Welcome to the North American Subaru Impreza Owners Club Thursday March 26, 2015
Old 06-17-2013, 06:28 AM   #1
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
Default Subaru put too much of wrong oil in my car.
So I'm "stage 2" before first oil change, and I get them free at my dealership. So I took it in Wednesday for my first oil change and everything is all good. .. or so I thought. I get home and check the invoice and notice it says they used 0w30 (they also service jaguars). Do I call them and they assure me everything is ok and the correct oil was actually used. Then later I cranked up the car and notice it smokes for thefirst 10-20 seconds. So after I get off work, a 12.5 hour shift, I check the oil and its about 1.5 inches over the full mark.
So I call them and head up there. They call the same tech and he takes it back. It's sitting on the ground for about 10 mins. Then he raises it up and is there for about another 10 mins. He walks back and taos to the service advisor and then we go look at the car. At this point is in the air with the drain bucket under it and he lowers it down and we check the dip stick. And it's barely over the full Mark. And he's like" it's only about .5 a qt over. But ill drain and refill for you" but I get an invoice staying it was over full. I get home and look at the invoices and notice the original also says 6qts. And I see oil on to of my motor coming out of the intercooler. Take it back, then clean it off and say is fine. Now I notice 3 oil spotson my garage floor. And look under and see this:
Taking it back in 2 hrs.
CLIFFS: Subaru put 6 quarts of wrong oil in. Now I possibly have a leak.
WRB13WRX is offline   Reply With Quote
Old 06-17-2013, 07:32 AM   #2
tuzzio
Member#: 292532
05 STI
Sounds like you got hosed by the stealership
tuzzio is offline   Reply With Quote
Old 06-17-2013, 07:40 AM   #3
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
yep, getting a guy in the subaru world to look at that works there today (owns a ~05 sti)
Old 06-17-2013, 08:07 AM   #4
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
6 qts isnt going to do anything wrong. People run a full qt over when they race. Probably some extra blowby at the vents making a mess. I'd be more worried about 0-30 oil if anything.
scby rex is offline   Reply With Quote
Old 06-17-2013, 08:17 AM   #5
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
That is mainly what I'm worried about. Especially since the oil leak. At the dealership now
Old 06-17-2013, 08:52 AM   #6
scby rex
Member#: 104878
02 wrxbastardchild
I'm saying that the "leak" is probably some oil vapor from the valve cover and or ccv because the oil was a thin viscosity and over full. Nothing to worry about, just clean it up and have proof that the correct weight oil is in here.
Old 06-17-2013, 08:57 AM   #7
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
They refilled it with the Correct stuff friday morning. And now I'm about a quart low
Old 06-17-2013, 09:28 AM   #8
Dr. octagon
Member#: 171127
GDA Cyborg T4
Not waving back
Why are you not changing your own oil
Dr. octagon is offline   Reply With Quote
Old 06-17-2013, 09:37 AM   #9
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
Laziness to be honest. Usually don't let anyone touch my car. But I decided to let them do it since it's free
Old 06-17-2013, 09:41 AM   #10
rexspeedworthy
Member#: 26965
2011 WRX
DarkGray
all the time you've spent already, is the time it takes to do 100 oil changes.
rexspeedworthy is offline   Reply With Quote
Old 06-17-2013, 09:46 AM   #11
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
Not really the time I'm worried about. Free is the main thing. Obviously I regret it. So no need to say more about why I didn't change it myself
Old 06-17-2013, 08:53 PM   #12
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Sure you don't have a cracked ring land?
boosted25 is offline   Reply With Quote
Old 06-17-2013, 09:07 PM   #13
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
Diagnosis was oil seeping from head on passenger side
Old 06-17-2013, 09:21 PM   #14
kh15
Member#: 132400
sorry to hear this, I hope everything works out! Just because somethings free doesn't always mean its the best or something you should take advantage of. The fact of the matter is the only one who truly cares about your car is you, so crawl under it every few months and change the oil! After your done you can have a beer and know that the job was done right!
kh15 is offline   Reply With Quote
Old 06-18-2013, 06:03 AM   #15
dingobite
Member#: 82391
08 OBP Sti
stg2.... 279awhp, 299tq
I wouldnt let them fill up more than 5 quarts in the engine.
dingobite is offline   Reply With Quote
Old 06-18-2013, 08:53 AM   #16
redline23
Member#: 285799
2012 WRX 5-Door
I had a shop here locally change my oil due to laziness. I'm stage 2 and they put in an unknown amount of oil. It was probably over a quart full. My car started smoking petty badly on starting and the inside of my intercooler was getting coated in oil. I also popped off the intercooler to throttle body hose about 3 times since it was full of oil.
The shop I took it back to owned up immediately to the problem and drained 2 filters of oil from the engine and the oil has been at the F mark since then. No more smoking, no more oil in intercooler. There are still reputable shops out there, but I would rather change my own oil.
redline23 is offline   Reply With Quote
Old 06-19-2013, 01:07 AM   #17
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
Update. Subaru is covering it. Dropping car off in the morning and picking up my loaner.
Old 06-19-2013, 07:25 AM   #18
spins615
Member#: 353947
2013 WRX Premium
Damn, sorry to hear that. I'm also stage 2 before my first oil change..and am in need of one now, deff going to be doing it myself. Glad Subaru is covering that. Did they say anything about being stage 2?
spins615 is offline   Reply With Quote
Old 06-19-2013, 10:06 AM   #19
pumba
Member#: 308636
2008 WRX Sti
This thread only further confirms my disgust for the carelessness and quality of work found at most car dealerships. Hope it all gets fixed!
pumba is offline   Reply With Quote
Old 06-19-2013, 10:44 AM   #20
DarkProphet
Member#: 299707
2011 Wrx 5-Door
The one and only time i took my car to the dealer ship was for the free replacement windshield wipers. They couldn't even install them correctly. At least now I know not to take my car there for anything
DarkProphet is offline   Reply With Quote
Old 06-19-2013, 10:51 AM   #21
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
^ this
What did you expect from a free oil change? I wouldn't even trust them if I was paying them to do it.
Old 06-19-2013, 03:48 PM   #22
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
the 0w30 'wrong' oil was almost certainly better oil than what they put back in it
Old 06-19-2013, 06:47 PM   #23
WRB13WRX
Member#: 341786
2013 WRX Ltd. Hatch
sorry, it was 0w20, not 30.
nother update:
they had a Subar field tech manager look at it. they concluded there is no headgasket leak. and it all came from the "air duct to oil intercooler boot" which really doesnt make sense. but part number is 14459aa660. and after a quick search i see that its common for it to mess up after an over fill. which they are denying ever happened. and tried to get me to pay for it. which i finally talked them into pay for, and i put it on myself. they said it was due to me being tuned for more boost (which wont make the oil run through the intercooler system) but ive got it on the invoice with how much of what oil they put in it. incase something does go wrong.
Old 06-19-2013, 08:57 PM   #24
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
nother update:
i guess you dont know much about how these engines and systems work
if the oil was overfilled...it would be easy for the pcv system to suck oil into the intake and through the turbo and into the intercooler
and i could go on all night about why it is a REAL bad idea to 'go stage 2' before the car has 10k miles on it
but that aint k00
Old 06-20-2013, 12:00 AM   #25
Member#: 51961
2005 STi
2012 WRX
Lol, I'd love to hear that reasoning
