Old 09-26-2002, 10:23 PM   #1
ERaab212
Member#: 18466
2003 GT35r Evo VIII
11.033@132
Default How do you install DYNAMAT trunk kit?
Does anyone know how to do this stuff. is it easy. any hints or a good description of how to do it.
thanx,
erik
ERaab212 is offline   Reply With Quote
Old 09-27-2002, 11:30 AM   #2
Jakezor
Member#: 9624
2002 ImprezaWRXsedan
Platinum Silver Metallic
#1 Prep prep prep!
Take everything out of your trunk. Including the factory carpet and such.
Clean the metal with rubbing alcohol (or something similar) to get any grease or what not off.
If you have the normal dynamat a hair dryer or heat gun will be almost necessary. You don't really need one for Extreme. Or just let everything sit in the sun for a while.
An old tooth brush will be helpful for getting into those small spots and a wallpaper roller helps for bigger flat areas.
I wouldn't be concerned about getting it to look like they picture the installs, rarely does 1 whole piece of dynamat go on very nice or even contacting 100%.
Go to my webpage http://jakezor.doesntexist.com/ and go to WRX, then stereo install. I've got some pictures of my trunk that is very dynamatted.
Jakezor is offline   Reply With Quote
Old 09-27-2002, 08:23 PM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Umm, your website is all messed up, I get no pics, and when I click on a link it sends me to an ATTB 'URL not found' page, but if I open it in a new browser tab it works fine (except there are no pictures)
Concillian is offline   Reply With Quote
Old 09-28-2002, 10:58 AM   #4
Jakezor
Member#: 9624
Hmm it works for me, I'll check it out. Probably re-upload it.
If you want to forsake the frameset go here: http://home.attbi.com/~jacoberickson/wrx/install.htm
give that a shot and let me know.
Old 09-28-2002, 11:50 PM   #5
Atimaxx
Member#: 25339
2000 2.5 RS
STi engine swap soon!!!!
when you are working with the dynamat, keep in mind that the material must be soft to properly adhere to the metal. so when you are working, make sure you use a HEAT GUN, not just a hair dryer, the hair dryer doesnt give it enough heat.
you can apply the dynamat to the metal and then run the heat gun over it, softening it and rolling the roller over it. you will notice that when the dynamat is soft, it takes the shape of the metal and once it is cool, it is hard to get off.
you can apply the material in strips or in large sheets. i tend to use the whole sheet and then put strips into the tight spots.
if i were you, only use extreme on the trunk lid because otherwise it will get too heavy. the extreme is the easiest to work with but it is very hard to get off once it is attached. you should also use a roller so that it attaches properly.
trust me ive installed PLENTY of these kits and they arent too hard to do. take your time and dont get upset if you mess up or get it wrong the first time, you can always use the heat gun to soften it up and move it.
Good luck!
Atimaxx is offline   Reply With Quote
How do you install the Footwell Illumination Kit (H201SSC000) in the '09 FXT/WRX/STI? GodWhomIsMike Interior & Exterior Modification 209 01-23-2013 11:58 PM
You got the "200" STI 6speed swap lists now, how do you install? wrx03.4wz Transmission (AT/MT) & Driveline 9 07-16-2009 11:32 AM
What's in your trunk / how do you setup your trunk? Ken Off-Topic 21 05-23-2004 10:16 PM
How do you like your turbo kit for 2.5 rs? Szm426 Normally Aspirated with bolt-on Forced Induction Powertrain 32 07-26-2002 10:44 PM
Message Board Statistics All times are GMT -4. The time now is 07:57 PM.
