Pearl
Absolutely love it. Wheels are a perfect fit.
white rocket is offline   Reply With Quote
Old 05-28-2013, 04:23 AM   #25
mynxi
RIP 12/6/84 - 10/28/13
Member#: 32211
2001 GC/Yamaha R6
Cashmere Yellow
Hey Ronald, nice to see you with a Subaru! Another project eh?
mynxi is offline   Reply With Quote
