Old 09-25-2002, 10:32 AM   #1
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Default Road Dyno runs after tuning...
Well, I've been doing quite a bit of work in preparation for going turbo, which includes installing and tuning a Haltech E6K. I've been learning to tune it while NA, and thought I'd share my recent Road Dyno runs with you all.
http://8complex.com/rdruns/index.html
Previous to the Haltech, I was pulling about 130ft.lbs of torque and 118hp. I will try and get some of those charts up on that page outlining my mods and all as well.
The main thing I'm trying to point out is how flat the torque curve is, and for that matter, just how much hp is lost over the 6000rpm mark. I'm revving to 6800 currently and the only thing that is nice about it is that I don't have to shift as often.
8Complex is offline   Reply With Quote
Old 09-25-2002, 02:25 PM   #2
Section 8
Member#: 821
Hey Nick,
Were you farting around with the maps between runs, were those vaiations in the curves due to road conditions (different places) or is that just the reproduceability with the road dyno?
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 09-26-2002, 09:47 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I believe those two low runs were from a small section of the road that was heading slightly uphill. It's hard to find a good, flat road around here... despite the lack of hills in IL.
Old 09-26-2002, 09:59 AM   #4
Section 8
Member#: 821
Then add in a road that is free of the cars with special vinal graphics that you don't want to go speeding past and it gets that much harder.
What did you find was most diffacult part of the Haltech tune?
cheeRS,
Greg
Old 09-30-2002, 01:52 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The most difficult part of the Haltech tune has to be the fact that I didn't have an O2 sensor for the first 3 weeks running it, so it was like tuning in the dark. Oddly enough, I got the fueling pretty close, all things considered.
After getting the O2 in, it was just a matter of running and tweaking repeatedly. The timing map needed adjustment as I took it off some OBD-II logs and went from there.
Really though, I found it pretty easy to tune all around. I suppose the most tricky part of it has to be the correction maps -- I was tuning the main map, so the correction maps come into play at other, less controlable times. It's easy to keep the car at full operating temperature, but tough to keep it at cold start type temperatures.
DeltaDash, Road Dyno, Datalogging, Live User Tuning 02-03 $150 shipped wrxtool Engine/Power/Exhaust 10 04-13-2008 10:56 AM
New Dyno sheet after tune from Phil dunk Mid Atlantic Impreza Club -- MAIC 17 01-09-2006 10:38 AM
Any positive 1/4mi, Auto x, Road Race, Dyno Runs on an STi with AP tuning?? BigJ04STi Engine Management & Tuning 0 01-07-2005 01:49 AM
STI Accessport, 2nd Dyno run after 2 weeks of ECU learning finger123 Engine Management & Tuning 17 06-27-2004 04:29 PM
