Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 05-24-2013, 07:48 PM   #1
sysfailur
Member#: 135993
08 AW STi GTX3071
V-Mount, 18x12, 335 R888
Default 08_AW_GRB: Area 1320 V-Mount GTX3071 : BOXERFEST BOUND!
Alright NASIOC I've decided to finally post up my car's journey on here for the first time in full. I've been on IWSTI continuing updates there but figured I would consolidate and re-post over here giving you the meat of my build. I have a 2008 Aspen White STi and at around 44,000 hard driven miles during an auto-x run my 3rd piston decided it wasn't going to work any more. So, the car sat for a little while I figured out what I was going to do. Initially I was just going to buy my friend's shortblock, put it in, and be done with it but as it often happens, I went balls deep instead.
My goal for this phase of modification was to make a nearly indestructible auto-x engine with extremely quick response and the ability to rev and boost high with all safety measures taken to ensure the engine will survive. Yes my hotside is small but it's v-band and there are .82 and 1.06 waiting to be used for other applications. What this phase of my car's life entails is power from down low (hopefully ~3300-3500) revving out to 8200 or so safely in 2nd gear with the best response possible. I plan to eventually do further weight reduction, add a cage, strip it down, etc but as of now I'll retain my interior and keep it somewhat streetable.
5/24/2013: Where my car is at now is most fabrication is done and the last parts can not be modified until the engine is back in, the exhaust is back on, and we can route all the plumbing and mount everything. I also still need to purchase my wheels/tires/flares but those will come in time. I'm selling my current wheels to help the purchase of the new setup.... and I'm going BIG.
When will it be done? Not sure. When time/money allows for it to be done! I'm taking things slowly and properly and not cutting important corners. This is my dream car and I'm doing it the way I want! You may notice I don't have a single exterior mod done for looks.... every time I think about buying something I then think... "but it doesn't do anything" and nix it and buy something related to safety, power, or handling. It's just the way I am.... I doubt I'll ever get a Varis body kit for $10K--it's just not for me.
Finally, big thanks to Ryan @ Area 1320 for the build guidance, advice, and fabrication! I've done what I can that are within my abilities but Ryan is the master and will be doing tricky stuff. Also thanks to Adam for pulling the engine with me and helping wield a grinder in a way I have yet to master. And of course, never-ending thanks to my girlfriend for understanding my obsession with my silly, noisy, uncomfortable car that makes her sick when she gets rides in it lol
Thanks also to Toyo and Forgeline for jumping in with sponsorships for this build. My budget isn't massive so the help I've gotten from them is greatly appreciated.
Questions/comments welcomed. Enjoy!
EDIT:
What remains to be done as of today:
*Start final assembly/installations/fabrication.
*Front end reinforcing via custom bumper bar.
*Radiator bung modification for -20 AN.
*Fab Intercooler piping + intake piping
*Bungs in downpipe
*Exhaust cut-out install
*Exhaust cut-out side exit... something special in the works
*Add v-band flange to axleback exhaust
*Touch up pie-cuts on inside of downpipe
*Mount accusump + route ss hose to front
*Mount battery in trunk + route electric
*Mount all oil and fuel components + lots of plumbing
*Top off all fresh fluids
*Sand and prep hood one last time, have hood painted professionally
*Install flares
DONE!!!!
MOD LIST BREAKDOWN:
(Rally Blue = Installed/Purchased Mods, Red = Coming Soon, Black = Potential Upgrades)
Engine/Power:
Garrett GTX3071R .63 Tial V-band Exhaust Housing
Fully Forged Short Block w/ Darton Sleeves, Stock Nitride Crank, CP Pistons, Eagle Rods, ARP Studs
BC S2 Cams, Springs, Retainers and mild PnP job by myself
Cometic Head Gasket
Gates Racing Timing Belt Kit
Tomei Timing Belt Guide
AVCS Delete, WRX Cam Gears
Supertech Inconel Exhaust Valves, Stainless Intake, Std Size
Area 1320 Custom Rotated Downpipe w/ electronic exhaust cutout (316L medical grade)
Area 1320 Custom Up-pipe / Dump Tube w/ Tial 38mm EWG (316L medical grade)
Area 1320 Custom Intake
Area 1320 Custom V-Mount Intercooler
Mishimoto MR2 Radiator -- modified for v-mount application
AN-20 Fittings and Startlie Hosing for Radiator
Greddy Ti-C converted to v-band
Greddy Mid-pipe has flex connector installed + electric cut-out + turn down
Tomei EL Headers
P&L Air Pump Delete
Hallman Pro RX Boost Controller
Turbosmart RacePort BOV
ATI Super Damper
Electronics:
Carberry Engine Management + Omni 4 Bar MAP speed density
AEM Digital Gauges: Oil Temp, Oil Pressure, Boost, Wideband
Odyssey PC680 Battery relocated to the boot
Racepak IQ3 w/ Data Logging
Fueling:
Aeromotive 340 In-Tank Pump
Deatschwerks 1000cc Injectors (flow tested/cleaned 1050cc+)
Agency Power Fuel Rails
-6AN custom Fuel Lines w/ Russell Fittings
Aermotoive Fuel Pressure Regulator
Integrated Engineering Surge Tank / Bosch 044 submerged (-6AN)
Fuel Lab 40 micron Stainless In-Line Fuel Filter w/ check valve
Oiling:
Killer B Motorsports Oil Pan, Pickup
ACL Oil Pump
Canton Racing Accusump (2QT, -10AN)
Canton Racing Electronic Valve Controller
Aeromotive Billet Check Valve
Mocal 235matrix 25 row Oil Cooler (-10AN)
190F Mocal Thermostat Sandwich Adapter
Aeroquip -10AN stainless lines throughout oiling system
Canton Racing 6" CM in-line oil filter
Peterson Fluid Systems Breather Can
Track Prep / Cooling / Braking / Misc:
Earl's Power Steering Cooler
WRC V-Mount Intercooler Vent
RunCool Hood Louvers 11"x17"
CF style Aerocatch latches
RaceTech RT4009WHR Seat
Planted Technology Seat Bracket
Planted Technology Seat Base
P&L SS Clutch Line
P&L SS Brake Lines
Custom SS Turbo Oil Feed -4AN Russell
Custom SS Power Steering Line -6AN Russell
Hawk HPS Pads
Spare and other misc parts removed
Drive Train:
Competition Clutch + Flywheel
Kartboy Rear Shifter Bushing
Perrin Front Shifter Bushings
Torque Solutions Engine, Tranny, Pitch Stop, Short Shifter
Cusco Rear Diff Inserts
WL Rear Subframe Inserts
TiC Tranny Crossmember Bushings
TiC Holy Shift Set
Kartboy Rear Subframe Bushings
Wheels / Tires:
Forgeline GA3R 18x12 +12 Polished Lip, Titanium Hardware, Satin Silver Center
335/30/18 Toyo R888
3.5" carbon fiber flares via eBay
Project Kics R40 Gun Metal Lugs
949 Racing Gun Metal Anodized Alum Valve Stems
Suspension Upgrades:
Fortune Auto 510 V4 Coilovers 8kF/9kR Swift Springs + Roller Bearing Upgrade
Cusco Rear Adjustable Lower Control Arm
Cusco Front Lower Arm Bar Type II
Cusco Front/Rear Strut Bars
Kartboy Front/Rear Endlinks
Whiteline 22mm Front Sway Bar,Whiteline 20mm Rear Sway Bar
Whiteline Rear Sway Bar Mount Reinforcements
Whiteline Steering Rack Bushings
Whiteline Front Control Arm Bushings
Whiteline Roll Center Kit
Whiteline Rear Toe Arms
Exterior/Misc:
2011 STi Bumper w/o fogs
Perrin Shorty Antenna
25% Tint
Fluids:
Amsoil 5W40 Signature Synthetic Engine
Amsoil 75W90 Synthetic Transmission / Diff
Amsoil 600 DOT 4 Brake Fluid
Amsoil Power Steering Fluid
Amsoil Dominator Coolant Boost
Last edited by sysfailur; 04-23-2015 at 07:21 PM. Reason: various fixes to post, pictures added, etc
sysfailur is offline   Reply With Quote
Old 05-24-2013, 07:51 PM   #2
sysfailur
Member#: 135993
08 AW STi GTX3071
AEM gauges testing https://www.facebook.com/photo.php?v...52871992382066
Gauges going in:
Electric cut-out switch added in:
Old 05-24-2013, 07:52 PM   #3
sysfailur
Member#: 135993
08 AW STi GTX3071
Some pics of the head work I did... 5 hours of sanding worth.
Valves being lapped:
Process of installing the WRC vent. First let me say that this is not the easiest process for a 2008 STi as they are not meant for this generation. There is not enough room to actually create exhaust ducting for the intercooler because the TMIC scoop is in the way. I didn't want to interfere with that so we put it as far back as possible and the purpose of it will be merely to vent out as much air as possible during idle. My friend Adam did the hood cutting and then I did some cleaning up and bending of the sheet metal to make things line up right. I used 3M panel bond to attach it to the hood which worked wonderfully and then bondoed around the scoop to blend it in nicely to the hood. I figure that with the louvres and WRC vent there will be PLENTY of routes for the air to escape. I may look into the GC WRC style dual-chimney venting style to the louvres but I don't know if there is room for that until everything is back in the car.
All was going well until I went to paint it. The base wasn't an issue but the company I used (touchupdirect) via amazon gave me a clear coat that caused severe yellowing. I was refunded my money and given new paint cans but once the car is done I'm going to just have it professionally sprayed. Oh well, I gave it a good go! haha
The Louvers came pre-powdercoated and those will not be sprayed but the rest of the top of the hood will be sprayed. I'll touch up the bottom myself later.
Shot of the hood bonod'ed and the "wings" I've fabricated for the radiator. I spent a good two-three days forming them to sit just so in the bumper so that it would scoop the air up in the direction of the intercooler/radiator. The wings are also welded in this pic and also supported in the rear with aluminum bars. I taped up the radiator as I also spent 2 hours straightening EVERY single fin even better than factory haha
Base on but no clear. I can't wait for it to look like this in the end. Of course the WRC vent will be meshed. I've also picked up an ebay sports grille which I will have painted white to allow more air into the intercooler.
Yellowing clear *uhg* .... but I got the aerocatch latches in! Once it is painted I will be sure to fully install them.
Old 05-24-2013, 07:53 PM   #4
sysfailur
Member#: 135993
08 AW STi GTX3071
Pie cut downpipe + better shot of the downpipe/up-pipe assembly. Unfortunately I only have cell phone quality but you get the idea.
I definitely want to swaintech white lightning them at some point.
Early build mock up with blown engine still in car:
Intercooler core is a bell core, 3.5x9x14 I want to say. It can flow around 942cfm or so I believe if memory serves. Again slightly small yes, but I'm doing all this for a reason and actually it can flow more than some bigger but crappy design cores.
Shots of the hood getting cut up for louvres:
80 rivet holes... this was real fun *roll eyes*
Early stage intercooler end tank fabrication. This end tank was made by Ryan who is doing all of the designing/fab work that I haven't done (and he instructs me what to do if I'm doing it). So, he made this one and I replicated it to the best I could the other side and with a little metallurgy Ryan fixed the one I made to make it nearly identical to the one he made. Job done!
I really do want one of these.... but I may have another idea which I'll keep in my head for now unless I find a spare $3000 for a L'aunsport spoiler :P
These are the wheels I am looking to purchase--Forgeline GA3R in 18x12 +18. Of course my car will need flares and initially I plan on going with just rivet-on carbon fiber 240sx flares. Eventually I would love to have some custom work done when I can afford it a'la JGTC open vent flares. The picture I am referncing here to show the meat on the Mercury was something I found when I was searching oddly enough for pictures of 335/30/18 tires which is what I want to run--and this is the exactly the same wheel I want to run, in the same size, with the same size tire. I am looking to either go full polish or matte black center, polish black lip.
Also the article I am referencing here shows one route I may go when having my flares properly produced. I really don't want bolt on flares, but I'll buy em to get by and then have something custom made maybe next year or later.
Old 05-24-2013, 07:57 PM   #5
sysfailur
Member#: 135993
08 AW STi GTX3071
One more reservation... and shower time. Back with more updates in a few!
Old 05-24-2013, 08:11 PM   #6
monjarassi
Member#: 281623
06 STI
Obsidian Black Pearl
sexy and intriguing
monjarassi is offline   Reply With Quote
Old 05-24-2013, 08:28 PM   #7
Derek11WRX
Member#: 296224
2011 STi Sedan
Plasma Blue Pearl
Damn.
Derek11WRX is offline   Reply With Quote
Old 05-25-2013, 12:09 AM   #8
sysfailur
Member#: 135993
08 AW STi GTX3071
Annnnnddd updated the first couple posts to cover pretty much everything of interest. I'll leave it as such until I have more news to post.
Enjoy your weekend!
Old 05-25-2013, 12:45 AM   #9
Shipman
Member#: 312847
2006 WRX STi
2008 Legacy/2003 Forester
Dang son, operation go hard engaged
Shipman is online now   Reply With Quote
Old 05-25-2013, 09:30 AM   #10
561wrx
Member#: 166427
03 wrx
oh my jeus
561wrx is offline   Reply With Quote
Old 05-25-2013, 09:49 AM   #11
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Definitely looking forward to how this build turns out! Great work!!
calebtharrell is offline   Reply With Quote
Old 05-29-2013, 04:58 PM   #12
sysfailur
Member#: 135993
08 AW STi GTX3071
Small update today but it is something... painted the grille I purchased a little ago. I will transfer over the STi logo and add mesh to it.
Old 05-30-2013, 06:43 PM   #13
sysfailur
Member#: 135993
08 AW STi GTX3071
Heads cleaned up and ready to rock.
Old 05-31-2013, 02:00 AM   #14
9vapors
Member#: 92582
Awesome setup, I love that you're not afraid to cut the **** out of it and focus on the motor...
9vapors is offline   Reply With Quote
Old 05-31-2013, 02:12 AM   #15
jvsoundwave
Member#: 66060
2007 STI Limited#534
Crystal Gray
WOW! Bad ass work man!
jvsoundwave is offline   Reply With Quote
Old 05-31-2013, 09:37 AM   #16
alecb
Member#: 335146
2004 STi
That's a nice setup man. Can't wait to see it all done.
alecb is offline   Reply With Quote
Old 05-31-2013, 10:01 AM   #17
besthaticouldo
Member#: 279660
wow, just wow. can't wait to see more of this car.
also you bought the wrong grille. you bought an 08-10 grille and not an 11+.
besthaticouldo is offline   Reply With Quote
Old 05-31-2013, 11:05 AM   #18
9vapors
Member#: 92582
After a re-visit to this thread, do you have any pics of your cutout and location?
Old 05-31-2013, 06:17 PM   #19
sysfailur
Member#: 135993
08 AW STi GTX3071
Hrmm. I haven't fitted it to the bumper yet. If it doesn't work or looks stupid I guess I'll be selling that! haha *eep*
Old 05-31-2013, 06:23 PM   #20
sysfailur
Member#: 135993
08 AW STi GTX3071
Actually that is one of the remaining parts that has to be put on the car once the engine is back in and the exhaust is on. The location is going to be on the mid-pipe, right after the downpipe. We've also added a flex section to the mid-pipe so it'll be right after that I believe. Not sure exactly where yet as the exhaust needs to be back on the car. I've got it wired but just not yet installed.
The cut-out itself is from Summit Racing, their brand, and we're just gonna weld it right on probaly. I'm not messing with gaskets and crap. As soon as it's done it'll be posted up!
Glad you guys are enjoying the project. I figured that I would probably never find myself wanting to get rid of my car so why not just go for it and do exactly what I want?
Also.... wheels should be ordered in a few weeks. To say I'm excited is an understatement.
Old 05-31-2013, 06:30 PM   #21
P-Train
Member#: 279233
2008 WRX
That looks like the same cheapo grill I just bought lol.
P-Train is offline   Reply With Quote
Old 06-13-2013, 08:19 PM   #22
sysfailur
Member#: 135993
08 AW STi GTX3071
Alright gents.... updates are not that thrilling but the status is as such:
Engine status = heads were on, bucket to cams were measured and long story short, it's too tight so today I measured everything and the valves are being pulled to be zipped down every so slightly. When it's back we're gonna have to re-do all the measuring and get some buckets for proper clearances.
Sucks but needs to be done. And that's where things are at. I should be ordering my new wheels soon as I sold my old Prodrive wheels.
Old 06-13-2013, 10:42 PM   #23
stierzy34
Member#: 92113
2013 Mini Cooper S
"Martha"
This has to be one of my favorite cars. Cannot wait to see more progress!
stierzy34 is offline   Reply With Quote
Old 06-14-2013, 01:18 AM   #24
djbondoc
Member#: 343025
2014 Forester XT
Dark Gray Metallic
Subscribed! Awesome work so far. Excited to see where this goes.
djbondoc is offline   Reply With Quote
Old 06-14-2013, 01:51 AM   #25
fuelMuncher
Member#: 301554
2002 WRX Wagon
wow. subscribed.
fuelMuncher is offline   Reply With Quote
