Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 06-15-2013, 09:41 PM   #1
racingbeck22
Member#: 285603
Default greddy ebc help please
Can someone lead me in the right direction on the proper settings on my greddy ebc. I have a fully built 2.5 with a dom 2.5 polka turbo. Trying to set ebc for 24lbs with proper gain etc
racingbeck22 is offline   Reply With Quote
Old 06-15-2013, 10:00 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
How are you trying to set this?
Old 06-15-2013, 10:12 PM   #3
racingbeck22
Member#: 285603
Through the setting of the ebc. Not sure what you mean
Old 06-15-2013, 11:04 PM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
So the EBC has the ability to set? I'm asking are you doing this with a tune or some knob on the product.
Old 06-15-2013, 11:11 PM   #5
racingbeck22
Member#: 285603
I'm using the knobs on the ebc to set the boosr etc. And using open source for the ecm. Just can't get the settings right to maintain 24 lbs.
Old 06-16-2013, 10:20 AM   #6
Rally2
Member#: 132023
2005 STI
blue
Greddy has manuals online but not sure if you have the "profec" style contoller
http://www.greddy.com/tech-support/p...boost-control/
Rally2 is offline   Reply With Quote
Old 06-16-2013, 11:04 AM   #7
cowboy_Rob
Member#: 194062
2003 Impreza WRX
You have the old school profec with knobs the profec b with the digital display and buttons or something else?
Depending on your setup and altitude the settings will be different but think of it this way
Duty cycle is how much time it opens the wastegate compared to closed while maintaining boost. Stock gate your duty cycle will be high (more open) big ewg it can be set lower but can surge. So full boost 50% duty cycle it opens the gate 1second then closes 1second over and over. 75% it opens for 1.5 seconds then closed for .5
Start duty cycle is when the boost controller starts trying to control boost. On a big laggy turbo this may be 3-5 psi below your target boost on a stock fast spooling turbo this will be lower otherwise you will overshoot your target boost then come back down
And gain is your target boost setting. Pay attention depending which you have your settings could be psi, bar, or kg/cm2 like my special avcr
I'm telling you all this from memory your labels might be slightly different I had a profec b in my old dsm but it was years ago
You can also change the feel of the car drastically by playing with the wastegate duty and start duty settings to make it spool smooth and soft or hit fast and hard. I had a big ewg and a 60-1 so I set the wastegate duty at 90% (as high as it went) and the start duty a couple psi below target so it didn't even start to open the gate till it was all but at full boost then blasted it open the whole way. Made fora very fun car with a huge torque spike but wasn't the best for drivetrain reliability lol
cowboy_Rob is offline   Reply With Quote
