Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 06-15-2013, 11:49 AM   #1
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Default Relatively quick OL tuning question
Hey Guys,
Alright so i'm trying to understand why my OL tune is so rich. Well 10ish then it jumps up to 10.8ish as I reach redline. It happens when i'm going into boost, full throttle. Partial throttle its fine and closed loop is great.
My learning view seems good at 50g+. Im getting about -0.1%. Anywho I was wondering if I should fart around with the MAF scale or just lean it out in my open loop map. I feel though that the MAF scaling is good otherwise my learning view readings would be totally off?
I could edit the learning view to show more range in open loop for the MAF reading. Right now I just have 50+ range so its not very informative, maybe I have a section thats way off?
Any help would be awesome.
Oh if it matter I have a catless dp with the rear o2 still intact. I don't have any codes or anything, I just read around that it might cause the richness? Thought id put that in here.
Thanks!
OC_Nooby is offline   Reply With Quote
Old 06-15-2013, 12:48 PM   #2
dux10
Member#: 235338
2002 Faggin Wagon
srp
What other mods do you have?
The LV values are only for learned correction values based on CL correction. In other words, it has very little bearing on how well you maf scaling is beyond say 80g/s (this is roughly the limit of "d range"). It sounds like you need to scale your MAF to hit your target AFR.
Steve @ Pullz-On Tuning
dux10 is offline   Reply With Quote
Old 06-15-2013, 12:49 PM   #3
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Post your OL fueling map.
If it's a good map, just do a maf scaling.
Jubert69 is offline   Reply With Quote
Old 06-15-2013, 03:17 PM   #4
OC_Nooby
Member#: 311781
2003 WRX w STI V8
The OL MAP looks good!
I'll scale the maf, I didn't know the learning view stops at 80g/s ish.
Thanks guys!
Old 06-16-2013, 12:32 PM   #5
dux10
Member#: 235338
2002 Faggin Wagon
srp
Its not the learning view, its the ECU's "D range" learned values. Once the car is in open loop the car no longer makes corrections via AF correction or AF learning.
Thanks guys!
Old 06-16-2013, 01:19 PM   #6
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Yes it does. When you switch to OL, AFC goes to zero, but AFL is still applied. AFL D will keep being applied all the way to redline.
Old 06-16-2013, 04:33 PM   #7
dux10
Member#: 235338
2002 Faggin Wagon
srp
I've never had a car with that problem. I could've sworn D range was capped in the ECU at like 80g....
Old 06-17-2013, 09:36 PM   #8
robbyredneck
Member#: 346999
2003 wrx
blue
i was fighting this. it has you asking "why the hell am i creeping leaner"
robbyredneck is offline   Reply With Quote
Old 06-27-2013, 08:28 AM   #9
GrundleJuice
Member#: 165749
D range may end at 80 but the long term correction from D range is applied to OL. If the fueling correction was not applied then the minor differences from one engine/intake to another would not be compensated for in OL.
Old 06-27-2013, 10:29 AM   #10
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
OP is going from 10.0 @ WOT to 10.8 at redline (?). He needs to rescale his maf if his fuel table is ok. He's creeping leaner due to his fuel table or his maf scale.
Op, if your D-range is anything other than zero in your learning view, then +/- x.xx% is being applied to your WOT afr. Keep this in mind.
wgr73 is offline   Reply With Quote
Old 06-27-2013, 03:40 PM   #11
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Its +0.10 in D.
