Old 05-23-2013, 01:29 PM   #1
nickysigz06sti
Member#: 354054
Default vag com cable 06sti
I just got a vagcom cable and am looking for some help of how to flash my 06sti. I've heard some
People say u can't some say you can . Im just looking for some help and if anyone knows of a stage 2 speed density tune or just a stage 2 that I could upload to start with could use the help to make it easier
nickysigz06sti is offline   Reply With Quote
Old 05-26-2013, 09:26 PM   #2
Andrewxxcarlson
Member#: 316415
2006 WRX
Vagcom works once in a blue moon.. I'd know.
Andrewxxcarlson is offline   Reply With Quote
Old 07-16-2013, 12:37 PM   #3
nickysigz06sti
Member#: 354054
Have you had it work on a 2006 sti I'm trying to flash I can log fine just can't flash maybe something him doing or using isn't right ?
Old 08-08-2013, 09:51 AM   #4
nickysigz06sti
Member#: 354054
Bumo need help still
Old 08-08-2013, 10:08 AM   #5
Andrewxxcarlson
Member#: 316415
2006 WRX
Check where you have ecuflash looking for definitions, rommetadata or whatever file.
Old 08-11-2013, 10:16 AM   #6
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Supposedly 64bit operating systems wont work. I use a Windows XP machine.
I use a $10 Vag-COM cable to tune my 07 WRX.
You have left ALOT of questions unanswered with info that you did not post.
Black94Snake is offline   Reply With Quote
Old 08-11-2013, 01:28 PM   #7
MadProfessor
Member#: 192779
I use a vagcom cable to tune an 06 WRX. The biggest problem I had was getting an older version of EcuFlash so it would work with the cable. The newer versions do a check to see if you are using their cable, and won't work with vag-com.
Do a google search, the information is out there.
MadProfessor is offline   Reply With Quote
Old 08-11-2013, 05:19 PM   #8
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
its not really that big of a problem...
http://evoecu.logic.net/mirror/ecuflash/releases/
and I use 1.42.2595
It doesnt give a **** what cable you have.
Old 09-19-2013, 01:14 PM   #9
mikeyPSF
Member#: 236475
One important change in the newer versions of our software is that we spent a lot of time to write our own device driver since the older versions of EcuFlash use a Microsoft driver that infrequently but occasionally resulted in Windows blue screens. Since we switched to using our device driver we haven't had a single blue screen. Something to consider when evaluating which cable you want to use.
mikeyPSF is offline   Reply With Quote
