Old 06-12-2013, 01:27 AM   #1
elblanco1987
Member#: 353502
2013 WRX
Pearl white
Default 44mm ewg too big?
I'm thinking of getting a used 44mm ewg and up pipe from someone on the site. But my buddie said that 44mm is too big for my setup. Cobb sf, invidia Catted turbo back, and Perrin bpv, Somebody give me a little info?
elblanco1987 is offline   Reply With Quote
Old 06-12-2013, 02:33 AM   #2
VinceCarter
Member#: 284694
2006 WRX 6 Speed
277/323 @ EFI Logics
Your buddy is wrong on this one.
38mm=High boost applications
44mm=low boost applications
Lastly, when it all comes down to it just get a competent tuner, the right wastegate spring, a tune and you'll be all set with either sizes.
VinceCarter is offline   Reply With Quote
Old 06-12-2013, 05:24 AM   #3
CodeRed30
Member#: 350787
2013 WRX
Vince, can you expand upon that? Seems backwards to me that a larger WG would be better suited to lower boost levels. I'm a boost noob so just asking for some insight
CodeRed30 is offline   Reply With Quote
Old 06-12-2013, 05:43 AM   #4
05-rsx
Member#: 101188
MY07 WRX Wagon
If you're trying to keep your boost low, you're going to have to bypass a lot of the exhaust gases past the turbine through the wastegate.
More gases will flow better through a larger wastegate.
05-rsx is offline   Reply With Quote
Old 06-12-2013, 06:53 AM   #5
scott06sti
Member#: 320340
2006 Subaru STI
38mm=low boost applications
44mm=High boost applications
scott06sti is offline   Reply With Quote
Old 06-12-2013, 07:16 AM   #6
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
This is the correct one.....
And yes, it's too big for you. You would require the 38mm.
Cathexis is offline   Reply With Quote
Old 06-12-2013, 07:39 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it has NOTHING to do with boost pressure, and everything to do with mass air flow through the wastegate.
Old 06-12-2013, 09:42 AM   #8
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
WTF? Please tell me sarcasm is running rampant through this thread...
44mm is for any application
38mm is ONLY for applications where you don't need to flow a low of air through the wastegate
Read that again...
38mm is ONLY for limited applications
If you're not sure, go 44mm. If you're running a big turbo, go 44mm. If you're running low boost, go 44mm. ONLY if you're running a smallish turbo with high boost should you go 38mm. The 38mm does not have any advantages over the 44mm, and there are NO situations in which a 44mm will not work but a 38mm will (there are plenty of situations in which a 38mm will not work and a 44mm will, though).
The question itself is misleading..."44mm ewg too big?" There's no such thing as "too big" when you're talking about wastegates. There's "bigger than necessary", but that's significantly different. It can certainly be "too small" though.
Old 06-12-2013, 11:33 AM   #9
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
^ this is the only true answer. nicely summed up eggroll.
FWIW, I am using a 38mm EWG on my vf52 and I will consider to do so when I switch to a 20g turbo. The only reason I am using the smaller EWG is because I'll be running high boost.
Mr Wrex is offline   Reply With Quote
Old 06-12-2013, 11:38 AM   #10
coalslaw
Member#: 324808
2006 IWL Stg2
blow air through it with your mouth or even scream
only way to find out if its enough
coalslaw is offline   Reply With Quote
Old 06-12-2013, 02:56 PM   #11
VinceCarter
Member#: 284694
2006 WRX 6 Speed
Please do not post "facts" on subjects you have not researched...
Old 06-12-2013, 03:03 PM   #12
teesutt
Member#: 127940
Evil shenanigans
no, just noobs.
teesutt is offline   Reply With Quote
Old 06-12-2013, 09:04 PM   #13
elblanco1987
Member#: 353502
2013 WRX
Pearl white
Welp. Looks like ill be getting the 44mm since it seems it'll work with my current setup and once I get a bigger turbo
Old 06-12-2013, 09:33 PM   #14
Member#: 51961
2005 STi
2012 WRX
Originally Posted by Mr Wrex View Post
FWIW, I will be using a 38mm EWG even when I switch to a 20g turbo, but that's only because I'll be running high boost.
Nothing wrong with the 38mm gate, I hope I didn't imply that in my post.
The 38mm gate is perfectly acceptable and will work for most setups, one just needs to be aware of the limitations and make sure that it won't create a bottleneck in their application.
There are two types of people who run a 38mm gate:
1) Those who know what the difference is, and know that a 38mm gate will work correctly for their application. Whether it's through experience, research, following a similar build, or whatever else may be the case.
2) Those who don't know what's going on and simply pick the cheaper option.
People in camp #2 would be better off picking the 44mm just in case they need it and don't realize.
When it comes to wastegates, if you're unsure then go big. It's not like turbos where going too big will have a downside that needs to be weighed against the benefits. There really is no downside to going bigger than necessary on the wastegate, other than cost.
Old 06-13-2013, 12:01 AM   #15
Bru1212
Member#: 178770
06 STi
04 FXT
What are we considering high boost?
Bru1212 is offline   Reply With Quote
Old 06-13-2013, 07:58 AM   #16
scott06sti
Member#: 320340
2006 Subaru STI
I know my 44mm has held 30 psi and my car is still running good, so from my point of veiw it is all up to the person if you want 38mm or 44mm with the springs that come with them ethier one will do almost what the other will. The 44mm will let air flow faster being a little bigger, with the 38mm it will build pressure a little faster being smaller, but that is way so many people blow one of these engines to think the 38mm is better. Mine is still running high boost since 06 how many people can say that their car is still running.
Old 06-13-2013, 10:38 AM   #17
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Old 06-13-2013, 11:17 AM   #18
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
You didn't imply that whatsoever, don't sweat it!
OP, this should be the only thing you take as fact on this thread. As I stated earlier, a smaller EWG allows you to control higher levels of boost more effectively. You can run high boost on a 44mm EWG, but I've noticed firsthand that they're harder to tune with due to the larger diaphragm size.
As for the question about what constitutes a "low boost" application... it depends on capability of the turbo you are using. If you get a turbo that can run up to 30psi but you only want to run 17psi, that would be considered "low boost". I am running 22psi on my vf52 (24psi on e85), which is pretty much the highest you can run it in its efficiency range. That is an example of a "high boost" application. The larger the EWG diaphragm, the easier it is to bypass exhaust gasses and keep the psi down lower. I'm sure eggroll will have another way to describe it in case my basic explanation may not fully make sense.
In the end, I would highly recommend talking to your tuner about what size he/she thinks is best for your setup. You will also want to ask about what size spring to use and research the different boost control setups you can use. I made a thread awhile back to compare the different kinds (MBC vs EBCS vs Hybrid) so check it out and let me know if you have any furthur questions!
Old 06-13-2013, 11:29 AM   #19
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I don't even know where to start here
The ONLY time we've ever seen the 38mm perform poorly is when the design (angle to flow, pipe size, length, etc...) was done poorly. The 38mm will work for 99.98% of Subaru applications IMO. The smaller gate will also gives added resolution or modulation of boost, however your tuner prefers to word it, over the larger 44mm.
We've done the 38mm on a 35R at 17psi and 26psi and both had duty cycle headroom.
Will the 44mm do the job too. Sure. The larger the gate the bigger the oscillations in feedback boost will be seen with but enough ECU resolution it's compensated for anyway and it's not enough to 'feel'. So they both will work.
A WG is just a simple pressure regulation valve. It open when there is too much boost pressure and closes when it needs to build more. The size of the gate is the size of the hole you are opening to regulate the pressure. The smaller valve will give more precise control and the bigger valve can flow more, if needed. If the Suby setup wasn't so inefficient from the get-go I'm sure the 44mm would make more sense in more applications.
Just my 2 cents
KillerBMotorsport is offline   Reply With Quote
Old 06-13-2013, 11:50 AM   #20
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
how paradoxical.
Old 06-13-2013, 11:12 PM   #21
Leafy
Member#: 330625
2006 WRX
Just my 2 cents
This is the most complete answer. Bigger is better, until is starts to be hard to control. I also bet the 38mm would be insufficient if you were trying to run that 35R at 12psi.
Leafy is offline   Reply With Quote
Old 06-14-2013, 05:56 AM   #22
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
think about what you're claiming: that a 1.5" round hole in your exhaust wouldn't pass enough gas to prevent a 35r from hitting 12psi.
Old 06-14-2013, 06:20 AM   #23
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ and an even simpler way to put it
Considering a 35R's turbine inlet is ~47mm, the 38mm WG has plenty of flow to modulate boost.
Old 06-14-2013, 08:24 AM   #24
tuzzio
Member#: 292532
05 STI
My buddy has a 67mm turbo on his 2JZ, with a tial 38. At 18psi, it's just fine.
I have a tial 38 on my vf39, at 18psi, it's just fine.
tuzzio is offline   Reply With Quote
Old 06-15-2013, 06:04 PM   #25
scoobasaurusrex
Member#: 255114
2007 wrb wrx wagon
93oct vf43 ewg
38mm sound ricey so you should get a 44mm
Your buddy is an idiot. Either will work and either will do the same thing for your setup.
scoobasaurusrex is offline   Reply With Quote
