Old 05-21-2013, 06:16 PM   #1
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Default Will an ELH increase strain on turbo & engine?
So, I know running 20psi on a stock motor & stock VF52 is not exactly a recipe for reliability as it is, but my tune is running very well, and I'm now considering an ELH for the added low-end torque & lower spool rpm.
My question is whether or not an ELH would make my engine & turbo even more likely to blow? (Similar to how running a turbo swap on a stock motor is almost an eventual guarantee)
It's hard to figure out, intuitively, because it would be increasing torque, it would make the turbo spool very low (making it nearly impossible to stay out boost when the car is cold) and it might flow too much for the IWG, (meaning I'd be inclined to port the turbo).
On the other hand, it smooths out the exhaust pulses, so there's less impact on the blades of the turbo, and maybe the lower restriction actually means less stress on the engine, even though the torque increases?
Relevant Mods:
Torqued Performance Stage III @ 20psi, 91oct
NGK Iridium One Step Colder Plugs
AEM CAI
Process West TMIC
Forge BPV
Grimmspeed EBCS
Invidia Catted DP
PTP Lava Turbo Blanket
DW65c Fuel Pump
blehhh is offline   Reply With Quote
Old 05-21-2013, 09:13 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
no
it's better off because of flow linearity and a lack of unequal pressures at each valve
eg33GC is offline   Reply With Quote
Old 05-21-2013, 09:20 PM   #3
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Originally Posted by eg33GC View Post
no
Ah, so it makes a difference at both ends of the system.
And the increased torque @ given RPM is had without the cost of added stress though, because it's merely a function of lower rpm spool, not altered exhaust manifold pressures or anything like that like.
I basically just don't want to get greedy and start asking too much of the stock motor, (like a turbo swap).
Old 05-22-2013, 07:28 AM   #4
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Originally Posted by blehhh View Post
Relevant Mods:
Did you talk to Eric about this already?
dstroy is offline   Reply With Quote
Old 05-22-2013, 07:42 AM   #5
jpatt006
Member#: 289470
2010 Forester XT
It should only benefit your engine if tuned correctly. The current UEL header on your car causes exhaust temps to be higher in runners 4 and 2 because they are longer than 1 and 3...guess which 2 piston ringlands are the most commonly cracked (4 and 2).
An EL header will ideally result in lower EGTs for those 2 runners.
jpatt006 is offline   Reply With Quote
Old 05-22-2013, 07:50 AM   #6
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Not yet, just dawned on me that I could do a header relatively easily and see big gains. I'd likely have Eric re-tune it, or I'd get a pro-tune and throw in injectors as well.
Old 05-22-2013, 09:39 AM   #7
dstroy
Member#: 283711
2012 STI sedan
Ask him about it, and if you're going to do injectors he'll do it if you have a wideband that you can hook up to ATR and log with.
Old 05-22-2013, 10:25 AM   #8
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
An EL header doesn't shorten the 2 and 4 runners, it lengthens the 1 and 3 runners to be just as long as 2 and 4. So your argument doesn't make a lot of sense. By that logic, you should be saying that an UEL header makes 1 and 3 safer than an EL by shortening their runners.
OP - it's all about flow linearity, not EGTs or anything else. And people make all the fuss in the world about the horrid atrocities of UEL, but at the end of the day, a similarly designed aftermarket EL and UEL have been shown to make basically the same amount of power on the dyno, both of which significantly higher than stock. So go with what you want and safely ignore the EL nazis.
Old 05-22-2013, 10:28 AM   #9
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Originally Posted by the suicidal eggroll View Post
An ELH doesn't shorten the 2 and 4 runners, it lengthens the 1 and 3 runners to be just as long as 2 and 4. So your argument doesn't make a lot of sense. By that logic, you should be saying that an UEL header makes 1 and 3 safer than an ELH by shortening their runners.
I was thinking the same thing, but he could still be right about the temperatures dropping IF the equal length aids the flow of the entire system so much to the point that back pressure inside the 2 and 4 runners is reduced.
I always thought EL shifted the torque curve to the left by like 500rpm, (because of the lower spool)... Is that not necessarily true? Am I thinking of a twin scroll setup? I wish I could find more conclusive, direct dyno before/after comparisons of this.
This is also making me really want to go EL (even if this dude can't drive):
Old 05-22-2013, 11:07 AM   #10
Member#: 51961
2005 STi
2012 WRX
You're probably thinking of a twin scroll setup. EL headers are praised for their top end power, not their spool. And tests show that their top end power isn't really much different than a well designed UEL anyway.
There was a big header shootout several years ago. It compared stock to Grimmspeed to multiple tubular EL and UEL. In the end, the Grimmspeed made about 10whp more than stock, and both EL and UEL made about 10whp more than Grimmspeed, with very similar spool and power curves as each other. Unfortunately the server hosting the images went down a while back, and I haven't seen anybody re-host them. I wouldn't mind hosting them if somebody had the original images, but that seems to be hard to find.
Old 05-22-2013, 11:19 AM   #11
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Hmmm... maybe it's not worth it then.
Someone at the dyno day this weekend had a 2011 WRX, Cobb OTS Stg 2 93 oct map, Perrin ELH, Perrin TMIC, Perrin Pulley, etc. He put down 297whp.
My 2012 WRX, TP Stg 3 20psi 91 oct, PW TMIC, GS Pulley, etc put down 291whp, (I actually made more torque than him)
It must be my 20psi that even landed me anywhere near his numbers, but this torque curve is what really caught my eye, it was left of mine by a few hundred rpm.
Not trying to chase numbers or even another car, just intrigued about potential gains.
My carbon fiber driveshaft (whenever it shows up!) should be good for a couple-two-three whp on a dyno though lol.
Old 05-22-2013, 11:27 AM   #12
Member#: 51961
2005 STi
2012 WRX
Keep in mind that my comments are referring to EL vs UEL, not aftermarket vs stock. There are still significant gains to be had (both top end power and often spool also) from an aftermarket header, but whether that aftermarket header is EL or UEL doesn't matter a whole heck of a lot.
Old 05-22-2013, 11:34 AM   #13
themaus
Member#: 321211
So the car with the headers was running a Cobb OTS map?
themaus is offline   Reply With Quote
Old 05-22-2013, 11:35 AM   #14
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Maybe it was a perrin map? I was going off of hear-say from others.
I was still surprised to be so close in power with a stock header.
Old 05-22-2013, 11:39 AM   #15
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
curious, were these cars making quite large numbers or more moderate numbers? I would imagine the difference would be progressive(progressively larger) and not linear as overall power increases, no?
SenorDucK is offline   Reply With Quote
Old 05-22-2013, 11:46 AM   #16
themaus
Member#: 321211
I doubt you'd see much for gains without a proper tune for them.
Old 05-22-2013, 11:48 AM   #17
themaus
Member#: 321211
http://forums.nasioc.com/forums/show...8&postcount=18
Old 05-22-2013, 11:56 AM   #18
Member#: 51961
2005 STi
2012 WRX
I believe the car was making low 300s on the stock header.
Old 05-22-2013, 11:59 AM   #19
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Sounds like I'd be into it for well over $1000 then for parts and a pro-tune. (Unless I had Eric retune somehow).
meh.... lol More $$$ than I thought for worthwhile gains.
Old 05-22-2013, 12:00 PM   #20
Member#: 51961
2005 STi
2012 WRX
Good link, those are similar gains to what I remember the aftermarket UEL and EL headers making in the header shootout I was referring to above. I don't recall the midrange gains being that high, but the shootout was done on an older car without exhaust AVCS, which could have something to do with it.
Old 05-22-2013, 12:04 PM   #21
themaus
Member#: 321211
Agree.
I'm going to do a before and after airboy and virtual dyno.
Before will be turboback, after will be ks tech intake, perrin el's and a 38mm ewg, and ID1000s. Car is a 2012 wrx.
Old 05-22-2013, 12:21 PM   #22
SenorDucK
Member#: 327511
13' WRX 6 Speed
thanks, I've already jumped onto the ELH bandwagon though
Old 05-22-2013, 12:42 PM   #23
jpatt006
Member#: 289470
2010 Forester XT
I never stated that EL would shorten runners 2 and 4... I am well aware that an EL manifold lengthens 1 and 3.
My point was that the longer 2 and 4 runners cause the EGTs to be higher in cylinders 2 and 4.
Old 05-22-2013, 12:45 PM   #24
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Yes, relative to 1 & 3, but does the elongation of 1 & 3 actually reduce the temperatures in 2 & 4?
Old 05-22-2013, 01:05 PM   #25
jpatt006
Member#: 289470
2010 Forester XT
This is where I agree with Eggroll and the flow comes into play. If all runners are the same length, then the exhaust gasses would have the same distance to travel and result in even temperatures/flow.
Contrast the stock UEL manifold where you have relatively cooler gasses from 1 and 3 colliding with relatively hotter gasses from 2 and 4 at the up pipe. This back-up/restriction prevents gasses from 2 and 4 from flowing through freely (causing subaru burble) and causes Temps to be higher in cylinders 2 and 4.
This is what I have gathered from all my reading If there is any other information or evidence, please by all means share it. I don't pretend to know it all
