Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 06-03-2013, 03:36 AM   #1
Jaytronzero
Member#: 356590
2002 WRX Wagon
Default Tires for a 9.5in rim
What size tire is "supposed" to be on a 9.5in wheel?
255 looks like it's a little stretch. Would I be able to fit 275's on a 17x9.5 in wheel with +38 offset? (2002 wagon)
Jaytronzero is offline   Reply With Quote
Old 06-03-2013, 03:50 AM   #2
Jaytronzero
Member#: 356590
2002 WRX Wagon
Disregard.. Direzza ZII largest width are 255 for 17s
Old 06-03-2013, 04:12 AM   #3
Jaytronzero
Member#: 356590
2002 WRX Wagon
Upon further research... I don't think a wagon could even fit a 9.5 wheel with a +38 offset :|
Old 06-03-2013, 04:48 AM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
not without cutting the fenders
anything bigger than 17x8 with a 235/40 will be problematic
Old 06-03-2013, 04:55 AM   #5
Jaytronzero
Member#: 356590
2002 WRX Wagon
Yeah, I've spent the past hour looking around.
If I want to run a 17x9, I need to either:
Stretch a bunch (no point in getting a 9in rim)
Run a ton of camber (meh)
So I think I'll try and go with 17x8, I want to get a decent amount of meat on my tires.
Old 06-03-2013, 06:42 AM   #6
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
dont try a 235/45...its gonna be too tall
Old 06-03-2013, 12:33 PM   #7
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
yup everyone knows that too tall = a blowed up car right? stop spouting fear mongering, Cupcake
235/45 is stock size on the 2011+ which has the same gearing. it wont hurt anything. if he wants to run that size for his own reasons, there's no reason he CANT. hell i run a 26" tire for my winter setup and its AWESOME.
gsrcrxsi is offline   Reply With Quote
Old 06-03-2013, 04:01 PM   #8
GenericWagon
Member#: 197386
2003 WRX Wagon
Sonic Yellow
18x8.5 or 17x8.5 et48 with 245/40/18(17) works for me. Fenders rolled and pulled, -1.75 front, -1.3 rear camber.
I know you know this Jesse, but figured I put it down for others.
boop.
GenericWagon is offline   Reply With Quote
Old 06-03-2013, 06:41 PM   #9
Mach V Dan
Member#: 12029
17x9 +42 with 255/40R17. Coilovers, camber, and rolled fenders.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 06-03-2013, 07:14 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
dont think the op d00000d is gonna wanna do all that
Old 06-03-2013, 07:16 PM   #11
Jaytronzero
Member#: 356590
2002 WRX Wagon
--Dan
Mach V
FastWRX.com
I saw that when searching.
My question regarding that car is, if it were lowered another inch or two, would the tire still clear the fender or would you then have rubbing issues?
Old 06-03-2013, 07:16 PM   #12
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
--Dan
Mach V
FastWRX.com
and that looks dumb as hell like that
and must be stiff as a stone not to rub badly
no thanks
maybe the OP HAS a brain in his head and it just isnt full of kiddie f00-f00
Old 06-03-2013, 07:32 PM   #13
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Cupcake, the fenders are rolled and camber added to not rub. Plus there's plenty of space for travel before any hypothetical contact. I highly doubt it's "stiff as a stone"
My 450lb springs on my Feal 441 coilovers are actually quite comfortable. And anyone with the setup will agree with that.
Just because its not 225/45/17 RSRs, doesn't make it bad. Nor is everyone driving on the dirt roads that you CLAIM to drive on. Get yer head outta yer bunghole.
Old 06-03-2013, 07:37 PM   #14
Jaytronzero
Member#: 356590
2002 WRX Wagon
This thread is getting good.
gsrcrxsi, do you have a wagon as well? (Just trying to see more setups)
Old 06-03-2013, 07:42 PM   #15
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
I have a 2010 hatch as per my profile.
You can look up my setup, and it is slightly similar as far as difficulty as fitment but it doesn't exactly translate.
Old 06-03-2013, 08:00 PM   #16
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
kiddie boiz like you doin it all wrong are the ones who need to stop doin that thinkin ya all k00 an ****
and my current jobsite is ONLY 2.5 miles off pavement
Old 06-03-2013, 08:19 PM   #17
Jaytronzero
Member#: 356590
2002 WRX Wagon
Ah, I was hoping you had a wagon too or something
Old 06-04-2013, 03:33 PM   #18
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
here man:
http://forums.nasioc.com/forums/show...postcount=1122
lots of useful info for you there it seems
Old 06-04-2013, 03:35 PM   #19
sc00by4life
Member#: 97135
its going to be extremely hard to fit that much meat properly on a wagon....
in all reality, that is far too big of a wheel if you want as much rubber as you can functionally get on the road.
Old 06-06-2013, 11:19 AM   #20
96max2fast
Member#: 252910
On this same note, I bought Rota Grid 18x9.5 and I wanted to know if they will fit on my 07 STi sedan (no drop) w/ 255-40-18's ... Otherwise, I will get other size tires?
Opinions will be greatly appreciated...
96max2fast is offline   Reply With Quote
Old 06-06-2013, 12:45 PM   #21
Jaytronzero
Member#: 356590
2002 WRX Wagon
If you have no drop, I don't think it really matters?
Old 06-06-2013, 02:04 PM   #22
JonnyV2889
Member#: 197384
2006 WRX Ltd
Offset would help...
For insight had 18x9's +29 advan 235/40/18 on my previous 07 required a good amount of fender work in the rear.
JonnyV2889 is offline   Reply With Quote
Old 06-06-2013, 03:56 PM   #23
sc00by4life
Member#: 97135
No those wont fit. Yes, you'll need smaller tires. Yes, that will look rediculously wierd at stock height.
yep, still matters.
Old 06-18-2013, 01:11 PM   #24
96max2fast
Member#: 252910
I put 245-40-18's on 18x9.5 rota grids (w/ 5mm spacers all around). Front seems fine. Rears rub on hard cornering and when car is loaded. I'm have all four fenders roll to avoid issues and to prepare for future coilovers..
