Old 05-21-2013, 11:56 PM   #1
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
Default Sway Bar
Anyone know if a 08 STI Hatch rear swaybar will fit a 2011 WRX Sedan?
im assuming it will but since the catbacks are different the swaybars maybe aswell?
ClemRoo is offline   Reply With Quote
Old 05-21-2013, 11:59 PM   #2
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
The stock 08 STi swaybar is nothing to write home about. I'd just get a real aftermarket SB and put it on your car. Seriously I threw mine on the trashheap when I got some whiteline swaybars. Part vs stock was huge. Also if you do the swaybar you should get new endlinks. And you shouldn't run an aggressive sway bar on the back and nothing complimentary on the front. From what I understand it can severly impact driveability.
Napalm3nema is offline   Reply With Quote
Old 05-22-2013, 12:13 AM   #3
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
From my understanding my current rear sway is 16mm and the O8 sti is 18 mm im not looking to spend 200$+ on sways im just looking for something slight to improve handling. im keeping my stock front sway with the sti rear and sti endlinks which is more than sufficient what im looking for
Old 05-22-2013, 12:54 AM   #4
easyeatlanta
Member#: 347906
2008 Sti - 6066
the upgrade to the sti rear is a common mod and many people seem to be very happy with it but I would suggest getting one from a sedan although im not a hundred percent sure on the fitting. Last I saw they go for about $90
easyeatlanta is offline   Reply With Quote
Old 05-22-2013, 01:58 AM   #5
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
Coo then carry on and good luck with your search!
Old 05-22-2013, 04:00 AM   #6
FL4TFTW
Member#: 256953
2014 WRX Hatch
I highly doubt a 2mm increase will make a noticeable performance increase. IMO do it right the first time. Save up for some Eibach sways. They're relatively inexpensive.
FL4TFTW is offline   Reply With Quote
Old 05-22-2013, 05:46 AM   #7
PSBeachBum
Member#: 279870
2005 WRX Wagon
my 05 wrx wagon 17mm to a sedan 20mm was a good difference. I just want more now so if you can get it free, WHY NOT?
PSBeachBum is offline   Reply With Quote
Old 05-22-2013, 05:54 AM   #8
leecea
Member#: 37359
2003 WRX
http://www.oakos.com/wrx/swaybarchart.htm
60% increase in bar stiffness. Not sure how that translates to seat of the pants feel, but seems worthwhile.
leecea is offline   Reply With Quote
Old 05-22-2013, 10:24 AM   #9
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
exactly ive seen many ppl happy with the difference you for example and im only spending 30 bucks on it so its a steal
Old 05-22-2013, 10:26 AM   #10
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
Thats a sweet chart man 60% is more than i expected so hopefully it will be noticeable in the corners
Old 05-22-2013, 10:32 AM   #11
cmiovino
Member#: 134005
2004 WRX Premium
Moving from 13mm stock ones on GCs to even the 17mm of a WRX, or even 20mm was a large increase.
A buddy of mine even has a 20mm WRX one on his 2.5i and it really made a big difference.
Keep in mind however, these were going from a 13mm noodle to 20mm. Going from a 16mm to 18mm is a smaller difference, although it will still be noticeable. You can surely notice the difference going from 17mm to 20mm.. I'd assume 16->18 would be similar.
If you have a 2011, really look into getting a aftermarket one. The STI one will help and give an improvement, but for the price of sways, I'd go for aftermarket here. You can get adjustable ones. Something in the 20mm range even on a stock suspension will make a world of difference. Don't go much beyond this point as you will get that lift off oversteer or snap oversteer everyone talks about.. however, it's only apparent on snow or when at the limit.
Old 05-22-2013, 11:04 AM   #12
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
which wrx has a stock 20mm rear sway? i was looking for a 2011+ sti sway 19mm but had no luck so i have to settle for the 18mm which im sure will satisfy me for now.
Old 05-22-2013, 11:14 AM   #13
RM_2
Member#: 163058
'16 BRZ Limited WRB
'06 Saab 9-2X 2.5i NGM
You can get a 19mm STi rear swaybar from SubaruGenuineParts (LINK).
I ordered exactly that and paired it up with Kartboy endlinks front and rear. It's a massive difference going from the 16 mm to the 19 mm in my '11 WRX.
RM_2 is offline   Reply With Quote
Old 05-22-2013, 12:28 PM   #14
leecea
Member#: 37359
2003 WRX
The earliest models - 2002/3 - like mine
http://www.fastwrx.com/suoem20reswb.html
Old 05-22-2013, 12:53 PM   #15
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
thats sweet too bad it wont git mine
Old 05-22-2013, 01:37 PM   #16
leecea
Member#: 37359
2003 WRX
But isn't the rear suspension completely different on the later models? I thought I'd read that they rotate better and don't need such big rear sway bars.
Old 05-22-2013, 02:18 PM   #17
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
yea its different but 16mm is still relatively small going to 18-20 is perdect IMO
Old 05-22-2013, 02:22 PM   #18
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
They are different but 16mm is still relatively small and going 18-20 is perfect IMO. i feel like you dont have to go so big on these 3rd gen because they handle very well as they are
Old 05-22-2013, 05:56 PM   #19
09rexrunner
Member#: 293955
2011 WRX
Have you searched the classifieds. Pretty sure there's two for sale right now.
Edit: LUMBERZACK and wayward167 have 19mm rear sways currently for sale
09rexrunner is offline   Reply With Quote
Old 05-22-2013, 06:08 PM   #20
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
im looking for an oem 2011+ rear sway
one of them is selling aftermarket 22mm sawys and the other is the front sway from the 2011
thx tho
Old 05-22-2013, 06:51 PM   #21
09rexrunner
Member#: 293955
2011 WRX
thx tho
My bad. LUMBERZACK must've sold the rear bar. I know he had one cuz I was interested in buying it. wayward167 has a 19mm "spec c" bar with poly bushings. I know that cuz I was interested in that as well. He also has a WL sway bar brace.
Edit: If I knew how to link the thread I would sorry.
Old 05-22-2013, 06:58 PM   #22
LUMBERZACK
Member#: 340009
2007 STi
48W
Yea I sold the rear, Still have the front and end links.
LUMBERZACK is offline   Reply With Quote
Old 05-22-2013, 07:01 PM   #23
09rexrunner
Member#: 293955
2011 WRX
Knew I should've jumped on that when I had the chance. Damn shipping costs.
Old 05-22-2013, 07:15 PM   #24
09rexrunner
Member#: 293955
2011 WRX
Nvm, wayward sold his bar too. Sorry I tried to help.
Old 05-22-2013, 07:34 PM   #25
ClemRoo
Member#: 343934
2011 WRX
Charcoal Gray
yea man thx appreciate it
