Old 06-12-2013, 11:26 PM   #1
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Which way the crush face on the metal TGV gasket between intake manifold and TGV assy should face? Crush face touching/facing the intake manifold or touching the TGV facing head?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 06-13-2013, 11:29 AM   #2
Eww Evo
Member#: 299687
TT3
06' Wrx Project
The crush side needs to face the heads if i'm not mistaken. I'll go look for a link.
Eww Evo is offline   Reply With Quote
Old 06-13-2013, 12:09 PM   #3
Eww Evo
Member#: 299687
TT3
06' Wrx Project
Yes, confirmed with Rallysport Direct. The tab in the middle where the crush side is should be facing the heads.
Old 06-13-2013, 12:15 PM   #4
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Not sure I understand, you can flip the gasket either way and still have the tab pointed in the same direction.
I think the crush side faces the intake though as the mating surface in the intake is bigger (smaller ID) than the TGV housing ID. Also, there is some witness marks on the intake that seem to indicate the crush side was deformed by the intake not the TGV.
So is the orientation in the picture correct? crush side facing up towards intake?.
Old 06-13-2013, 11:07 PM   #5
Leafy
Member#: 330625
2006 WRX
If both surfaces are flat and the gasket is otherwise symmetrical it doesnt matter. I cant remember which way I put mine in when I did my tgv deletes. But for some reason I thought it only lined up one way.
Leafy is offline   Reply With Quote
Old 06-14-2013, 09:23 PM   #6
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
As long as the bolt holes line up it doesn't matter which side is up. Once the ridge is compressed it no longer matters.
Old 06-14-2013, 11:12 PM   #7
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
It matters the ID on the TGV is larger than the ID on the intake, once compressed there is more material on the intake side for the ridge to compress, so I think I have answered my question but still would like to know how the factory installs it.
Old 06-14-2013, 11:39 PM   #8
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I'm not getting what your saying. Ridge up or ridge down the ID of the gasket doesn't change when the ridge is compressed and it doesn't protrude into the flow path.
Old 06-15-2013, 12:55 AM   #9
cameronxt
Member#: 305971
2004 WRX STi
Wold Rally Blue
I put mine on with the ridges faceing up (towards the intake), though i dont think it matters, the material crushes not expands. Even if it did it would expand all of it not just one face.
cameronxt is offline   Reply With Quote
Old 06-15-2013, 10:08 AM   #10
Leafy
Member#: 330625
2006 WRX
Arent they the same gasket for both sides? Wouldnt that mean one of them needs to be up and one down? Or are the TGVs more symmetrical than I remember.
Old 06-15-2013, 10:27 AM   #11
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Guys, I just would like to know how factory installs them, regardless on whether it matters or not. Crush ridge up towards intake?, or ridge down towards head?
Simple question.
Old 06-15-2013, 11:08 AM   #12
kellygnsd
Member#: 32669
LINK G4 hybrid STi
They are symmetric so you can install it up or down. Its hard to tell how it was installed from the factory because the ridge compressed flat when everything is torqued together. The old gasket is perfectly flat when it comes out and I couldn't tell looking at the IM or the TGV's what side was up or down. The only purpose of the ring is to deform and form a circular ring of high pressure for a better seal. Up or down its doing the same thing.
I'm about 99% sure I installed them ridge up this time around just because of my OCD but the last 3 or 4 times I've had my manifold of I just threw the gaskets in without even looking at the orientation and have never had an issue.
Old 06-15-2013, 05:47 PM   #13
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
I will go with facing up towards intake.
Old 11-14-2013, 11:19 PM   #14
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Any issues? Ill be doing this on saturday.
RallyImprezive is offline   Reply With Quote
Old 11-14-2013, 11:53 PM   #15
superblkwrx
Member#: 129395
2006 OBPWRX VF39 E85
333WHP 385WTQ 21PSI SD
I build these engines quite often. It does not matter which way. Both surfaces are flat.
superblkwrx is offline   Reply With Quote
Old 11-15-2013, 12:48 AM   #16
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
No issues, I installed the convex side of ridge facing the intake.
Old 11-17-2013, 11:32 AM   #17
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Yep, got the install done yesterday, didnt sweat the gaskets. I dont even remember what side I put up or down.
Thanks guys!
