Old 07-01-2014, 12:37 PM   #626
blknylw
Member#: 381455
So would the sharper cutoff mean brighter lights and/or being able to see further and wider?
blknylw is offline   Reply With Quote
Old 07-01-2014, 01:46 PM   #627
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
The output is going to be a little better, but mostly people opt for the clear lens for the purple/blue "flicker" at the top of the cutoff.
http://www.theretrofitsource.com/com...l#.U7Lzs41dU3Y
bicycle_wreck is offline   Reply With Quote
Old 07-01-2014, 04:04 PM   #628
Nikopotomus
Member#: 297499
2011 WRX
For the chrome ring section, do you tape off and only paint the chrome part, or do you paint the entire plastic piece?
Nikopotomus is offline   Reply With Quote
Old 07-02-2014, 12:18 AM   #629
bshearman
Member#: 336446
2012 5 Door WRX
I taped off what I did not want painted but there are many ways to achieve the same results. Mine wasn't the cleanest but it was simple.
bshearman is offline   Reply With Quote
Old 07-03-2014, 12:57 PM   #630
blknylw
Member#: 381455
Great! Thanks for the explanation
Old 07-03-2014, 10:08 PM   #631
bobbygoss
Member#: 382241
I just baked my headlights in a similar fashion, same paint....mostly same result EXCEPT I cracked my headlight lens. It is about an inch long on the corner of the headlight. Can it be fixed or do I have to get a new headlight?
bobbygoss is offline   Reply With Quote
Old 07-03-2014, 10:26 PM   #632
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
Dude, what happened?!?
Unfortunately you can't purchase just a lens but you can purchase a stripped housing for about half the cost of a full headlight. That or get a used light off eBay. I don't recommended non oem housings/lenses, their quality and scratch resistance is way less than the subaru branded ones.
Overland04 is offline   Reply With Quote
Old 07-04-2014, 02:08 AM   #633
cmiller219
Member#: 187179
Chapter/Region: HIIC
14 STi
Cocain
Can someone tell me the benefits of the TSX-R Clear Lens swap if I already have factory HID's?
do it i love it. Sharper cutoff, better light output, sharper color, and further range. At least from what I can tell on mine.
cmiller219 is offline   Reply With Quote
Old 07-06-2014, 12:44 PM   #634
Overland04
Member#: 293311
2013 FXT 6-Speed
Some sick lights coming down the pipe this week!
Here's a members black housing, smoked reflectors, and red demon eyed monsters!
Old 07-06-2014, 01:01 PM   #635
komuso
Member#: 373174
2015 STi
Dark Gray Metallic
What creates the red in the demon eye? Does it cast any red light?
komuso is offline   Reply With Quote
Old 07-06-2014, 01:20 PM   #636
Overland04
Member#: 293311
2013 FXT 6-Speed
Demons, of coarse!
It's done by painting the backside of the cut-off shield. If done correctly, there is no red visible light output at all.
Old 07-06-2014, 01:30 PM   #637
Nikopotomus
Member#: 297499
2011 WRX
Hmm, I bought the vled along with a relay. I have the amber only. I forget, does our cars always have them emit light when headlights are on?
Also, only thing I don't like is that when I signal, it takes about a second before it starts flashing. Anyone else experience this issues? I imagine the higher resistance relay does this but it just is somewhat annoying.
I wonder if it's because my rear signals are still the factory bulb and not led. Anyone have input, please? Thanks thanks overland for the guidance with mine. Pics to follow soon
Old 07-06-2014, 01:34 PM   #638
Overland04
Member#: 293311
2013 FXT 6-Speed
Originally Posted by Nikopotomus View Post
Hmm, I bought the vled along with a relay. I have the amber only. I forget, does our cars always have them emit light when headlights are on? Also, only thing I don't like is that when I signal, it takes about a second before it starts flashing. Anyone else experience this issues? I imagine the higher resistance relay does this but it just is somewhat annoying. I wonder if it's because my rear signals are still the factory bulb and not led. Anyone have input, please? Thanks thanks overland for the guidance with mine. Pics to follow soon
Yes the parking lights come on with the headlights always and then the turn signal activates when you use it.
Did you get the relay from VLED or is you get one from Amazon (or equal)?
The ones I get from VLED usually don't delay even with halogen rear bulbs. The ones from Amazon or other Toyota LED relays usually delay or hold the flash for a second.
Old 07-07-2014, 02:47 PM   #639
Nikopotomus
Member#: 297499
2011 WRX
Ok thank you!
Yeah it is off amazon.. I believe I followed a link that someone had posted in this thread. It's not a huge deal, but if it's a cheap fix maybe I'll look into it. Just buy the one off VLED, then?
Old 07-07-2014, 03:09 PM   #640
Overland04
Member#: 293311
2013 FXT 6-Speed
Ok thank you! Yeah it is off amazon.. I believe I followed a link that someone had posted in this thread. It's not a huge deal, but if it's a cheap fix maybe I'll look into it. Just buy the one off VLED, then?
Yeah, the VLED one works great.
The amazon link may have been mine, lol
The reason I know about the delay is I had one for a little bit and it annoyed the crap out of me.
Old 07-08-2014, 10:15 PM   #641
VEGAS WRX
Member#: 362867
2013 WRX
Posting for reference when I have time. Thanks for the write up.
VEGAS WRX is offline   Reply With Quote
Old 07-09-2014, 03:50 PM   #642
Phill0406
Member#: 317275
2011 WRX
Without opening a huge can of worms, in theory could you just swap the lenses, then put an HID kit in and be okay? I know there's a lot of talk about the fresnel lenses and the glare they give.
Phill0406 is offline   Reply With Quote
Old 07-09-2014, 04:20 PM   #643
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
No. The fresnel lenses in the halogen projectors are identical to those in the HID projectors. The lens holders are also identical. Same part numbers.
The major differences are in the projector bowl and cutoff shield.
Don't do it if you're just going to drop a PnP HID kit in there.
As much trouble as it is to open the headlights up to that point, you might as well stick a couple of decent projectors in there and go full HID retrofit.
Old 07-10-2014, 08:22 AM   #644
kdizz781
Member#: 340925
2013 WRX sedan
Dark Gray Metallic
So I have been waiting for Amazon to restock this for about 1.5 months
Rust-Oleum Automotive 260770 12-Ounce Paint For Plastic Spray, Satin Black
http://www.amazon.com/gp/product/B006ZLR3OE/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1http://www.amazon.com/gp/product/B006ZLR3OE/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
No luck and it doesnt look like it is coming in any time soon, can't find it in any stores either.
Has anyone used this?
Krylon 2421 Fusion Spray Paint, Satin Black:
http://www.amazon.com/gp/product/B000C0158E/ref=pe_62810_120821040_em_1p_2_tihttp://www.amazon.com/gp/product/B000C0158E/ref=pe_62810_120821040_em_1p_2_ti
Thanks for the feedback!
kdizz781 is offline   Reply With Quote
Old 07-10-2014, 08:47 AM   #645
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
That Krylon should work just fine.
Old 07-10-2014, 09:16 AM   #646
arani rey
Member#: 346176
I used Krylon for mine.... start with VERY light coats and also I would take some fine grit and go around the projector bezel a little. We did two sets at once and the one with sanding was easier to paint, but they came out looking the about same.
arani rey is offline   Reply With Quote
Old 07-10-2014, 09:50 AM   #647
Phill0406
Member#: 317275
2011 WRX
Thank you!
I'll put this project on the back burner until I do a full retrofit then. Much appreciated.
Old 07-14-2014, 07:29 PM   #648
Overland04
Member#: 293311
2013 FXT 6-Speed
A pair of TSX lenses in these baby's!
Old 07-15-2014, 03:36 AM   #649
NKBRKR
Member#: 228733
11' LR WRX Sedan
07' GMC Sierra blacked
Pics of the red demon eyes installed on the car. Also can you Pm me a price quote on em for my 11' wrx
NKBRKR is offline   Reply With Quote
Old 07-17-2014, 10:47 AM   #650
05wrxdude
Member#: 284904
2014 Wrx
Wrb
I actually stumbled on an issue I can't find on here or anywhere for that matter, I split and blacked out my housings well the next day after putting it back together I found what I thought was fog on the lens but it was almost 100 degrees here and in the 90s since so it didn't make sense. A friend said it looks like an off gassing but I used nothing but paint on the housings I didn't bake I used a heat gun. So I re split to try to wipe it off and it won't come off with a rag and alcohol. It's about the size of a quarter and the other has one about the size of a dime. has anyone ever seen or had this issue? Could the lens have oxidized from heat? Maybe polishing compound or headlight restore May clear it out?
05wrxdude is offline   Reply With Quote
