Old 05-28-2013, 03:01 AM   #1
BeardedShogun
Member#: 354456
Default 07' wrx won't rev past 4000
I've done my research on this matter, but I feel like I need more opinions and help on dealing with this.
Problem is, when I try to put my foot down and give it an aggressive amount of throttle, I get hesitation and finally I hit a wall at around 4-4.5k depending on gear.
only started happening after flashing to stage 1
Currently the only mods I have:
Cobb SF intake
Cobb AP stage 1 93
other than that car is bone stock.
At first I believed it was due to the intake, maybe a ratio problem, replaced it with the factory filter and still had the same problem.
Made sure my launch control and flat foot settings on the accessport were well beyond redline, still the problem occurred.
So far the only solution I have to get around this is to return to stock through the AP and uninstall, as the problem seems to go away when I do that.
Any suggestions?
BeardedShogun is offline   Reply With Quote
Old 05-28-2013, 03:06 AM   #2
BeefCurtains64
Member#: 251257
12 WRX
Try your rev limiter .... just a hint or Stg 1 w/ Cobb intake ... map
BeefCurtains64 is offline   Reply With Quote
Old 05-28-2013, 03:06 AM   #3
TW0P0INTSL0W
Member#: 305392
2002 WRX Wagon
Does it do it while moving? Or just at a standstill
TW0P0INTSL0W is offline   Reply With Quote
Old 05-28-2013, 03:50 AM   #4
BeardedShogun
Member#: 354456
Just moving.
Old 05-28-2013, 03:52 AM   #5
rob1n1
Member#: 276425
2013 335is
Alpine White
It could be that your AP is in Valet Mode.
See a related thread here: http://forums.nasioc.com/forums/showthread.php?t=542173
You're going to want to look in the AP manual for instructions on how to turn it off or make sure it's off.
rob1n1 is offline   Reply With Quote
Old 05-28-2013, 04:01 AM   #6
BeardedShogun
Member#: 354456
Will definitely try that.
Thanks for the suggestion.
Old 05-28-2013, 08:16 AM   #7
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
What does your AP say max boost is when you hit the cut at 4000?
Cathexis is offline   Reply With Quote
Old 05-28-2013, 08:56 PM   #8
Haelan
Member#: 151045
2013 Subaru STI
CBP
Shot in the dark, but the green test connectors need to be disconnected when you're done flashing with the AP.
Haelan is offline   Reply With Quote
Old 05-28-2013, 09:14 PM   #9
nsbat7
Member#: 150973
2007 STI
Blue / Gold
check your food down shift setting on your AP...
nsbat7 is offline   Reply With Quote
Old 05-28-2013, 09:17 PM   #10
nsbat7
Member#: 150973
2007 STI
Blue / Gold
if is doing it with the clutch down only...
Old 06-06-2013, 04:18 PM   #11
BeardedShogun
Member#: 354456
quick update:
tried cleaning the fuel systems/injectors, no luck there
updated my AP, flashed, and reflashed, no luck
cleaned MAF sensor, still won't let me rev past, and still have hesitation.
next step: replacing and cleaning spark plugs and injectors, anyone who's had this problem it'd be great if you could chime in to let me know I'm on the right track.
Thanks to everyone
Old 06-06-2013, 06:46 PM   #12
TW0P0INTSL0W
Member#: 305392
2002 WRX Wagon
Originally Posted by BeardedShogun View Post
quick update:
Thanks to everyone
Check the green test connectors before you do the injectors and spark plugs. Try checking all hoses in the intake tract. I had a tmic hose loose and id cut out at 4000. One day it popped off. Got it back on and never had the problem again.
Old 06-06-2013, 07:14 PM   #13
s0ber_p
Member#: 172689
2004 WRX
quick update:
Thanks to everyone
CEL, flashing or otherwise?
s0ber_p is offline   Reply With Quote
Old 06-06-2013, 10:26 PM   #14
coalslaw
Member#: 324808
2006 IWL Stg2
only common flashin cruise light wud be p2443 for hwkE
flashing CEL is serious trobel
+1 valet mode
+1 re do green connector test. windows closed doors closed when flashing
coalslaw is offline   Reply With Quote
Old 06-07-2013, 09:18 PM   #15
BeardedShogun
Member#: 354456
No CEL flashing.
Which only helps to add to the frustration haha.
Old 06-07-2013, 11:27 PM   #16
VictorOfHavoc
Member#: 341994
2010 Wrex
No CEL flashing.
Did you ever get a chance to check those green test connectors people mentioned? I had an issue and it was related to my flat foot shift rpm being too close to my launch control rpm...try setting lc to 4500 and ffs to 5500 and see what happens. Then again I'm open source so it might be different...But when I did set them both above redline it kept happening...
VictorOfHavoc is offline   Reply With Quote
Old 06-09-2013, 02:07 AM   #17
BeardedShogun
Member#: 354456
I did.
My test connectors are always unplugged when not flashing maps.
Old 06-09-2013, 02:14 AM   #18
VictorOfHavoc
Member#: 341994
2010 Wrex
I did.
good good. Did you try what I mentioned with ffs and lc? my car/ecu is newer so it might be different but it might be causing the issue...
Old 06-09-2013, 08:47 AM   #19
STIBungy
Member#: 51684
If its starting to hesitate before 4k, then its not an issue with connectors, ffs, lc, etc. Find someone with a wideband and/or datalogger.
STIBungy is offline   Reply With Quote
Old 06-09-2013, 05:22 PM   #20
danger1138
Member#: 279525
04 rex luger!
I got that symptom when my intercooler coupler popped off the throttle body. Check that out if u haven't already.
danger1138 is offline   Reply With Quote
Old 06-10-2013, 02:03 AM   #21
BeardedShogun
Member#: 354456
I did. No luck there.
Tomorrow I'm going to log it with my AP when I get out of class, probably something I should have done in the beginning, hopefully that'll clear up what I need to do.
I appreciate everyone's help again!
Keep the suggestions coming, they may mean more to me than you think
Old 06-10-2013, 08:22 AM   #22
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Upload log to google docs, make public, and post link here.
Old 06-12-2013, 01:24 AM   #23
BeardedShogun
Member#: 354456
Here it is.
Bear with me, I'm pretty sure log would need more paremeters, etc.
https://docs.google.com/spreadsheet/...EE&usp=sharing
Old 06-12-2013, 12:50 PM   #24
sc00ter
Member#: 117767
2015 WRX
CWP
According to those logs your RPM's are getting well past 4K (up to like 5800rpm before you let off the throttle). What's really concerning is that you are hitting boost of up to 23psi. If your mod list is correct and you are running a stock or stage 1 tune with the TD04 then you are WAY overboosting.
Are you 100% positive of your current mod list? Especially the turbo?
sc00ter is offline   Reply With Quote
Old 06-12-2013, 01:23 PM   #25
BeardedShogun
Member#: 354456
The RPM wall per say is never one strict number, sometimes I'd hit it at 4k sometimes 5k
But one thing for sure I'd get plenty of hesitation along the way.
And yes. I'm positive on that. The car is completely stock aside from the stage 1 ots map and a Cobb sf intake.
If I'm overboosting that's news to me. :/
