Old 06-18-2013, 07:17 AM   #1
Flocka
Member#: 276450
2008 Impreza 2.5i
Default 2008 Impreza 2.5i CEL due to resonator removal?
This morning my CEL, VDC and a flashing cruise light came on. The only reason I can imagine would be because I removed my intake snorkus/resonator about 1500 miles ago. Im going to get the code scanned at lunch, should I expect to see something about a rich fuel mix or a bad MAF? I would just re-install the resonator but its 200 miles away at my other house. Would It be a bad idea to drive it 200 miles to get the resonator?
Flocka is offline   Reply With Quote
Old 06-18-2013, 07:31 AM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Won't be able to help without the code.
Old 06-18-2013, 08:35 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
^^^ Indeed. Seems a bit of a stretch to think it's related to something you did 1500 miles ago.
Old 06-18-2013, 05:07 PM   #4
Flocka
Member#: 276450
2008 Impreza 2.5i
The code was a P0442 - evaporative emission system leak detected. I cleared the code and on the drive home I was bogging on starts and had to release the clutch at a higher rpm to get rolling. When coming to a stop the rpms dip to the lowest notch on the tach and almost stall. The vdc light flashed on for a fraction of a second once like it was stalling. Im guessing I'm running rich, which people against the resonator mod said would happen, Ive just never had these issues until now, after I cleared the code.
Old 06-19-2013, 09:12 AM   #5
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
vacuum leaks, a bad knock sensor, or old plugs will all make it act like this. I like to start with the cheapest thing first. Make sure you didn't unhook anything from the intake when you took off the resonator.
Rudgers73 is offline   Reply With Quote
Old 06-19-2013, 09:53 AM   #6
Flocka
Member#: 276450
2008 Impreza 2.5i
I checked all the vacuum line connections last night and made sure they were snug, didnt find any leaks but i must have eliminated whatever the leak was because the issue seems to be solved. The car drove fine this morning and didnt throw any more codes. Thanks for the help.
