Old 05-21-2013, 03:00 PM   #1
veel86
Member#: 308550
2006 Wrx STi
Default Bad ring land?
So I'm having high knock as much as -12 FBKC at low load cruising speeds. It is very random and shows different knock values. The car isn't smoking anywhere and I don't have a low oil issue. I'm going to do a compression test tonight and I will report back with the results. Has anyone had a similar problem to mine? And what did you do to fix it?
Thank you
Rob
veel86 is offline   Reply With Quote
Old 05-21-2013, 04:55 PM   #2
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
could just be a rattle in the engine bay causing false knock readings.
danny_d19 is offline   Reply With Quote
Old 05-21-2013, 05:03 PM   #3
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
I had one was -11.xx, but was told just a hiccup from the ecu, it also had no correction afyer it, just went straight to 0 on the next line. Does yours do this or does it "unlearn" the knock incrementally back to 0?
Cathexis is offline   Reply With Quote
Old 05-21-2013, 05:56 PM   #4
Sypher
Member#: 106366
2006 WRX
Pull your battery terminal and reset the "ram" in the ecu then drive it around and log.
Sypher is offline   Reply With Quote
Old 05-21-2013, 07:04 PM   #5
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Forget the compression test it is only false knock.
U need to search and read how to data log your suby. Any thing under 4000rpm forget it but anything above then be concerned but learn how to data log first!!!
trev762 is offline   Reply With Quote
Old 05-21-2013, 07:05 PM   #6
veel86
Member#: 308550
2006 Wrx STi
Mine has went straight to -12 or high knock numbers and sometimes it goes up and down slowly. I just did a compression test.
Cylinder #
1. 143
2. 145
3. 142
4. 145
Old 05-21-2013, 07:16 PM   #7
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Absolutely do not do this/
Old 05-21-2013, 07:18 PM   #8
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
This as in drivetrain vibrations and what not.....etc
Old 05-21-2013, 07:22 PM   #9
veel86
Member#: 308550
2006 Wrx STi
Alright ill just have to take a close look at everything.
Old 05-21-2013, 07:33 PM   #10
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
All right I'm in a good mood!!
Just before u go to data log for a wrx will be 3rd gear, sti will be 4th gear. When u get to 2,500rpm start data logging "wot" to almost redline then immediately stop data logging. Try to do it on flat road and safe area.
U only need to data log your default parameters.
So u know for next time u should of posted in engine management & tuning for better results.
Old 05-21-2013, 07:54 PM   #11
veel86
Member#: 308550
2006 Wrx STi
Right I guess I can do another log. It doesn't knock though.
Old 05-21-2013, 08:09 PM   #12
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Once u do look at your fbk and fkc, if u don't see any of this between 4,000-7,000 rpm u r good and also have a look at how much boost just in case u need to switch to either lwg or hwg map.
Old 06-01-2013, 09:09 AM   #13
veel86
Member#: 308550
2006 Wrx STi
Right I understand that. What I don't understand is about a week about I was at the track and my car would pick up FBKC when I was between shifts or right after I shifted and was back on the throttle. But I did a log yesterday of 2-4 and I got no FBKC at all. I'm just very confused as to where it is coming from. I will post the logs as soon as I can.
Thank you
Old 06-01-2013, 10:07 AM   #14
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Thank you
Huh/
Its quite obvious u don't understand like I've already said forget looking at fbk or anything else until u do a proper log as anything else will be only false knock/
Old 06-01-2013, 10:32 AM   #15
veel86
Member#: 308550
2006 Wrx STi
I all ready did a 3rd gear pull from 2000 rpm and everything was fine.
Old 06-01-2013, 10:59 AM   #16
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
Post the log.
moonrider_99 is offline   Reply With Quote
Old 06-01-2013, 03:47 PM   #17
veel86
Member#: 308550
2006 Wrx STi
https://docs.google.com/spreadsheet/...3c&usp=sharing
I am aware of the over boost. This is the ACN91 stage 2 cobb tune. I will be switching back to the stage 2 lwg 93 map.
Old 06-01-2013, 04:22 PM   #18
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Everything looks good and u r not overboosting its a little boost spike until the wg is regulating boost. If u start to throw p0244 overboost cel then change to the lwg map.
Old 06-01-2013, 04:26 PM   #19
veel86
Member#: 308550
2006 Wrx STi
Oh okay thank you
