Old 05-20-2013, 02:43 PM   #1
liljons06STI
Member#: 310659
06 STI
Default 06 STI only making 12psi
Hey guys, created a thread a couple weeks ago about my car running like 10lbs of boost. I was running a Cobb AP 93 tune with full invidia exhaust and a perrin intake. I proceeded to replace the stock BCS-no fix. Right after that, the car started running 5lbs of boost. I then checked the wastegate and found out I needed a new one. I then picked up my buddies vf39 turbo that had only 28,000 miles on it-no shaft play, no leaks, and he gave me the vacuum line with the restrictor pill with the turbo. This past weekend I replaced the turbo, and while I was in there I fixed an oil leak from the oil return line, as well as rechecking the new BCS by hooking it up to power to make sure it was working properly. I found out for sure that the BCS is working properly. I totally removed the Cobb map and reset the ECU and took it out for a spin. Long story short it is better than before when it was running 5lbs, but is back to hitting 10-12lbs of boost. This is not only read by my gauge, but also through the ECU. I can remove the EBC line from the wastegate vacuum line and it will go up to 20lbs or so before I let off the gas, so I know the turbo and wastegate are good. So my question is what's next? No CEL except for CAT Efficiency from not having AP hooked up, smoke tested the system-no leaks......I'm at a loss of ideas guys...
liljons06STI is offline   Reply With Quote
Old 05-20-2013, 06:55 PM   #2
liljons06STI
Member#: 310659
06 STI
Anybody?
Old 05-20-2013, 07:06 PM   #3
tbanks024
Member#: 320902
2007 WRX
Is there any chance your EBC is bad? It sounds like you've eliminated quite a few variables and found that with the EBC disco'd it works fine so that's my guess.
tbanks024 is offline   Reply With Quote
Old 05-20-2013, 07:12 PM   #4
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Make sure the restrictor pill is on the compressor side not the wastegate side. And I highly doubt your "wastegate was bad".
boosted25 is offline   Reply With Quote
Old 05-21-2013, 12:35 AM   #5
liljons06STI
Member#: 310659
06 STI
the restrictor is on the compressor side, double checked it. The turbo I replaced also had shaft play. I checked the EBC already and it is functioning properly
Old 05-21-2013, 09:57 AM   #6
liljons06STI
Member#: 310659
06 STI
Ok so to update you guys, I unhooked the vacuum hose from the EBC where it connects T fitting on the turbo to see if I could get it to spike 20lbs....it doesn't even make 12 lbs of boost anymore. It hits about 7-10psi...I'm lost once again
Old 05-21-2013, 11:04 AM   #7
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Are you using a restrictor pill with a 3 port EBCS?
dstroy is offline   Reply With Quote
Old 05-21-2013, 11:22 AM   #8
liljons06STI
Member#: 310659
06 STI
I am using the factory ebcs and yes the restrictor pill is there but im not sure if something is faulty or not there. I just ordered all new vacuum lines with the restrictor pill and the T fitting from Subaru this am. Was only 20 bucks and I can now check that off the list
Old 06-01-2013, 12:00 AM   #9
02_bluerex
Member#: 215131
2007 WRX
Did the new pill ever resolve your issue!?
02_bluerex is offline   Reply With Quote
Old 06-01-2013, 01:53 AM   #10
Dillinja666
Member#: 332644
07 STI
It's white
I had the same thing and found my cats were plugged. Swapped in a downpipe and no problems since.
Dillinja666 is offline   Reply With Quote
Old 06-11-2013, 06:12 PM   #11
liljons06STI
Member#: 310659
06 STI
No I still have the same problem. Once in a while my car will only hit 7psi and other times it will hit 15 consistently. I am still at a loss on this one. It can run a whole week with 7psi then randomly switch to 15psi for a couple days, then it may switch back. Seems like there is a demon in my car sometimes, I think its possessed....
Old 06-11-2013, 06:13 PM   #12
liljons06STI
Member#: 310659
06 STI
forgot to add this, my car is catless already so that cant be an issue
Old 06-11-2013, 07:14 PM   #13
imallbob
Member#: 110147
06 STI
SGM
I had a similar issue with my 06 sti where at times it would not make more than 10psi of boost on a 22psi map about 2 yrs ago.
So I had cobb do a smoke test and everything was good. They also tightened the fittings on my GS 3 port solenoid which should of not cured the issue but strangely it did.
Good luck man.
imallbob is offline   Reply With Quote
Old 06-11-2013, 07:33 PM   #14
liljons06STI
Member#: 310659
06 STI
The weird thing about it is I have the stock EBCS
Good luck man.
Old 06-13-2013, 12:27 AM   #15
richsta42
Member#: 318286
2007 WRX STI
Obsidian Pearl Black
It kinda sounds like the problem I was having with my 07. Download Accesstuner ( free for version 2 holders) and go to your HIGH wastegate table and multiply it by 1.05 then copy that table and insert into LOW wastegate table and multiply by .95. Do this until target boost is reached. Check my recent threads for the one cobb responded too. That's what fixed my lack of boost.
richsta42 is offline   Reply With Quote
Old 06-13-2013, 01:59 PM   #16
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Sorry, was on mobile app lol. Missed out on a few details there.
BeastianSTI is offline   Reply With Quote
Old 06-13-2013, 05:15 PM   #17
Dillinja666
Member#: 332644
07 STI
It's white
Might be a stupid question, but whats your elevation there? Don't turbos boost lower levels at altitude?
Old 06-13-2013, 06:16 PM   #18
sc00ter
Member#: 117767
2015 WRX
CWP
PA is pretty much sea level so that's not an issue. Up here in CO elevation definitely plays a factor though.
sc00ter is offline   Reply With Quote
Old 06-14-2013, 11:17 AM   #19
BeastianSTI
Member#: 310506
2005 WRX STi
Sounds like you already know what the issue is. You took out the BCS, and it held to 20 PSI, right?
Could have wrong size restrictor pill, in the wrong orientation etc. Try cleaning the BCS out with carb cleaner or something, because they can get clogged up.
