Old 06-05-2013, 06:54 PM   #1
sc00ter
Member#: 117767
2015 WRX (CWP)
3" TBE | DT Flex Fuel
Default Rubbing/scraping noise from rear wheel or brakes.
I cannot seem to find a solid answer for the problem I'm experiencing so I figured I'd post.
When I am slowly accelerating from a stop or coasting at low speeds (5-15mph) there is a rubbing noise coming from what appears to be the rear right side of the car. The noise has gotten noticeably louder over the past 5k miles or so. It also only happens when the brakes are NOT applied. If the rubbing/scraping noise is occurring, gently stepping on the brakes stops the noise. As soon as I let off the brakes the noise comes back. The noise also occurs just the same whether I'm going straight or turning.
Initially I thought it was my brake pads. However, I recently (within the last 500 miles) replaced my brake pads with new Hawk HPS pads. Since doing this the noise has remained consistent to how it was before the brake pad change. I'm pretty stumped right now and wanted to post to see if anyone had any insight on the issue.
I did a little research and came across a couple threads saying that it might be a bent dust shield rubbing against the rotor. However, this wouldn't explain why the scraping noise goes away as soon as I touch the brakes, would it?
Any ideas?
sc00ter is offline   Reply With Quote
Old 06-05-2013, 07:28 PM   #2
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
i came in with the dust shield suggestion, but...
can you put it up on jackstands and stick it in gear?
mechatricity is offline   Reply With Quote
Old 06-05-2013, 07:39 PM   #3
sc00ter
Member#: 117767
2015 WRX (CWP)
I can do that. What would I be looking for?
Old 06-05-2013, 08:54 PM   #4
uneekvisions
Member#: 157958
2006 STi
Obsidian Black Pearl
I remember reading this would happen if the pads were installed backwards, seemed to be a common issue with the dealer. Hope this helps.
uneekvisions is offline   Reply With Quote
Old 06-05-2013, 11:12 PM   #5
sszyma
Member#: 31399
2007 WRX
2014 Forester 6MT
Although you car isn't that old it is very common for the backing plates to rust. The rust pushes the lip of plate for the ebrake assembly into the groove on the rotor. Take off the rotor and look for shiny spot where the inner diameter of the rotor contacts the backing plate.
sszyma is offline   Reply With Quote
Old 06-06-2013, 12:42 AM   #6
sc00ter
Member#: 117767
2015 WRX (CWP)
But wouldn't it keep rubbing even when the brakes are applied? And wouldn't it be more persistent. The occurrence of the noise is sporadic.
This weekend I'll get the car on the lift and start digging around. I'm hoping it's something simply like the dust plate.
Old 06-20-2013, 12:46 AM   #7
Cupofnoodles
Member#: 352574
02 WRX
It wouldn't be hard to find out if its the dust plate. You would be able to see where its rubbing, look for fresh metal on the plate. If there is,they are very easy to bend back or "adjust" to where it wouldn't rub/hit (if that is the problem). Process of elimination one step at a time.
Cupofnoodles is offline   Reply With Quote
Old 06-20-2013, 06:36 AM   #8
BURNING4ORCE
Member#: 356215
Sounds like the dust plate but check all the bolts on the brakes/suspension on the suspect area.
BURNING4ORCE is offline   Reply With Quote
Old 06-20-2013, 10:49 AM   #9
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
Drive 10 mph and pull on the hand brake. Does the noise go away?
CRAZYHAWK is offline   Reply With Quote
Old 06-20-2013, 11:47 AM   #10
leecea
Member#: 37359
2003 WRX
Did you check the sliding pins are not stuck?
leecea is offline   Reply With Quote
Old 06-22-2013, 12:14 AM   #11
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
No actually...when you hit the brakes you torque on the backing plate slightly and the tolerance of what we're talking about is less than slightly... I just had this issue and it was pretty bad.. had to take a side grinder to it
Pull the rotor and look, its easy..
