Old 06-15-2013, 09:45 AM   #1
Jesse55
Member#: 348004
2005 WRX
Angry After fuel pump install car will not start
I just finished installing perrin fuel rails and a warboro fuel pump. When i go to start the car i hear the fuel pump turn on. I pulled the lines in the engine compartment and the one like on top is dry but the bottom has fuel and alot of pressure. I primed the car many times before trying to start. Any help is greatly appriciated.
Jesse55 is offline   Reply With Quote
Old 06-15-2013, 09:47 AM   #2
ringlander
Member#: 336100
2011 sti
any chance you have the lines on backwards?
ringlander is offline   Reply With Quote
Old 06-15-2013, 09:49 AM   #3
Jesse55
Member#: 348004
2005 WRX
I have the top line coming out of fire wall hooked up to the perrin junction block and the lower line hooked up to the fpr into junction block
Old 06-15-2013, 10:05 AM   #4
novacivic
Member#: 117980
2005 sti
wr blue
Try swapping the lines. Sounds like you have them backwards
novacivic is offline   Reply With Quote
Old 06-15-2013, 10:16 AM   #5
Jesse55
Member#: 348004
2005 WRX
I switched them now it tries to start but sputters down instantly
EDIT: i pulled maf off and the car starts but it revs up to 3k instantly.
Old 06-15-2013, 02:03 PM   #6
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
You have a boost leak.
dstroy is offline   Reply With Quote
