Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-13-2013, 11:09 PM   #1
japanesestar
Member#: 212037
2005 wrx sedan
black
Default WOT pull log. Need advice plz.
Hello scoob brethren. I did a pull in 3rd as recommended and got some interesting results. I have a 2005 WRX with 150k on the clock. Its been running a bit strange lately with slight hesitation and what appears to be an A/F delayed reaction to skinny pedal. I have an AEM wideband that i have not gotten the usb/serial cable for yet in order to log it.
The car has the factory map on it (-p0037 code).
I have an spt intake, silicone inlet, gutted uppipe, 3" catless ebay exhaust.
I've tested compression. Driver's side first (145 for both) and pass (~139 for both)
https://docs.google.com/spreadsheet/...p=docslist_api
Hopefully that works. I also have a couple of bad videos on youtube with me making cheesy comments about the femininity of the issue.
https://www.youtube.com/watch?v=6an2...e_gdata_player
https://www.youtube.com/watch?v=xRmu...e_gdata_player
In the datalog, yellow is a/f (factory), pink is FLKC, blue is engine load (g/rev), and green is MAP. Notice during the swinging that my foot has nothing to do with it.
I'm a noob at tuning, but really want to fix this and tune properly for the parts I have. I should mentioned that this issue has just recently surfaced and that I have had those parts on for a long time. The car ran "fine" up until this, although my buddy claims its the slowest WRX he's ever been in...
I totally expect a ruler on the hand for not tuning sooner, sorry boys. I'm pretty busy with a FT job and a wife and daughter, oh and school. Let the flaming begin!
japanesestar is offline   Reply With Quote
Old 06-14-2013, 05:33 PM   #2
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Need to make the doc public.
mechatricity is offline   Reply With Quote
Old 06-14-2013, 06:40 PM   #3
japanesestar
Member#: 212037
2005 wrx sedan
black
Sorry. Noob at google drive. It's public now.
Old 06-15-2013, 01:00 PM   #4
dux10
Member#: 235338
2002 Faggin Wagon
srp
Holy Knock batman! lol
Try cleaning the MAF sensor. If that doesn't help, replace the front O2 Sensor.
Steve @ Pullz-On Tuning
dux10 is offline   Reply With Quote
Old 06-15-2013, 01:59 PM   #5
japanesestar
Member#: 212037
2005 wrx sedan
black
Lol. That's what I thought. Will do.
Old 06-15-2013, 02:09 PM   #6
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Knock knock? Whos there? Blown motor!! Lol jk.
Tune tune tune!
cosseywrx is offline   Reply With Quote
Old 06-15-2013, 03:18 PM   #7
japanesestar
Member#: 212037
2005 wrx sedan
black
Tune tune tune!
I never used to have this knocking. I used to check learning view all the time with no real issues. My IAM has always been 16, and still is. I'll have to clean the MAF (cleaned it about 4 months ago) and possibly replace the A/F sensor. Sucks being busy.
Old 06-16-2013, 12:30 PM   #8
dux10
Member#: 235338
2002 Faggin Wagon
srp
Some of the 16bit cars (02-05 WRX's) don't do too well with the stock rom. I've only come across 2 others on 93 that were horrible and one of them had a post MAF leak.
Old 06-16-2013, 12:53 PM   #9
japanesestar
Member#: 212037
2005 wrx sedan
black
I did a rigged-up smoke test(didn't work well) and had smoke coming from the MAF where it inserts into the SPT intake. I haven't had a chance to find a new o-ring but did make a gasket from some really thin, high density foam. I'm not sure how much this leak would affect it, but I have to believe it doesn't help. I am going to perform a better smoke test soon just to find any low pressure leaks.
On the romraider forums there is a "stage 2" rom that I was going to try, obviously very cautiously, but don't want to until I believe all the little/mechanical things are fixed. Any thoughts on that?
Old 06-17-2013, 08:36 AM   #10
japanesestar
Member#: 212037
2005 wrx sedan
black
I thought the ecu ignored the A/F sensor during WOT...
Old 06-17-2013, 09:04 AM   #11
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
It does, but the ecu will apply the D range fuel trim (learned in CL) into wot (OL fueling).
nmlittlebigman is offline   Reply With Quote
Old 06-17-2013, 10:30 AM   #12
japanesestar
Member#: 212037
2005 wrx sedan
black
Wow, I have alot to learn...In my D range from learning view, I have -4.59% learned. What would cause this? I would think it would add fuel based on the parts I have...
Old 06-17-2013, 10:43 AM   #13
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Your fuel trims are based upon what the maf sensor and front 02 sensor are reading in closed loop as compared to your fueling targets in your map. If either of those sensors are faulty your trims will be off.
You might want to read the guide for a better explanation:
http://forums.nasioc.com/forums/show....php?t=1626520
Old 06-17-2013, 10:31 PM   #14
japanesestar
Member#: 212037
2005 wrx sedan
black
I do understand that part. I guess what I should have asked was, are there tell-tale signs of either sensor being bad when they appear to still function correctly? I know datalogging my wideband would help. I appreciate your patience..there are still some vital checks I need to perform to rule out any variables.
Old 06-17-2013, 11:05 PM   #15
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Pull a Learningview if you can and post it up. Otherwise you can check the A/F learning #1 stored values for A, B,C,D airflow ranges. Those might tell us more. Like you mentioned comparing wideband to front o2 sensor (AF sensor 1) would be a good thing to do.
Old 06-17-2013, 11:29 PM   #16
japanesestar
Member#: 212037
2005 wrx sedan
black
Ok. I will post a learningview asap.
Old 06-18-2013, 11:32 AM   #17
dux10
Member#: 235338
2002 Faggin Wagon
srp
It does, but while cruising in your video your AFR was bouncing all over the place. I've seen this happen on several cars and each time it was determined to be the primary O2 sensor.
Old 06-18-2013, 11:43 AM   #18
japanesestar
Member#: 212037
2005 wrx sedan
black
Ok. I have no problems with replacing that (except the $$). I'm surprised it's made it this many years/miles. It can't hurt, that's for sure. I has half a mind to replace it just for good measure, so I'm glad u said that. Oh, andi had no intention of recording my reflection. Lol. I noticed after. Derp.
Old 06-18-2013, 11:59 AM   #19
dux10
Member#: 235338
2002 Faggin Wagon
srp
Technically, the O2 sensor is a maintenance item to be replaced regularly. lol
Old 06-18-2013, 12:03 PM   #20
japanesestar
Member#: 212037
2005 wrx sedan
black
Hopefully, this link/post works. This is actually after running about a 30% mix of E85 to see if there was any false knock. This looks way better in terms of knock. I don't have my other laptop to upload a recent 93 learningview, but I will asap
Old 06-18-2013, 12:05 PM   #21
japanesestar
Member#: 212037
2005 wrx sedan
black
Shouldn't we be calling it an A/F sensor?
Old 06-18-2013, 12:35 PM   #22
dux10
Member#: 235338
2002 Faggin Wagon
srp
You can. I believe that's the correct technical term but most people know it as an Oxygen sensor. lol
