Old 06-08-2013, 07:31 PM   #1
Zane
Member#: 292786
2003 WRX
Sonic Yellow
Unhappy Need Confirmation/help.
Alright, my car is finally running again but it's making a loud tapping/knocking. I didn't see any visible metal in tear down or after, don't THINK it's a rod knock.
Firing on all 4 fine, seems like it's idling fine, no audible missing or shuddering in the car.
114-115 compression in ALL 4 cylinders.
Misfire codes on ALL 4 cylinders though.
Took stethoscope all around engine, the sound is the same no matter where I check.
1st seems to contradict the rest which is what has me baffled @_@
I'm thinking bent valves when my father did the timing. Thoughts?
Have working at 5am so won't be replying til tomorrow afternoon most likely. Thanks in advance for any assistance.
Zane is offline   Reply With Quote
Old 06-08-2013, 08:43 PM   #2
WrxWrb
Member#: 287477
02 Wrx Wagon WRB
EVO III 16g=Fun
Start with the simple.
Back sure your coil pack wires are white closest to radiator and black closest to firewall. If backwards it'll run like garbage.
WrxWrb is offline   Reply With Quote
Old 06-09-2013, 03:39 AM   #3
Zane
Member#: 292786
2003 WRX
Sonic Yellow
It's not running like garbage and they are in the right order. The noise and compression are my worry.
Old 06-09-2013, 11:17 AM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Your compression is WAY too low.
Old 06-09-2013, 02:19 PM   #5
Zane
Member#: 292786
2003 WRX
Sonic Yellow
I know >_> It was 154-157 before. That's why I'm posting here, I want some insight before I tear it down again.
Old 06-10-2013, 06:29 AM   #6
Zane
Member#: 292786
2003 WRX
Sonic Yellow
Guess I'll just tear it down again and see what I find... Surprised I didn't even get an Uncle Scotty "You're an idiot and spun a bearing" reply.
Old 06-12-2013, 06:25 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
sounds like valves
Old 06-19-2013, 09:41 PM   #8
Zane
Member#: 292786
2003 WRX
Sonic Yellow
Did leak down test, air was going in Cylinder 4, coming out Cylinder 2. Pull heads, cracked from intake valves to spark plug holes... valves look fine. Still have no idea what the noise is/was, but cracked heads explain bad compression. No idea how they got completely cracked, never overheated the car or anything.
So far I've had to replace the ECU, head(s), and every idler and the tensioner. Did new Oil Pump and Water Pump while I was at it... now just to see what I need to replace for that damned noise @_@ Waiting on heads to get here.
