Old 06-13-2013, 11:36 AM   #1
Extreme Turbo Systems
Member#: 194655
08 STI
Default Extreme Turbo Systems 2006 STi PT6466 751WHP/630WTQ
Looks like when we do it, we do it big (It's not an easy task to make power on the Subaru) We built our shop 06 Subaru STI a while ago and it's been missing a fuel system for about a year. We recently installed the fuel system and finished up the tune tonight. I will let the picture speak for it self, but this is our shelf rotated turbo kit. Here are the mods. Extreme Turbo Systems Rotated PT6466 Turbo Kit, ETS EL Turbo Manifold, ETS Ported Head Package, ETS 2.5L Motor Build, ETS Subaru STI Front Mount Intercooler Kit, ETS Turboback Exhaust System, AEM Engine Management System, ETS Custom Fuel System. Stock Intake Manifold and Stock Sleeves
Event: dyno
Ambient Temp: 70*
Elevation: 500ft
Weather: cloudy
Tires: Stock
Car: 2006 STi
Tuner: JR @ ETS
Dyno Info: Dyno Jet
Transmission: Stock 6 Speed
Gear: 4th
Peak HP at RPM: 751 @
Peak Torque at RPM:630 @
Baseline hp/tq for a stock on same dyno: Unknown
Target Boost: 38 PSI
Target AFR:
Fuel: Q16
Engine/Power Modifications: Cosworth Pistons,Rods, head studs, GSC S2 cams, Aeromotive AFPR, Walbro in tank pump, RC 1600cc Injectors, Ultimate Racing Fuel Rails
Driveline Modifications: Exedy Triple disc
Suspension Modifications: Lowering springs
Other Modifications: Full Weight, Stock Wheels and tires
Extreme Turbo Systems is offline   Reply With Quote
Old 06-13-2013, 11:55 AM   #2
reemwrb04sti
Member#: 254796
04 Sti
Originally Posted by Extreme Turbo Systems View Post
Looks like when we do it, we do it big (It's not an easy task to make power on the Subaru) We built our shop 06 Subaru STI a while ago and it's been missing a fuel system for about a year. We recently installed the fuel system and finished up the tune tonight. I will let the picture speak for it self, but this is our shelf rotated turbo kit. Here are the mods. Extreme Turbo Systems Rotated PT6466 Turbo Kit, ETS Ported Head Package, ETS 2.5L Motor Build, ETS Subaru STI Front Mount Intercooler Kit, ETS Turboback Exhaust System, AEM Engine Management System, ETS Custom Fuel System. Stock Intake Manifold, Exhaust Manifold and Stock Sleeves
Impressive #s...what head studs you guys runnin
reemwrb04sti is offline   Reply With Quote
Old 06-13-2013, 11:58 AM   #3
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Any chance of seeing the full dyno sheet? I am very curious as to what the power curve looks like on this beast!
RexFTW is offline   Reply With Quote
Old 06-13-2013, 11:58 AM   #4
Blown95ImpalaSS
Member#: 87629
killer numbers
wonder what you'd gain by replacing stock manifold with a properly sized equal length manifold
Blown95ImpalaSS is offline   Reply With Quote
Old 06-13-2013, 11:58 AM   #5
Member#: 194655
08 STI
We built the motor so long ago I can't recall exactly but I am pretty sure they are ARP.
Old 06-13-2013, 12:02 PM   #6
reemwrb04sti
Member#: 254796
04 Sti
Race gas ?
Old 06-13-2013, 12:03 PM   #7
Member#: 194655
08 STI
Yes, I will have a full dyno graph up later today hopefully.
Originally Posted by Blown95ImpalaSS View Post
killer numbers
Not sure. We built this kind of on a budget. Its an in tank walbro fuel pump, top feed injectors, AFPR, stock rubber lines, conversion fuel rail, forged pistons/rods and some GSC s2 cams. Keep it simple.
It is running our Rotated 6466 turbo kit, Turbo back exhaust and 4" FMIC Kit.
Old 06-13-2013, 12:04 PM   #8
Member#: 194655
08 STI
Race gas ?
Yes, Q16. It made 518 @ 23PSI on pump.
Old 06-13-2013, 12:17 PM   #9
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
751whp with how much boost?
and please fix your first post: http://forums.nasioc.com/forums/show....php?t=1858764
Old 06-13-2013, 12:20 PM   #10
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Any plans to run it down the 1/4?
Old 06-13-2013, 12:31 PM   #11
Member#: 194655
08 STI
38PSI we ran out of fuel pump. There is more left in it. its on a single in tank walbro.
Possibly. Stay tuned to find out!
Old 06-13-2013, 12:38 PM   #12
juanmedina
Member#: 133146
never mind I am running e85
Congrats! amazing car
Old 06-13-2013, 12:45 PM   #13
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
Stock liners?
02rex62 is online now   Reply With Quote
Old 06-13-2013, 12:57 PM   #14
Member#: 194655
08 STI
Originally Posted by 02rex62 View Post
Stock liners?
Yes, sir. just Cosworth pistons/rods and head studs.
Old 06-13-2013, 01:32 PM   #15
juanmedina
Member#: 133146
no pins? block guard? or anything?
Crazy! I wonder how long it will last.
Old 06-13-2013, 01:38 PM   #16
Member#: 194655
08 STI
Nothing. Engine builder/tuner is confident in the setup. Once we get a bigger fuel pump in he wants to push it farther. We did 20+ dyno pulls on the motor alone last night in 4th gear.
Old 06-13-2013, 05:19 PM   #17
juanmedina
Member#: 133146
I am glad you guys have to balls to push that much boost on the stock sleeves. I hope it stays together for while, let us know if it breaks. Maybe most of the stock case failures that we see are do to too much timing and det.... Maybe the case will survive with a good tune.
Congrats again.
Old 06-13-2013, 05:28 PM   #18
Member#: 194655
08 STI
Congrats again.
Thanks! You will hear about it if it breaks. so far it has 20+ dyno pulls and a fair bit of "closed course" abuse.
Old 06-13-2013, 05:39 PM   #19
Paul
Member#: 56203
00 RSTI Coupe
video or it didnt happen
Old 06-13-2013, 05:51 PM   #20
reid-o
Member#: 103631
2004 STI
That's impressive overall and even more impressive on a single fuel pump.
reid-o is offline   Reply With Quote
Old 06-13-2013, 06:03 PM   #21
CatfaceType-R
Member#: 81102
This.
CatfaceType-R is offline   Reply With Quote
Old 06-13-2013, 07:10 PM   #22
Member#: 194655
08 STI
Originally Posted by CatfaceType-R View Post
This.
I will work on getting a video.
For now the dyno sheet is in!
Old 06-13-2013, 07:19 PM   #23
bjohnson_55
Member#: 216580
Jr Tuned?
Good numbers guys
bjohnson_55 is offline   Reply With Quote
Old 06-13-2013, 07:23 PM   #24
Member#: 194655
08 STI
Originally Posted by bjohnson_55 View Post
Jr Tuned?
Good numbers guys
J.R. @ ETS tuned not Junior tuned.
Thanks!
