Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 05-19-2013, 06:26 PM   #1
pippen
Member#: 171290
2008 STi
Default First start up on new motor.. Minor issues!
That's my LV shot.. I did port the TGVS so I know that's fixable, btw how do I get rid of that code?, and the OCV code is due to me snapping the connector off the solenoid and trying to solder it back up to work again which obviously was a major fail.
1. Is the dealer the only place to buy a new OCV solenoid? Which is apparently AKA as the AVCS solenoid?
2. I'm pretty sure the cam timing code is due to the OCV, can someone else confirm this?
3. The car should be running very rich due to the tune I had while I had a broken piston where we tried giving more fuel before knowing about it.. Can someone show me or point me in the right direction as to how to tune it down myself? I have another flurry of mods coming up after break in so I don't want to waste my tune money now..
4. Can I let the car run/idle with this going on?
Thanks for the help!
pippen is offline   Reply With Quote
Old 05-19-2013, 06:36 PM   #2
Boostedbob
Member#: 336241
08 Sti
OPB
I got my OCV from the dealer it was like 130$ I think? The car will run but I would advice against it.
Boostedbob is offline   Reply With Quote
Old 05-20-2013, 12:18 PM   #3
pippen
Member#: 171290
2008 STi
Yeah $121.. All because that retarded connector. I even tried soldering what was left of the leads and that obviously didn't work.. Not sure why. Costly part
Old 05-21-2013, 11:31 PM   #4
pippen
Member#: 171290
2008 STi
I have a new OCV related issue (i think).. P0011 CAMSHAFT POS. - TIMING OVER-ADVANCED 1. This is after I replaced the solenoid on the drivers side.. Is the "1" referring to a certain side of the motor and or certain cam? I noticed I have a small oil leak and it seems to be originating from the passenger side OCV?
Old 05-22-2013, 11:57 AM   #5
pippen
Member#: 171290
2008 STi
Anyone?
