Old 06-13-2013, 11:40 PM   #1
subi-T
Member#: 348082
2006 impreza
SGM
Default E85 Help
Hey guys!
There may be a thread on this already but can't seem to find it or a answer I'm looking for.
I wanted to know if I can use E85 on my 2002 WRX, if I can run my car on E85 safely and what would happen besides as I heard power gains.
Can I use E85 then switch back to 91 and then use E85 againbor will I need to stay on E85?
My engine mods are: Perrin up pipe, Perrin down pipe, ARC cold air intake, Injen turbo back exhaust, turboxs blow off valve.
Thanks guys. And again sorry if I posted a thread already started just looking for help. :-)
subi-T is offline   Reply With Quote
Old 06-13-2013, 11:44 PM   #2
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
Originally Posted by subi-T View Post
Hey guys!
On your stock wrx turbo e-85 would be a waste of money. You will need a tune and larger injectors at the very least if your for some reason dead set on it.
Shortpersonbk is offline   Reply With Quote
Old 06-13-2013, 11:44 PM   #3
Scooby2002
Member#: 291441
2004 WRX
The thread in question is:
http://forums.nasioc.com/forums/show....php?t=1729586
A tune, bigger injectors and a fuel pump are things that are needed for E85, maybe more.
I would read the thread to help decide if its something you actually want to do.
Scooby2002 is offline   Reply With Quote
Old 06-14-2013, 12:11 AM   #4
subi-T
Member#: 348082
2006 impreza
SGM
Thanks guys.
What kind of fuel pump do u recomend.
Do u think E85 is worth it?
Old 06-14-2013, 09:53 AM   #5
Shortpersonbk
Member#: 319017
15 Prius
Thanks guys.
On the stock turbo you would probably not even see more then 10-15hp difference
Just get a wally 255 or dw200, i am using a wally 255 with 750cc injectors on e--85 and a much bigger turbo then your stocker
Old 06-14-2013, 10:02 AM   #6
encryptedballa
Member#: 122189
02 WRX Wagon
You def. want the DW300 pump. Drops right in and big enough to support future mods. I'm using it on my td04 on e-85 along with PE 800cc injectors at about a 50% IDC. I'm right around 250whp with a mildly-aggressive tune. You wont get much more than that out of a td04.
Here in IL we have e85 all over, so its really worth it for me.
encryptedballa is offline   Reply With Quote
Old 06-14-2013, 10:08 AM   #7
Shortpersonbk
Member#: 319017
15 Prius
There is no way he needs a dw300, i know multiple guys on 18gs and walbro 255 shoot mine is the size of a small 20g and i am not running into fueling issues. There is no need to waste the $50 difference and get a dw300, unless he has plans for a large 20g or 30r sized turbo in the future.
Old 06-14-2013, 10:35 AM   #8
encryptedballa
Member#: 122189
02 WRX Wagon
Just curious, what's your IDC with the setup?
OP: as for your Q regarding switching back and forth from e85 to 91: You will still need 2 maps, yes. You will need to do this anyway since its recommended you run a tank full of reg. gas for every 4-5 e85 tanks you put in. This is done to clean out the buildup that comes with e85.
I just make sure I have a conservative 93octane map ready on my laptop for when I need to switch.
Old 06-14-2013, 11:40 AM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
"worth it" is a crap question. If you don't have E85 near you, or willing to spend the money on the needed parts to benefit from it, then no it's not worth it. It also limits the travel you can do in a vehicle. In addition, you need to be Protuned just to run E-85. And you'll want to test the fuel before every fill up to insure proper Ethanol blend.
-No, you cannot just put E85 in your stock WRX.
-You will not benefit enough from it with your setup
-Are you even tuned?
Old 06-14-2013, 12:35 PM   #10
Shortpersonbk
Member#: 319017
15 Prius
just under %90 at 23psi pushing it on these injectors but pretty much got all out of this turbo that i can for now, i have a walbaro 460 e-85 compatible on my desk just saving up for some id1000s to make sure of that but i am overall unimpressed with this turbo.
Old 06-14-2013, 12:48 PM   #11
wrxlaunch
Member#: 181298
Are u smoking crack? He will see 10-15 just By switching to 93 oct and a good tune. Op check e85 thread posted above
wrxlaunch is offline   Reply With Quote
Old 06-14-2013, 12:57 PM   #12
paulpat
Member#: 237145
02 WRX
12 FXT
No one has mentioned that every time you switch gas you need to switch the tune. So after ur mods, you need to get the car to a tuner and ask for two maps one for each fuel type.
paulpat is offline   Reply With Quote
Old 06-14-2013, 01:25 PM   #13
encryptedballa
Member#: 122189
02 WRX Wagon
i believe i did...
Old 06-14-2013, 09:57 PM   #14
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Bullspit. Stop talking out your ass.
I gained about 45 HP from E85 on the stock turbo coming from 91 octane. There is plenty gain to be had on the stock turbo.
Here is what you need to go E85:
- Fuel pump (DW300 or Walbro 255)
- Fuel injectors (stock turbo I'd go at least 750cc/min to have headroom)
- a tune
- a device to switch that tune back and forth when you fuel up on a different fuel
So there are several ways to do the tuning, but I recommend talking to someone local who will be doing the tuning to find what they recommend, then do that. You'll get the best results listening to the tuner vs. showing up with something they don't recommend and them working with that.
The basic options are Accessport + carry it around to switch maps or Tactrix + laptop and carry that around to switch maps. The 02-03 ECU can be programmed with the Carberry ROM which can be wired with a physical switch to flip between maps without an external device, but this uses a different way of tuning than the stock ROM and it is highly recommended to move your air temperature sensor to the intake manifold to use that.
Also you absolutely do not need to run a tank of regular gas every 4-5 tanks of E85. My car spent over 2 years on E85 exclusively at ~12k miles a year. When I pulled my engine and swapped to the JDM version 8 engine, I moved my injectors over and they were in great shape. Deposits from E85 is rare these days. I won't go into the details, but the deposits weren't from E85, but due to issues with sharing transport and storage equipment between 91 and E85. E85 distribution is mature enough these days that there is very little dual purpose transport equipment anymore, so there are very rarely issues with those deposits.
Concillian is offline   Reply With Quote
Old 06-14-2013, 10:16 PM   #15
projectQWKSLVR
Member#: 285270
03 WRX
I think it's bullspit that I don't have e85 up here in Maine! An e85 fueled td04 setup would be a fantastic street car, even better with a 19t variant.
:-/ sadly I'm stuck on 91
projectQWKSLVR is offline   Reply With Quote
Old 06-14-2013, 11:28 PM   #16
Groundup
Member#: 294682
02 wrx
Sedona Red
Pretty hard to even find 93 in Maine!
Groundup is offline   Reply With Quote
Old 06-15-2013, 02:38 AM   #17
subi-T
Member#: 348082
2006 impreza
SGM
Yup. This is to confusing. Lmao.
Ill stick to 91 for now haha
No need to argue guys we are here to have fun
Old 06-15-2013, 06:46 PM   #18
Shortpersonbk
Member#: 319017
15 Prius
- a tune
yeah your right he should spend $300 on injectors, $100 fuelpump, $500 on a tune to gain 45whp, i missed the fact that he was moving from 91 not 93 but either way why not spend $300 and get a vf39 at least then he doesn't waste a ton of money on a protune only to be screwed and instantly maxed out
also a DW300 is not comparable to the 255 the DW200 is in both price and flow
Old 06-17-2013, 03:45 PM   #19
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I didn't state what he should or should not do, but I did not given him misleading or incorrect information like some people did. Why did he say it was confusing? Because some people gave him false information
I gave him what he would need. I gave him numbers from my own foray down the path. You gave him incorrect information and continue to mislead him by trying to compare a vf39 as if it's a comparable path... E85 is a gain across all RPMs, there is no spool penalty like a vf39.
How is being maxed out a concern? a vf39 swap that's tuned for is just as maxed out, isn't it? Anything done right should be maxed out or you overpaid. If you think you'll go bigger later, than buy bigger injectors than you think you'll need. Anything under about 1200-1250 is reasonable to tune reliably and deal with the 1.0ms low limit in the ECU.
Re-tuning also is a pretty small cost if you do it right. get a wideband so you can use an e-tuner and you can get pretty cheap custom tunes for new setups.
Old 06-17-2013, 04:23 PM   #20
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
Don't let all the arguing in this thread deter you from going e85!! Its amazing stuff and well worth the switch if its easily accessable to you. A fuel pump and larger injectors will be necessary later down the road anyway if you decide to upgrade to a larger turbo.
super_usdm is offline   Reply With Quote
Old 06-17-2013, 05:02 PM   #21
jack klompus
Member#: 152885
2014 Malibu LTZ
Go with the DW300 pump or a pump designed for e85. My Walbro 255 got loud and gave me starting trouble after running e85 in less than a year.
jack klompus is offline   Reply With Quote
Old 06-17-2013, 07:22 PM   #22
Shortpersonbk
Member#: 319017
15 Prius
This! E-85 is great
Old 06-18-2013, 06:30 PM   #23
DeatschWerks
Member#: 87358
Don't forget that ALL our pumps and injectors are ethanol compatible and come with 3-year warranties as well.
DeatschWerks is offline   Reply With Quote
Old 06-18-2013, 10:58 PM   #24
subi-T
Member#: 348082
2006 impreza
SGM
How mauch are those? Where can I find one??
Old 06-19-2013, 10:19 AM   #25
DeatschWerks
Member#: 87358
www.deatschwerks.com
If you have any questions about what would work best for your application feel free to PM me or reply in this thread.
