Old 06-17-2013, 05:42 PM   #1
lavid2002
Member#: 226864
Default Quick video, is this shaft play normal or not?
I think it's a bit much. It's almost into the housing. If I push it to a side and rotate I can hear it barely touching.
Quick vid
I paid 500 clams for this. I wanted a perfect turbo and the buyer explicitly stated there was no shaft play. What say ye?
Thanks guys
-Dave
lavid2002 is offline   Reply With Quote
Old 06-17-2013, 09:07 PM   #2
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
That's fine. If there as thrust play i'd be concerned.
mechatricity is offline   Reply With Quote
Old 06-17-2013, 09:13 PM   #3
Ballistic1350
Member#: 156877
04 sti
Well I'd call that shaft play... you paid for none and got some.
Ballistic1350 is offline   Reply With Quote
Old 06-17-2013, 11:19 PM   #4
rudymcskoody
Member#: 257618
2006 wrx
aspen white
I dont think it should have that much. Take it to your tuner and show them. That being sid this is the wrong section for this post.
rudymcskoody is offline   Reply With Quote
Old 06-17-2013, 11:49 PM   #5
lavid2002
Member#: 226864
Yeah it is in the wrong section.
I paid what I consider to be to dollar as far as used VF30s are concerned. I'm talking to the guy now.
Old 06-18-2013, 12:54 AM   #6
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I have yet to see a turbo with no shaft play. I bought a new vf48 that moved that much. Put some oil in it and see how much it moves.
Old 06-18-2013, 01:42 PM   #7
lavid2002
Member#: 226864
Out of how many turbos?
Old 06-19-2013, 06:04 PM   #8
424wrx
Member#: 171948
08 wrx vf52 swap
best et,[email protected]
seems pretty normal. be more concerned with in and out play than side to side. the oil has to pass through the journal bearing and is why theres some play there. my new vf52 i installed had a little play even.
424wrx is offline   Reply With Quote
Old 06-19-2013, 06:09 PM   #9
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
i have had 6 or 7 TD04s, none of them blown. Drained of oil, they all have maybe .5mm side to side play. You should not have any thrust (in and out) play.
Old 06-20-2013, 12:20 AM   #10
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I install a turbo every month or two. There is four turbos in the shop right now.
