Old 09-26-2002, 07:50 PM   #1
desiwrx02
Member#: 20168
02 wrx
black and blue all over
Default DeltaDash logs of UTEC?
Anyone got em?
They would be great to see please. I would hope the logged values are very similar to the programmed ones. Also, if you had a graph with the UTEC knock correction that would be awesome as well. Im not clear on how the UTEC pulls timing based on percieved knock.
Ajay
desiwrx02 is offline   Reply With Quote
Old 09-27-2002, 04:59 PM   #2
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
Actually.. I would be very interested in seeing this as well. Might be a useful thing to have up on the new site wackie and I are working on for tuners.
crazyhorse is offline   Reply With Quote
Old 09-27-2002, 10:22 PM   #3
codean
Member#: 10186
The only people that have a utec now are the testers and maybe a few lucky people. However I can tell you that when the utec sees what it thinks it knock, it will retard timing whatever amount you want and then slowly start adding back the timing. I don't know what number that is on the base map that turboxs has created for the masses.
codean is offline   Reply With Quote
Old 09-27-2002, 10:27 PM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
I presume that, since TurboXS sells both the UTEC and the ECUTEK DeltaDash, they could easily supply some .CSV DeltaDash files that show the results of the UTEC at both cruise (closed-loop stock ECU A/F control) and WOT (open-loop UTEC A/F control). I also know that RiftsWRX has both the UTEC and DeltaDash.
How about some DD .CSV files, folks?
Jon [in CT] is offline   Reply With Quote
Old 09-27-2002, 10:33 PM   #5
crazyhorse
Member#: 19502
scoop. =(
If someone does have them and cares to show them... PM me and I'll put them up on my server for everyone to have a look. Since I'm pretty sure you can't attach them here. Incidently.. the ecu tuning site we've been working on will be finished Monday.. so people can just upload them there if you don't mind waiting just a couple days.
Old 09-27-2002, 10:56 PM   #6
codean
Member#: 10186
Contact Riffswrx. I bet he has a bunch of logs.
DeltaDash Log - WHA?? savka Engine Management & Tuning 1 11-21-2003 02:14 PM
My ECUTEK DeltaDash logs ... Post yours here too!! wayoutwest Engine Management & Tuning 2 01-16-2003 11:00 PM
DeltaDash Log / Confused jblaine Engine Management & Tuning 12 01-06-2003 12:50 PM
New UTEC & DeltaDash logs here from tonight 10.2.02 DiMensionX Engine Management & Tuning 30 10-04-2002 10:08 AM
UTEC & DeltaDash logs here from tonight DiMensionX Engine Management & Tuning 15 10-02-2002 12:57 PM
