Old 06-07-2013, 03:30 PM   #1
skep18
Member#: 214971
2014 WRX
Default Tire Advice (Autocross ONLY, Driven to/from Track)
So, I've got a dedicated track vehicle for which I need some tires, and therefore some advice from experienced members here.
Historically, I've driven my DD at AutoX. I have an extra set of wheels I've used, and typically put them on Friday, run them at AutoX Saturday and Sunday, and take them off Sunday night. On these wheels, I've been running BFGoodrich g-Force T/A KDW 2's. I've been happy with their performance and longevity(1.5 - 2 seasons), everything considered, and am thinking of getting them for this car. But I wanted to see if anyone else know of something better.
I am looking for some awesome performance given ~$160/tire or so while not having tires that wear so fast that I'll need an extra set just to get me to/from the track which is 30 minutes away.
If I'm leaving out information needed, please feel free to ask. Thanks in advance for your kind advice.
EDIT: I will be using the STI BBS wheels.
skep18 is offline   Reply With Quote
Old 06-07-2013, 04:11 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Well you left out the tire and wheel size, which is a pretty important factor to price.
There are three popular "top tier" autox tires right now that I'm aware of:
Dunlop ZII -- good cold grip, but will overheat if pushed HARD. This is a problem on some autox courses and surfaces, but not a problem at others, depends on the course and driver and possibly some on the weather. It's a good DD tire with decent traction through standing water. questionable for an HDPE where the longer sessions will usually have these tires over their comfortable temp and longevity and performance will start falling off quickly.
BFG Rival -- better communication of the limit than the ZII, handles heat better than the ZII, but has abysmal standing water performance. This makes it a poor choice for something you'd daily drive, but a good tire for a dedicated set of autox / HDPE wheels. It's a new tire so longevity is not too well known, but it should hold up similar to the KDWs.
Hankook RS3 -- not so good cold, picks up grip when warm and handles heat better than ZII. Decent with standing water. autox performance may be slightly hurt by needing some warm up, but this works well at the higher temps seen at longer sessions seen in HDPEs.
Anyone doing anything less than shooting for nationals should consider these equal in performance. Choose based on the other factors. ZII is more flexible for rain and colder temps and is the de-facto standard for an autocross tire that will be daily driven, good for those with moderate skill since they work well cold and are good enough in the wet to not be scary to daily. Rival is a good choice for a dedicated track set of wheels, it's main weakness is wet performance, so this is probably your best choice. RS3 might be a little cheaper, depending on size so may be in the running if you run HDPE sessions on the wheels or you see a lot of wet autocross days.
Concillian is offline   Reply With Quote
Old 06-07-2013, 04:44 PM   #3
skep18
Member#: 214971
2014 WRX
Wow. Great response. Thanks!
I didn't even notice the BFG Rivals before when looking on TireRack. Seems like a nice tire. Asymmetrical, so I might not be able to have them remounted to use the outside for longer use. However, how do you think these would compare to the KDW's I'm used to?
Thanks again! Leaning towards the Rivals.
Old 06-07-2013, 04:51 PM   #4
skep18
Member#: 214971
2014 WRX
Looks like the BFG KDW's have a treadwear rating of 300 while the Rivals have a rating of 200. So I suppose that means they'll wear out a bit faster. But maybe worth it for the performance upgrade?
The hope is evetually these wheels will be the wheels that take me to/from the track and I can get another set of rims/tires to change into. So longevity matters to me some...
Old 06-07-2013, 05:00 PM   #5
skep18
Member#: 214971
2014 WRX
Found a great link describing the Rivals. Helpful. Probably going to choose these, however anymore advice out there is definitely appreciated.
Let me put it this way: BFGoodrich's pure competition tire, the R1 and their street tire, the G-Force Comp-2, loved each other very much. When the stork finally arrived, they named it Rival, and found that they had a child who was greater than the sum of its parents. And what a cute kid it is...
The G-Force Rival is built to fill a highly specific niche. While the R1 is a very well-regarded competition tire and the Comp-2 sits atop Tire Rack's customer surveys for UHP street tires, the Rival aims to be the best of both worlds. It's made to be a superior track tire that can still be driven to and from the track. This track/street hybrid goes along nicely with BFG's own battlecry, “If it's paved, we own it.”
Review: BFGoodrich G-Force Rival
Old 06-07-2013, 05:25 PM   #6
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
A few things to note:
On the rivals, the tread depth is 7.2/32". It's been said that the Rival is somewhat resistant to wear, but at that low tread depth it may not make a difference. I'm not aware how many runs people are getting out of a set.
Of the 3, the RS3 has the deepest tread depth at 8.8/32". (Z2 is 8/32")
If your region is typically very hot/dry (100+ degrees) in the summer months, I would choose the RS3 as it will handle the heat better.
If your region gets a LOT of rain, do the Z2.
This is assuming 225/45/17 for all. You could probably get away with 245/40 on the Rival and Z2, but not on the RS3 due to its softer sidewall.
T-37 is offline   Reply With Quote
Old 06-07-2013, 05:52 PM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I wouldn't put too much stock in treadwear ratings meaning much when the primary usage is track / autocross. They barely mean much for street driving.
I don't really have anything more on that, the Rival is too new to really have any strong impressions on how long they'll last.
Old 06-08-2013, 04:42 AM   #8
RandR
Member#: 292132
2016 Cayman GTS
Racing Yellow
There is a broad correlation between tread wear rating and coefficient of friction. Anything with a rating of ~ 100 - 180 will likely be very good tire in the dry and far superior to anything with a rating of 300.
Broadly speaking
semi slick rating ~ 50
high performance street/crossover ~ 100 to 180
high performance all round ~ 200 to 260
long life daily ~ 300
If you want a top level street/ crossover tire try the newly released ADVAN AD08 R
RandR is offline   Reply With Quote
Old 06-08-2013, 10:21 AM   #9
gixxer7fiddy
Member#: 203474
2005 STU STi #46
Broadly speaking
Except we won't get the that Advan for a while if ever
gixxer7fiddy is offline   Reply With Quote
Old 06-08-2013, 11:47 AM   #10
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
Broadly speaking
Except that the SCCA street tire minimim TW has been bumped from 140 to 200. If you want a "fast" autocross street tire, it should have 200 on the sidewall.
Old 06-08-2013, 12:41 PM   #11
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
There's a good article on tirerack about asymmetric treads and traction. Read the whole thing, but basically it boiled down to "tread direction has no effect at all on traction in the dry. And not very much in the wet."
So remounting them shouldn't be an issue at all.
bushflyr is offline   Reply With Quote
Old 06-09-2013, 06:02 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
anybody who even LOOKS at treadwear ratings is a total and complete fool
especially at this level of tire
these numbers are pixie dust.....fairies in the forest....mermaids
fiction at very best....more like fantasy
Old 06-09-2013, 10:54 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
oh yeah
this is in the wrong forum...we have an entire forum dedicated to....guess what???
autox
Old 06-10-2013, 11:05 AM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
"Dedicated track vehicle" does not typically mean a vehicle that you drive on the street to get to/from events.
What STI BBS wheels? And what size tires? Makes it hard to provide recommendations to meet your budget if we can't figure out what size you're looking for.
I didn't even notice the BFG Rivals before when looking on TireRack. Seems like a nice tire. However, how do you think these would compare to the KDW's I'm used to?
The KDW2 isn't even a particularly noteworthy Ultra High Performance summer tire - they're a dated design with decent performance and a neato tread pattern. The Rival is BFG's brand new extreme performance tire, specifically designed to do well in the very competitive street tire auto-x classing. The Rival will run circles around the KDW2s.
Old 06-10-2013, 02:54 PM   #15
Tire Rack Moderator
Member#: 1215
ext. 4362
kudo's guys there are lots of good posts in here ...
Right now when talking about the top tier of performance street tires is all about 4 tires
1.) BF Goodrich G-Force Rival
2.) Bridgestone Potenza RE11A
3.) Dunlop Direzza Z2
4.) Yokohama ADVAN Neova AD08R
I have driven on all of them, both on the street and on the track, here's my take.
All, were very good and for 3 out of 4 noticeable upgrades from their predecessors. They certainly have blurred the line between "race tires you can drive on the street" and "street tires you can drive on the track".
As far as road manners go I liked the low road noise and comfortable ride of the Bridgestone Potenza RE11A with the Yokohama being a very close second. The Rival is very "darty" on the road and follows road irregularities. The Dunlop is, by far, the noisiest of the four.
The track is is where these tires show their true metal. With all producing over a 1g average in the dry it made for some fun driving. In the end the two fastest tires for me were the Dunlop Direzza Z2 and the BF Goodrich G-Force Rival. I was fastest on the BFG by a slight margin while some of my associates were faster on the Z2's.
While, the Dunlop Direzza Sport Z1 Star Specs and Hankook Ventus R-S3 were battling it out of supremacy last season this new crop tires have made them also rans. The Star Spec has been discontinued in favor of the superior performance of the Z2. The R-S3 is definitely showing its' age with comparatively sluggish steering response as well as its lack of composure and stability under heavy load.
NOTE: You will not find the Yokoham ADVAN Neova AD08R is not on our website at this time. It is so new it hasn't even made it to the North America yet but, it will start arriving in the next few weeks.
We have just completed our testing of these new entries into the Extreme Performance tire world and will be publishing our results very soon so, keep an eye on our website for the full test report.
Old 06-14-2013, 02:36 PM   #16
skep18
Member#: 214971
2014 WRX
Wow. Thanks for the great review. I will probably be buying some Rivals from you guys very soon. Would you be able to provide a discount by going through you on this site?
Old 06-14-2013, 08:31 PM   #17
skep18
Member#: 214971
2014 WRX
Any advice on tire size best for Autocross application? (I realize "best might not be the best term here, but hopefully you get my point.)
Running Stock 17x8 BBS wheels, probably going to buy those BFG Rivals.
Old 06-14-2013, 08:42 PM   #18
sc00by4life
Member#: 97135
Its autocross. You are free to do all sorts of backwards ****. Run the widest possible tire you can. Not what fits best on the wheel. Literally. The widest tire you can fit on the wheel.
Old 06-14-2013, 08:45 PM   #19
skep18
Member#: 214971
2014 WRX
You don't need to worry about side wall rolling over or anything?
Old 06-14-2013, 08:52 PM   #20
jaboyd
Member#: 247304
2011 STI
WR Blue
Luke,
Is the new AD08 a material upgrade (like RE11A) or are there other changes?
jaboyd is offline   Reply With Quote
Old 06-15-2013, 08:53 AM   #21
Tire Rack Moderator
Member#: 1215
ext. 4362
Originally Posted by jaboyd View Post
Luke,
outward appearances of the AD08R is unchanged from the AD08 so, it is most likely a compound upgrade as the internal carcass of the AD08 was very good already
Old 06-15-2013, 04:12 PM   #22
skep18
Member#: 214971
2014 WRX
Luke, any advice on sizes?
Old 06-16-2013, 02:12 PM   #23
jprice130
Member#: 288225
2013 FR-S
With 17x8 wheels and BFG Rivals in mind, your tire size choices should either be 245/40/17 or 225/45/17. On a typical AutoX course, the 245/40 tire has slightly more performance potential, but unless you're nationally competitive or a top 10% driver, I don't think you'll see any difference in your lap times between the two sizes. Given that, I'd choose the size that's more readily available and costs less.
jprice130 is offline   Reply With Quote
Old 06-16-2013, 05:29 PM   #24
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
Do you mean 235/45/17 instead of 225/45?
CopperTopNWOR is offline   Reply With Quote
Old 06-16-2013, 05:59 PM   #25
jprice130
Member#: 288225
2013 FR-S
As far as I know, the Rivals are not currently available in 235/45/17. The OP seemed sold on the Rivals, so that's why I suggested the two available sizes that would fit his 17x8 wheels the best.
