Old 06-17-2013, 01:35 AM   #1
Murphy's Law
Member#: 243936
2011 Impreza WRX STi
Dark Blue
Default 2012 Impreza Sport Engine Noise!
First off, hello again NASIOC!
The title explains it.. the sound is coming from the rear driver side cylinder, the sound has slowly been getting worse and im really afraid that Evanston Subaru won't fix it. I like the place and people but i had this car (My mothers car) in just a few weeks ago and they changed the oil before checking out the sound so when they took the car on the highway then got off and let it idle (When it will do it the most)They said that they could not hear anything. When i got the car back, you couldn't hear the noise as much but it was still there. Now its only 600ish miles later and its VERY much back!!
I posted this video on YouTube so you guys could take a listen. In the video, you can hear the sound even when I'm just standing in front of the car!!! its almost embarrassing to drive a brand new car that sounds like this!! :/
Also, i thought i would note that the car gets hot when it sits without the ac on(The fan does not kick on nearly as much as it should when its sitting)
Please let me know what you think ASAP
Thanks, byron!
Murphy's Law is offline   Reply With Quote
Old 06-17-2013, 11:22 AM   #2
Murphy's Law
Member#: 243936
Dark Blue
*bump Any ideas?
Old 06-17-2013, 03:18 PM   #3
jbulls93
Member#: 315840
2000 2.5rs
How often does she check the oil? Has it ever been added between changes? What oil change intervals?
How do you know it gets hotter than it should when sitting? There is no temperature gauge.
Bring it to another dealer and/or contact SoA.
jbulls93 is offline   Reply With Quote
Old 06-17-2013, 09:21 PM   #4
Murphy's Law
Member#: 243936
Dark Blue
We check it quite often and it has dropped below the oil level once but we added a qt then got it changed.
The reason is because the engine bay (even on cooler days) gets so hot that when i go for the hood release, it burns. Its not very warm, its HOTT! I also have had to add coolant 2 times because it keeps emptying the reservoir. :/
Old 06-20-2013, 10:26 PM   #5
JUMBOpin
Member#: 285212
2010 Impreza OBS
2-tone silver
oh my...that doesn't sound good at all...what kind of oil are you guys using?
JUMBOpin is offline   Reply With Quote
Old 06-21-2013, 01:21 AM   #6
aod12
Member#: 282701
2008 FXT
Bring it to the dealer again make them fix it. Just keep your calm, you're still under warranty. So long as your maintenance has been kept up to date and you have no modifications keep pressing nicely until you're happy.
aod12 is offline   Reply With Quote
Old 06-23-2013, 02:00 PM   #7
Murphy's Law
Member#: 243936
Dark Blue
im using subaru 0w-20 from the dealership. ill get them to look at it again! thanks guys! -Byron
Old 06-23-2013, 06:08 PM   #8
4cyl of thunder
Member#: 316807
2011 Sti Sedan PBP
as your maintenance has been kept up to date and you have no wfxzrzmodifications keep pressing nicely until you're happy.
DMsrasrrWydezurwaswrwrtgaerawszyyydfw
4cyl of thunder is offline   Reply With Quote
Old 06-25-2013, 03:09 PM   #9
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Sounds like a water sprinkler that attaches to the hose. lol
Any updates?
Old 06-26-2013, 01:53 AM   #10
Eyedoc Orlando
Member#: 146216
2007 Impreza 2.5i SE
Newport Blue Metallic
Time to drive to another dealer and get SOA involved. That's definitely valve issues, and it needs a compression check. I'm sorry to hear you're having any issues at all with it.
Eyedoc Orlando is offline   Reply With Quote
