Old 06-17-2013, 02:20 AM   #1
storm-chaser
Member#: 354009
1998 Forester
Default Gates T42023 timing belt pulley mismatch
I ordered the Gates T42023 timing belt pulley from rockauto.com, expecting to get this (as it was pictured on the site). This is the updated part with more durable bearings:
And instead, got the old, narrow bearing obsolete part:
I guess I will call rockauto and see what they can do. I'd rather use the updated part as I'm in the middle of a head gasket change.
storm-chaser is offline   Reply With Quote
Old 06-17-2013, 12:07 PM   #2
PA-Outback2000
Member#: 161832
2000 Outback Limited
couldn't you just order the full gates set with water pump?
PA-Outback2000 is offline   Reply With Quote
Old 06-18-2013, 10:50 PM   #3
storm-chaser
Member#: 354009
1998 Forester
Well, I called rockauto and they informed me sometimes gates uses old stock with the new part number, and there is no guarantee as to what you will get. I am just going to use it and hope it runs for a while. Just frustrating. Does anyone have a source for the good wide bearing pulley?
Old 06-19-2013, 07:55 AM   #4
PA-Outback2000
Member#: 161832
did you test-fit the narrow one?
Old 06-19-2013, 01:59 PM   #5
storm-chaser
Member#: 354009
1998 Forester
Yes they both fit perfectly, its just I'd rather have the stronger wide bearing pulley on the car as it will last quite a bit longer.
