Old 06-14-2013, 08:31 PM   #1
majik1
Member#: 255841
2005 WTX STi
white
Default Run stage 2 93 tune on 91 + meth
Voice your opinions guys, let me know if that would make this map safe!
majik1 is offline   Reply With Quote
Old 06-14-2013, 08:54 PM   #2
rajalucy
Member#: 358957
2015 wrx
white
why not E85
rajalucy is offline   Reply With Quote
Old 06-14-2013, 10:10 PM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
You might have issues with the area of the tune before boost is high enough to have meth spraying.
I wouldn't be worried about the tune when meth is spraying, 91+meth should end up similar to 93, the problem is that boost might get into a limbo area where timing is too high for 91, but meth isn't spraying yet.
If you do this, set a pretty low boost activation pressure.
Concillian is offline   Reply With Quote
Old 06-14-2013, 11:24 PM   #4
majik1
Member#: 255841
2005 WTX STi
white
I have the aem kit with boost pressure set at the lowest(5 psi). Is it running high enough advance to cause det issues at <5 psi? And not e85 because there is one gas station her with it and I do not have the injector headroom for it...
Old 06-15-2013, 01:43 PM   #5
majik1
Member#: 255841
2005 WTX STi
white
Help me out guys, more opinions please
Old 06-15-2013, 01:46 PM   #6
savvy
Member#: 127208
2011 STI
If it were my car i would get a proper tune for 91+meth instead of trying to squeeze into a box the tune wasn't meant for.
savvy is offline   Reply With Quote
Old 06-16-2013, 12:52 AM   #7
majik1
Member#: 255841
2005 WTX STi
white
I ended up not using it, used my protune for 91 alone and ran a 13.6 1/4 at 3000 elevation. Thanks guys
Old 06-22-2013, 03:53 PM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
your fueling would be extremely rich running a ots stage2 map with meth.....
