Old 06-05-2013, 11:02 AM   #1
brasstacks
Member#: 321391
Default Super laggy 18G ?!?
When does peak boost occur for a TD06SL2 18g 8cm. I just installed mine last week and got it tuned. It runs really well, but the lag seemed very high. I got an 18g instead of the 20 because I was afraid of lag.
Did some data logging and I hit 24psi @ 4800rpm. That seems really high amirite?!
My Setup
TD06SL2 18g 8cm
Perrin SRI
3in Turbo Back Exhaust
Front Mount intercooler
Tial 50mm BOV
Prodrive 3 Port Boost Solenoid
Walbro 255
1000cc injectors
Rebuilt Head with All New Valves, 3 Angle Valve Job
TGV Delelets
8mm GS Phenolic Spacers
brasstacks is offline   Reply With Quote
Old 06-05-2013, 12:23 PM   #2
tuzzio
Member#: 292532
05 STI
Sounds pretty high, that's a big number though
tuzzio is offline   Reply With Quote
Old 06-05-2013, 12:23 PM   #3
Spiffy07
Member#: 287105
2007 WRX TR
Urban Gray Metallic
it does seem a bit high. With my Blouch TD06H-20GXT Billet 8cm^2 i hit 23psi at 4300rpm. I have similar mods on my 07 wrx. I kept the stock air box and stock BPV however. Also, i have a PW TMIC instead of a FMIC.
Did you replace the inlet with something larger than stock plastic one? Other than that the only other thing i can think of is that you are seeing a large pressure drop through your pipes and across your FMIC. Turbo needs to work harder to get your 24 psi to the engine so it hits a later RPM. just a guess.
Spiffy07 is offline   Reply With Quote
Old 06-05-2013, 12:41 PM   #4
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Already checked for pre turbo exhaust leaks? Already checked for boost leaks?
dstroy is offline   Reply With Quote
Old 06-05-2013, 01:14 PM   #5
brasstacks
Member#: 321391
Ill be doing that tonight. Hopefully i can find a big nasty leak that solves all my problems
Old 06-05-2013, 01:22 PM   #6
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
It doesn't seem that late to me. It's a TD06. Plus, it's a smaller compressor than the 20g. Also, you have the front mount slowing things down even more.
guroove is offline   Reply With Quote
Old 06-05-2013, 01:45 PM   #7
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Definitely slow spool, even for a FMIC... let us know how the boost leak test goes.
Mr Wrex is offline   Reply With Quote
Old 06-05-2013, 02:05 PM   #8
lovethebugeye
Member#: 116929
2008 :shifty eyes:
That's even laggier than my rotated bw 7670 with an fmic.
Gotta be something up...
lovethebugeye is offline   Reply With Quote
Old 06-05-2013, 02:24 PM   #9
guroove
Member#: 129833
2005 Forester XT
How much boost are you making at 3,000 rpm?
Old 06-05-2013, 02:30 PM   #10
abrumlev
Member#: 197920
2005 Legacy GT
ABP
Who tuned it?
abrumlev is offline   Reply With Quote
Old 06-05-2013, 02:42 PM   #11
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
Im curious if the tuner just tuned it like a regular 18g, ive plenty of local tuners yet i still have to go elsewhere.
dingobite is offline   Reply With Quote
Old 06-05-2013, 02:46 PM   #12
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
When you run a hot side that big on a 1 liter 3 cylinder what do you expect.....Fill out your profile!
TD06SL is a pretty big hot side, big effect on spool.
18G cold side, well with the same hot side I doubt it is hardly any different than a TD06SL-20G or any other TD06SL when it comes to spool. I am sure there is an advantage to a smaller cold side IRT spool, but the big hot side is surely what is killing your spool.
Of course, the above assumes there is nothing wrong with your car / setup. Likely there is something wrong though since spool is so slow.
jebjkey is offline   Reply With Quote
Old 06-05-2013, 02:50 PM   #13
GulfCoastMotorworks
Member#: 358317
6266 Built Bugeye
GulfCoastMotorWorks.com
Most likely WGDC cycles are lethargic, pre-turbo exhaust leak, or the WG assembly is leaking.
That is way way way laggy. Most should have a TD06-20g's in the 3400-3900 range depending on model.
A PTE-6262 or HTA86 spools faster than that.
GulfCoastMotorworks is offline   Reply With Quote
Old 06-05-2013, 02:58 PM   #14
Spiffy07
Member#: 287105
2007 WRX TR
Urban Gray Metallic
your altitude will have an effect on how quickly you spool as well. I'm at 4,327 feet above sea lvl. My 20G would spool a lot faster if i drove the car to say California.
Old 06-05-2013, 03:37 PM   #15
GulfCoastMotorworks
Member#: 358317
6266 Built Bugeye
Yeah but 4800 for a 18g.... is ridiculous at any altitude.
/Drunkmann Tuning
Old 06-06-2013, 09:02 PM   #16
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Greddy 18g. Hits at 3400 on a perrin fmic
cosseywrx is offline   Reply With Quote
Old 06-07-2013, 03:35 PM   #17
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
My td06sl2 20g 8cm will hit 24 psi by 3900-4200rpm depending on the gear and temp so I would think 4800 is a little high.
nate_fisher is offline   Reply With Quote
Old 06-12-2013, 12:39 PM   #18
brasstacks
Member#: 321391
hnnnnggg. Brought it back to my tuner (NF Performance - FuJi k and Nuke209) . No exhaust leak, no boost leak. We played with the waste gate and the duty cycle. Nothing.
Did a couple of runs and my tuner keeps telling me that it does not feel like any 18g he has ever tuned. Its defiantly fast.. I dont have any qualms about the power, but that lagggg.
My tuner says its got exceptional top end for an 18g. The label on the turbo def says tdo6sl2 18g though. Baffled to say the least.
Old 06-12-2013, 12:54 PM   #19
guroove
Member#: 129833
2005 Forester XT
Post up a dyno chart. 24 psi @ 4800 rpm isn't laggy if you're making > 17 psi @ 3000 rpm. Also, has your tuner tuned a TD06sl2 before? It's quite different from a TD05h, which is what most people are talking about when they say 18g.
Old 06-12-2013, 12:57 PM   #20
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
What brand turbo? I don't think I see you've mentioned that.
findurpath is offline   Reply With Quote
Old 06-12-2013, 01:01 PM   #21
brasstacks
Member#: 321391
Kinugawa tdo6sl2 18g.
Yes he has tuned this exact turbo and tdo6sl2 20g's before. Ill get a datalog up when I get home.
Old 06-13-2013, 12:22 AM   #22
brasstacks
Member#: 321391
Old 06-14-2013, 03:13 PM   #23
brasstacks
Member#: 321391
nobody eh?
Old 06-14-2013, 03:39 PM   #24
guroove
Member#: 129833
2005 Forester XT
I think everything was covered in this post.
Old 06-14-2013, 03:41 PM   #25
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
PM gabedude he is extremely knowledgeable about kinugawa/turbos .
hopefully he isn't to busy to help you . good luck .
tekfoc is offline   Reply With Quote
