Old 06-16-2013, 10:33 PM   #1
Caged240
Member#: 345254
02 Wrx wagon
Default No compression
O so I compression tested my car today and it was reading no compression on 2&4 which is the drivers side. But was getting good pressure on 1&3. My buddy says if I replace my head gasket then that should fix the issue... I want some opinions on what I should do. I mean if that will work then let me know. Please any help would be greatly appreciated
Caged240 is offline   Reply With Quote
Old 06-18-2013, 07:32 AM   #2
Caged240
Member#: 345254
02 Wrx wagon
Bump no answers?
Old 06-18-2013, 07:46 AM   #3
novacivic
Member#: 117980
2005 sti
wr blue
Was it running bad before hand? Maybe you didnt get a good reading? Most likely if you really have no compression then you probably have burnt valves and need to have the head(s) rebuilt.
novacivic is offline   Reply With Quote
Old 06-18-2013, 01:55 PM   #4
StarburstAutos
Member#: 344253
03 WRX Sedan
primer black
I would check again if car was running ok. if you have no compression then you have a valve problem I would think
StarburstAutos is offline   Reply With Quote
Old 06-18-2013, 02:24 PM   #5
Caged240
Member#: 345254
02 Wrx wagon
Yea it ran fine then one day it just ran funny. So basically I should just rebuild the heads and this should cure my problem? I mean hey what ever gives me an excuse to make more power I'm game haha.
Old 06-18-2013, 05:09 PM   #6
Member#: 301037
2004 Forester XT
I would take it to a trusted shop in your area and have someone diagnose it first before you just start throwing parts at it.
art@grimmspeed is offline   Reply With Quote
Old 06-18-2013, 05:18 PM   #7
Gamble_WRX
Member#: 234783
2004 STi
Dude, these guys jump to such harsh conclusions. you have 2 cylinders with no compression on the same side. if your not over 185k miles, its the headgasket. valves do not burn out only on one side of the engine. either that, or maybe skipped a tooth on the timing belt.
Gamble_WRX is offline   Reply With Quote
Old 06-18-2013, 05:28 PM   #8
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
^ +1 for possible timing belt issue
fastnoypi is offline   Reply With Quote
Old 06-18-2013, 08:02 PM   #9
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
so your timing belt skipped a tooth..
bad tensioner..was the 100k service performed?
Old 06-18-2013, 09:29 PM   #10
StarburstAutos
Member#: 344253
03 WRX Sedan
primer black
That would be more logical. Timing issue I shouldnt have jumped to worst case
Old 06-21-2013, 07:33 AM   #11
Caged240
Member#: 345254
02 Wrx wagon
Yes service was done about 60,000 ago the motor does have a lot of miles on it. I haven't bought anything yet I'm still trying to figure out what it might be. I'm going to stick my bore scope in the head and look around to see if anything is bent or broke and also im going to look at the pistons to make sure they don't have some sorta holes or anything.
