Old 06-16-2013, 01:26 PM   #1
swi dragon
Member#: 266357
2001 JDM WRX
blue
Hi guys
I am using my mobile and it switched before I completed the title, sorry
This could have Been asked already but I am have difficulties finding info on it, but here goes.
Is the jdm GBD ecu a direct fit( running ok and all) on the jdm Gda (ej205 wrx)
I know the Ej207 uses 535cc injectors as opposed to 440cc in the ej205. Are there any other limits or problems expected.
Why I am asking is because I have a bugeye MY01, I had some issues So I have installed spec c forged pistons in it and I plan to use a 19t billet wheel in the td04hl, porting the hot side and fitting a blanket, hence I need to upgrade the injectors, I am thinking is easier to use Sti's injectors and ecu though it may be cheaper to mod my current injectors and use open source via an email tune because I am in the Caribbean far from good tuners. Btw I have read about open source tuning but never done it
You input please
Thanks in advance
swi dragon is offline   Reply With Quote
Old 06-16-2013, 01:49 PM   #2
swi dragon
Member#: 266357
2001 JDM WRX
blue
Please edit title to say: GDB ecu in a GDA,if possible
Old 06-22-2013, 10:06 AM   #3
pmugabi
Member#: 280926
The ECU is a direct fit. I would suggest getting a wide band and learning how to open source tune. You can also find a tuner online to do an email tune as long as you have the Tactrix cable to flash the ECU.
pmugabi is offline   Reply With Quote
Old 06-22-2013, 08:29 PM   #4
swi dragon
Member#: 266357
2001 JDM WRX
blue
Thanks for the reply
I will take your advise about the open source
But I need to get a cable now and the flash block
