Old 10-24-2013, 01:41 PM   #151
WhatTurboLag?
Member#: 243992
2006 WRX TR
No sleeves????
WhatTurboLag? is offline   Reply With Quote
Old 10-24-2013, 01:47 PM   #152
Extreme Turbo Systems
Member#: 194655
08 STI
NO sleeves....Just the block guard.
Extreme Turbo Systems is offline   Reply With Quote
Old 10-24-2013, 02:08 PM   #153
WhatTurboLag?
Member#: 243992
2006 WRX TR
Wow any reason why?
Any reason not to pin either?
Old 10-24-2013, 02:15 PM   #154
Member#: 194655
08 STI
We think the stock sleeves will hold up fine. With the block guard there is no reason to pin it.
Old 10-24-2013, 02:47 PM   #155
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Pinning is the poor man's block guard. A block guard is essentially just machining pieces and pressing them in to close the deck. The top of the cylinders is where the strengthening is needed to hold the combustion at high HP levels. The theory is that you don't need better sleeves, you just need reinforcement on the stock sleeves which is what this solution and the others like it provide. There are a lot of guys making big numbers on this type of solution.
WRXt4cy is offline   Reply With Quote
Old 10-24-2013, 02:54 PM   #156
WhatTurboLag?
Member#: 243992
2006 WRX TR
Interesting. Would sleeves and pins/block guard be even better then?
I thought pins all the way down while a block guard like this was just on the top portion??
Old 10-24-2013, 03:41 PM   #157
Member#: 194655
08 STI
Correct. That about sums it up.
Old 10-24-2013, 03:48 PM   #158
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
I think pins actually weaken the stock sleeves. Yes the may eliminate some movement/ vibration but you cut into the sleeve to hold them in place creating a potential stress points. They typically are only at the top 1" or so of the cylinders.
The problem that people are finding with iron sleeves is they expand at a different rate than the aluminum block creating a differential between the case and the sleeve and then leaking head gaskets. Some call it dropping which may happen if they aren't pressed in correctly. It more likely that they are at different rates of expansion from the case creating the HG issues.
Old 10-24-2013, 03:51 PM   #159
manitou
Member#: 193757
2006 XTI Limited
I don't remember If you call them and talk to Bobby I am sure he can match any other closed deck block price or beat it.
Thanks Mike! I'll contact Bobby. I sure do like the looks of there's and the way they cover the case bolt holes. It looks like a better solution that Outfront's. Can you tell me how thick the inserts are approximately?
Old 10-24-2013, 03:55 PM   #160
manitou
Member#: 193757
2006 XTI Limited
I finally received the universal 1/2" ARP head studs which will fit our blocks. <$8/ ea. plus nuts and T washers. I think these 1/2" head studs and the block guards will make a pretty bomber motor!
Old 10-24-2013, 04:36 PM   #161
Member#: 194655
08 STI
This is Robert . I don't remember how thick they are. I think they are about 1". They put a step in the block for the block guard to sit on. We used the 13mm P&L head studs in ours. The larger head studs aren't exactly easy to machine for but the end result is worth it.
Old 10-24-2013, 05:44 PM   #162
WhatTurboLag?
Member#: 243992
2006 WRX TR
Wow. 1 inch?
If that's the case, that would **** on pins. BUT how about a factory closed deck such as a ej22?
Sorry I am researching for a build in the near future.
Looking at the new class legal precision 6785 with a small turbine housing. It's a gt42 size compressor cover >
Old 10-24-2013, 06:23 PM   #163
Member#: 194655
08 STI
Originally Posted by WhatTurboLag? View Post
Wow. 1 inch?
Maybe not quite an inch. lol
Old 10-24-2013, 08:32 PM   #164
manitou
Member#: 193757
2006 XTI Limited
No worries Robert! I knew it was either you or Mike!
1"? That's thick. When I was talking with Paul Szuba at PnL about their block guards he said that they made theirs about as thick as he thought the block could take and theirs are 3/4" thick. Either 3/4" or 1" would be great as that's the business end of the cylinder! The PnL 13mm studs, ARP2000 are super nice at $500 and so are the AMR 14mm studs, 8740 CM steel at $600+! They should be very nice for that money.
The studs pictured below are 1/2"/ 12.7mm, are 8740 CM steel and have a tensile strength of +200,000 psi and torque to 110 ft.lbs. but here's the kicker. They're <$8/ ea. I figure the nuts and T washers plus the studs might add up to $15 max., so that's maybe $180 for a set.
juanmedina found them and I did a bit more research on them and ordered a couple to inspect them. They look nice, robust and should work well for our motors. Here's the specs on them.
AR7.562-1LB. is:
  • 7.562" OAL, 8740 CM steel
  • 180,000-200,000psi TS
  • torques specs are 100-110ft.-lbs..
  • The threaded portions are:
  • block: 1/2"-13 x 1.25" long
  • head: 1/2"-20 x 1.25" long
Old 10-26-2013, 02:55 PM   #165
jockeygolfs
Member#: 260868
2011 STI
Edited
jockeygolfs is offline   Reply With Quote
Old 10-28-2013, 04:02 AM   #166
lee586
Member#: 212926
97 Wrx
lee586 is offline   Reply With Quote
Old 10-28-2013, 04:04 AM   #167
lee586
Member#: 212926
97 Wrx
Old 10-28-2013, 11:15 AM   #168
What v8
Member#: 254718
this looks great! looking forward to the results.
What v8 is offline   Reply With Quote
Old 10-28-2013, 09:51 PM   #169
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
So how much power is this thing making now?
God... I need to stop being cheap and get a good engine haha
Old 10-28-2013, 10:00 PM   #170
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Originally Posted by juanmedina View Post
So how much power is this thing making now? God... I need to stop being cheap and get a good engine haha
Why??? My cheap engine ran like a champ lol
Md05STI is offline   Reply With Quote
Old 10-28-2013, 11:43 PM   #171
BLKSHEEP
Member#: 365835
2005 Evo 8
Pretty impressive build. Just read all 170 posts. Looks like I'll have to order some more parts from you guys with your proven street build. Like to see numbers when all said an done.
BLKSHEEP is offline   Reply With Quote
Old 10-29-2013, 08:00 PM   #172
Member#: 194655
08 STI
Sounds good. Let me know if you need anything. We started to turn it up on the dyno but it got cut short because one of the straps broke.
Old 10-29-2013, 08:20 PM   #173
juanmedina
Member#: 133146
My engine is running fine but I cannot turn it up any more
nice!
Old 10-29-2013, 09:56 PM   #174
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
That's what everyone said about mine too! But it kept running stronger, until all the boost finally got to it lol
Old 10-29-2013, 10:22 PM   #175
shomspeed
Member#: 166371
2007 WRX STI
They are factory STI blocks that they machine for a block guard. So they are stock bore (99.5mm). We got ours for stock size pistons.
I've seen that most that offer the closed deck option, or the of pinning the sleeves, require boring of the sleeves to get them back straight after the process. Are you saying that with VSR closed deck option there isn't any distortion of the sleeves that would require boring .25mm over?
shomspeed is offline   Reply With Quote
