Old 06-12-2013, 03:03 AM   #1
Corinator
Member#: 211974
2004 WRX STi PTE6466
2002 Sentra SE-R Spec V
Default 654whp/499wtq Clark Turner Tuning sleeved/forged 2.5l-PTE6466-GSC S3 on e85
Finally got my fuel pressure issues resolved and got some tuning done. The poor little Walbro 460 pump is just about at its safe max. IDC was ~85% and the fuel pressure started to taper off slightly so it was as far as they felt safe on the single pump. In the future, I will be doing a twin Walbro 460 setup.
I managed to get only 1 pull on video. Unfortunately the normal Android camera application was acting screwy and would only record for about a second. I managed to work around this by taking a video with Instagram. This is one of the early pulls and I don't know if it was on the full 27 psi of boost on this pull.
Instagram Video Link:
http://instagram.com/p/dkRxg8FP2A/
Event: Dyno Pull
Ambient Temp: 101 degrees Fahrenheit
Elevation: ~1400 feet?
Weather: Sunny with 27% humidity
Car: 2004 STi
Tuner: Clark Turner via Goodspeed Performance
Dyno Info: MAHA LPS3000 PKW
Transmission: Factory 6 speed with ACT XHD 6 puck ceramic clutch
Gear: 4th
Peak HP at RPM: 654.5 whp at 7225 rpm SAE corrected power
Peak Torque at RPM: 499.2 lb/ft at 6675 rpm SAE corrected power
Baseline hp/tq for a stock on same dyno: 04 STi ~210 whp SAE corrected power
Target Boost: 27 psi
Target AFR: don't know
Fuel: E85
Engine:
Sleeved EJ257 done by LA Sleeve
Cosworth pistons 8.2:1 CR 99.5mm bore
Cosworth rods
Cosworth oil pump
08+ nitrided crank
ACL bearings
MAPerformance H11 head studs
Hand ported/polished heads
Ferrea stock size valves
SuperTech 82lb springs/titanium retainers
GSC S3 282 cams
AMR UEL big tube header
AMS 900x V-band rotated kit
Precision PTE6466
Tial MV-R 44mm EWG
Tial Q 50mm BOV
APS DR525 FMIC
2007 2.5i Impreza NA big plenum, long runner manifold
Outfront Motorsports top feed SOHC fuel rails
KS-Tech 19mm phenolic spacers
FIC 2150cc injectors
-6 feed line (soon to be replaced with a -8 or maybe -10)
Aeromotive 13129 FPR (about to be replaced with a A1000 regulator)
Walbro 460lph fuel pump hardwired
Megan Racing catback exhaust
Cusco catch can
Drivetrain:
Group N motor/trans mount & pitch stop
ACT Xtreme Duty 6-puck clutch
Drive Shaft Shop 800HP rear axles
Turn in Concepts Sexy Rear End Kit
Suspension:
ISC N1 coilovers Racing spec 10k front/8k rear spring rates
Agency Power aluminum sway bar endlinks
Whiteline front & rear 24mm sway bars
Wheels and Tires:
18x9.5 +38 flat black Rota Grids
255/35/18 Bridgestone Potenza S-04 Pole Position
Interior:
Cusco 6 point bolt in cage
Defi Advance BF 60mm Amber Boost 2.0
Defi Advance BF 60mm Amber EGT
Defi Advance BF 60mm Amber Oil Pressure
Defi Advance BF 60mm Amber Oil Temperature
Defi Advance BF 60mm Amber Fuel Pressure
Defi Advance Control Unit
Innovate Motorsports G3/LC1 Wideband AF
Exterior
Zero/Sports front bumper
Zero/Sport sideskirts
BurnUp replica WRC wing
JDM rear bumper spats
The dyno sheet:
The car:
Corinator is offline   Reply With Quote
Old 06-12-2013, 01:46 PM   #2
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
The most amazing this about this post is the fact that you were able to tune the car in 95* weather and not 115*+ weather!! Hahaha jk
Sick build and car man. I'm liking it. As soon as you can turn it up I bet it's going to be a monster!! Rev it out!! Glad to finally see some High-HP Clark Turner cars.
wgr73 is offline   Reply With Quote
Old 06-12-2013, 03:41 PM   #3
Airboy
Member#: 72829
2006 WRX
2015 WRX
Am I reading it right, the chart shows ~26psi for boost?
Airboy is offline   Reply With Quote
Old 06-12-2013, 05:04 PM   #4
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Looks very nice, congrats
Yeah the boost seems to be higher than 22psi according to the graph. Maybe even 27ish
Uncorrected hp 551whp and 411whp
Old 06-12-2013, 08:34 PM   #5
Corinator
Member#: 211974
Yeah this stupid fuel pressure regulator issue is very infuriating.
I myself was confused at this. Clark said it must be off because the logs show minor fluctuations between 21-22 psi
Clark keeps telling me it is actually 22 psi according to the logs. They use the corrected power on this dyno as it still reads lower than a dynojet. From what I've been told, the corrected power reads ~9% lower than a dynojet. Numbers are kind of irrelevant though when every dyno reads different haha.
Old 06-12-2013, 08:43 PM   #6
SW00P_G
Member#: 5591
EJ257 Gt35r
I've tuned STI's that only go to 22psi of boost before in the logs as well. What does your boost gauge say?
SW00P_G is offline   Reply With Quote
Old 06-12-2013, 08:50 PM   #7
juanmedina
Member#: 133146
We need a VD
The stock MAP sensor max out at 22.7psi.
Old 06-12-2013, 08:51 PM   #8
Corinator
Member#: 211974
My Defi boost gauge agrees with what Clark said his logs show. My boost gauge reads 22 psi.
Old 06-12-2013, 08:57 PM   #9
Corinator
Member#: 211974
We need a VD
I'll get one once I get the fuel pressure regulator replaced. I'm Cobb speed density and have not had a stock map sensor for probably 3 years (UTEC speed density before that). I'm pretty sure it is a 5 bar map sensor.
Old 06-15-2013, 12:52 PM   #10
aaguirre
Member#: 155741
07 Clark Turner
& Goodpeed tuned WRX
Nice power man. To bad to see people hating but what can you do.
Abel
aaguirre is offline   Reply With Quote
Old 06-15-2013, 01:50 PM   #11
CatfaceType-R
Member#: 81102
Car looks mean and clean, engine looks great, nice build.
CatfaceType-R is offline   Reply With Quote
Old 06-15-2013, 08:29 PM   #12
Corinator
Member#: 211974
Abel
It doesn't matter to me if people hate. Once this thing is turned up all the way then I don't think people will have anything to hate on.
Thanks man. I appreciate it.
Old 06-16-2013, 08:25 AM   #13
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Abel
whos hating??
Old 09-03-2013, 08:36 PM   #14
Corinator
Member#: 211974
bump for new results with fuel pressure issues resolved
Old 09-03-2013, 08:50 PM   #15
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
It seems the car doesn't really make power until 5500 rpm+ so why did you not choose to go with a 2.34L motor and rev it out to 8k+?
I mean, looking at the graph you have a useful power curve of 1500rpm, that seems pointless to me and not very "usable".
Impressive power numbers, but just doesn't have that much area under the curve. How does it drive?
Tyrial is offline   Reply With Quote
Old 09-03-2013, 08:58 PM   #16
Corinator
Member#: 211974
A lot of that rightward shift of the powerband is from the GSC S3 282 cams. GSC doesn't rate them to be effective until 5k rpm. I thought about going with a longrod from MPS, but I decided to stick with the 2.5l. I think it drives great around town etc. I know it's a bad comparison, but I have a friend with an Evo IX MR on a built 2.0l with the 6266 and Kelford 280 cams and my car is much friendlier on the street.
I plan to eventually do the dry sump kit from ARE Dry Sump alongside the second Walbro 460 fuel pump. I should be able to take the car out a little further with those. I currently run it out to 8k rpm.
Old 09-03-2013, 11:34 PM   #17
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Yeah a dry sump should help. Rev it out I guess, but I'd talk to a builder first like Micah @ 3MI or Dom @ MPS, etc. before going much past 8k lol.
Once it spools, it's great, super aggressive cams though. Have you thought about Radium Surge tanks?
Oh and I love the look of your car, clean and neat with low-key accents, very well done.
Old 09-04-2013, 03:46 AM   #18
WhozNext
Member#: 265369
07 STI
Congrats bro. Hope to see some videos of this thing on the street doing some pulls.
WhozNext is offline   Reply With Quote
Old 09-04-2013, 03:55 AM   #19
Corinator
Member#: 211974
I managed to do a test dig tonight actually. First launch I have done on the new tune. Went down to mexico
Old 09-04-2013, 12:44 PM   #20
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Very Nice to see you got this taken care of.
Clark is the man behind the laptop!
rexworx is offline   Reply With Quote
Old 09-04-2013, 01:29 PM   #21
Type2
Member#: 200436
2004 Forester XT
The hp jump from 5500rpm to 6500rpm is bonkers. What, like 400hp? Cray cray!
Type2 is offline   Reply With Quote
Old 09-04-2013, 06:26 PM   #22
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
Video looks nice.....
jdpsearcher is offline   Reply With Quote
Old 09-04-2013, 07:34 PM   #23
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Looks like it is a hard charger, nicely done~
Old 09-04-2013, 08:11 PM   #24
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
what are you using the car for? It doesn't crack 200whp until 5500 rpms. I'm sure it's fun on a track but doesn't seem too streetable.
Your car sure looks good!!
575rider is offline   Reply With Quote
Old 09-04-2013, 09:04 PM   #25
Clark Turner
Member#: 178047
02 WRX STI Spec C
Just saw this post. The car ran a peak of 25.5 psi fading down to around 22 to 23 at power peak. It uses an AEM 3.5 bar map sensor that is accurate and calibrated. I rolled the throttle out up top and detuned this car to 654 because he has one fuel pump and a stock location oil pump. IDC was 85% and Oil pressure needle was shaking back and forth at 8000.
This car has BIG tube headers, BIG tube intake manifold, BIG header ports and BIG cams and BIG 6466 which all hurt midrange and low end and help top end. So that is what the car has. Top end power and no midrange power. However, At 22 psi, I think that is a pretty good number.
Clark Turner is offline   Reply With Quote
