Closed Thread
Old 06-15-2013, 02:53 PM   #1
armintheman
Member#: 316460
2008 STI
Snow White
Exclamation 08 sti AEM CAI problem?
Hey guys i searched and didnt find anything so i figured i'd start a new thread. long story short my car has the aem intake and the filter is perfectly placed so it's not touching the inner fender liner but around 100mph+ if im just going in 6th gear (around 3500rpm) and let off the gas it ripps out the passenger side fender liner!! this is the second time it's happend! all the clips were new and intacked, and i didnt hit anything in the road. (car is not lowered either) has anyone else experienced this??
my only thought is...the intake is sucking in so much air that its creating a suction effect on the fender liner and with the high speed winds the air gets into a small open spot and ripps it out? would that make sense??
armintheman is offline
Old 06-15-2013, 03:09 PM   #2
Spiffy07
Member#: 287105
2007 WRX TR
Urban Gray Metallic
im curious about this. can you post a picture?
Spiffy07 is offline
Old 06-15-2013, 05:14 PM   #3
armintheman
Member#: 316460
2008 STI
Snow White
sure a picture of what? pretty much the entire black inner fenderliner was torn out, along with the fender vent, and unclipped a couple of wires from the harness. i have an idea on fixing this issue if people think that its the suction effect...i know its not the intake filter flexing and touching the fenderliner because it's bolted down. so idk see whatelse it could be other then the amount of air the filter is trying to draw in
Old 06-15-2013, 08:50 PM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Why are you going 100+ on a street? Have you reviewed the forum rules that you agreed to? I would so.
HinshawWRX is offline
Old 06-15-2013, 10:15 PM   #5
LoveMyNewSoob
Member#: 323213
2009 WRX Sti hatch
Spark Silver
Do you have a front lip? I read a couple other places that people have had problems with lips causing fender liners to go...
LoveMyNewSoob is offline
Old 06-16-2013, 05:37 AM   #6
GrumpyPitbull
Member#: 313311
Lol ... This is a new one for me ... Never seen a CAI that eats fender liners.
GrumpyPitbull is offline
Old 06-16-2013, 07:52 AM   #7
Never Summer
Member#: 349361
2013 STi
Maybe the fender liner has been altered and going 100+ causes it to rip out of place
Never Summer is offline
Old 06-16-2013, 09:30 AM   #8
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
the intakes "sucking power" is directly linked to engine rpm and what turbo is in there. 100% throttle in 3rd gear 6500rpm in theory has the same pull through the intake as 5th gear 100% throttle at 6500rpm though you'd be going just physically faster. Your problem is someone isn't installing something right.
bluemax189 is offline
Old 06-16-2013, 10:22 AM   #9
cowboy_Rob
Member#: 194062
2003 Impreza WRX
You probably just didn't get the liner reattached completely after having it loose to install the filter. Without all the clips it won't stay put at close to double the speed limit
cowboy_Rob is offline
Old 06-16-2013, 10:28 AM   #10
2bfi
Member#: 265981
2011 STi Sedan
Try checking how the liner is installed. Pay attention to where the liner meets the lower bumper lip. The liner must be tucked behind/above the bumper lip. If it is installed below, it could catch air at high speeds.
2bfi is offline
Old 06-16-2013, 05:06 PM   #11
armintheman
Member#: 316460
2008 STI
Snow White
thanks for all the responses guys! a couple of questions i should answer first...i was going 100+ on an empty hightway doing wot data logs not street racing.
i do have a front lip actually i didnt think about that i guess it could be pushing some more air into the bottom grill/fog light bezzel and possibly pushing on the fenderliner.
the liner was not modified any and was installed by the dealer. after installation i double checked everything to make sure there were no clips missing. (all were intacked and the liner was installed correctly)
the turbo is a stock turbo around 21psi.
im thinking a solution to this is i'll install another one on there and put all the clips in again but this time i may cut a couple of vent holes into the plastic fender liner (front of wheel and back of wheel area) and apoxy a real fine mesh from the inside to let some air through it. that could fix the issue. the reason why im thinking its the intake and not the lip is because the driverside hasnt had a problem. only the passenger side (filter is on the passenger side) thanks again for all the help guys
Old 06-16-2013, 07:39 PM   #12
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Let me clarify this for you, even further. http://forums.nasioc.com/forums/misc.php?do=cfrules Read those.
Specifically:
Street racing posts of ANY kind, illegal or otherwise, must be posted in the Off-Topic forum or they will be locked or deleted without warning or notification. NASIOC does not support illegal street racing in any way, shape or form
"But I wasn't street racing, I was blatantly speeding on an empty highway."
Doesn't matter, illegal and not tolerated on this website. Review the terms that you agreed to.
Maybe the door of dicks will be at the end of the highway next time.
Closed Thread
