Old 06-15-2013, 04:36 PM   #1
Jackulous
Member#: 312637
2008 WRX hatch
Default even noisier after rebuild
hey guys. i had my trans rebuilt about 5-6 months ago. new bearings, seals, etc....it is now SO effing noisy, i always think it's going to drop or something. it whines, has that 'spinning bearing' sound. it shifts perfectly fine, and never slips or anything like that.
with the rebuild, i also put in a stage 1 ACT clutch and flywheel.
i spoke with my guy, and he says it's noisier due to the fact that the gears are not in the same grooves they were for the first 69k miles. the fact that i had to rebuild at 69k sucks in itself. (i bought car with 58k). but, can anyone confirm or deny this issue of gear groove change? i've heard that the 5-spd trans are total crap, and are subarus are just noisy in general, but man..i can take a video tomorrow if that would help.
thanks
Jackulous is offline   Reply With Quote
Old 06-23-2013, 12:26 PM   #2
Jackulous
Member#: 312637
2008 WRX hatch
really. 78 views, and no one has any ideas? come one now.
Old 06-24-2013, 01:56 AM   #3
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Are you or the shop that rebuilt it, 100% sure that the front diff backlash is right? Or if its even centered?
recce02 is offline   Reply With Quote
Old 06-27-2013, 12:17 PM   #4
Jackulous
Member#: 312637
2008 WRX hatch
i had a shop rebuild it. he said he had never done subaru 5spd before. i'm not sure about all that. the whine is getting worse though. clutch in or out, it whines REALLY bad.
Old 06-27-2013, 12:32 PM   #5
Bikelok
Member#: 254851
2002 WRX wagon 5mt
What kind of fluid did they/you use?
The wrong fluid can make a good transmission sound bad.
Still, a fresh rebuild should not be noisy.
Bikelok is offline   Reply With Quote
Old 06-27-2013, 11:56 PM   #6
Jackulous
Member#: 312637
2008 WRX hatch
Well, he used a synthetic 80w-90 (some racing ****), and then my ball joint broke, an my axle pulled out, so I topped it off with Lucas synthetic 75w-90. (Which he ok'd).
Old 07-01-2013, 11:30 AM   #7
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
can you not get the car on a lift and put it in gear to try to isolate exactly where the noise is coming from?
if from the transmission then go back to the guy and see what he will do..for you.
04stigeorge is offline   Reply With Quote
Old 07-01-2013, 10:22 PM   #8
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Your best bet for the 5 speed are a very limited choice of lubes.
Subaru's Extra-S, Uncle Scotty's Cocktail, Andrew Tech Cocktail are some of the best choices. These transmissions don't respond well to the wrong lubes.
Again, a fresh rebuild should not make odd noises, but using the right fluid is very important.
Old 07-02-2013, 02:44 AM   #9
Jackulous
Member#: 312637
2008 WRX hatch
took her back in today. she's gonna be there for a week or so. if he can't fix this problem, we are going to try and scam my warranty into writing us a check for $3500 and get an STI swap goin on.
Old 07-02-2013, 02:47 AM   #10
Jackulous
Member#: 312637
2008 WRX hatch
if it comes to that...would it be beneficial to swap with an 08+? i'd have to find a STI center console and such...but...what do yall think?
