Old 06-18-2013, 03:55 PM   #1
Gamble_WRX
Member#: 234783
2004 STi
Default Anyone running V7 pistons in an EJ205?
So im toying with the idea of putting the V7 pistons in my Ej205, and was wondering whos already done it. i dont know if i can get away with honing the block without splitting it. i really dont wanna go through the trouble of doing main bearings. the car is not my DD, however it may be for the winter, and i already blew ringlands on my last wrx and dont wanna go through that again.
just looking for information wondering if i cant get away with using a blade hone or something to keep away from the rod, and just take out factory piston, do a few passes with a hone and reinstall v7 pistons.
thanks for any help!
Gamble_WRX is offline   Reply With Quote
Old 06-18-2013, 04:22 PM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
it would be a cleaner job if you split the block then hone and hot tank.
The dirty way..you could remove your rod caps, pull the rods out and stuff a rag in each cylinder to catch the crap left from the hone.
how much power are you planning and are you keeping the 205 rods?
fastnoypi is offline   Reply With Quote
Old 06-18-2013, 04:29 PM   #3
Gamble_WRX
Member#: 234783
2004 STi
I was planning a 20G at 25psi. should put me around 400 whp. i know the factory rods will be fine. i just dont want to go through the hassle of gauging and changing the bearings is all. its a PITA, and your chances of spinning a bearing go up by like 600%. im only running the engine for a year, if i cant get away with honeing it with the shortblock still together, ill either just drop in the V7s, and score the hell outta the cylinder walls, or leave the cast junk, and tune it retarded rich.
i used to be all into this stuff, but im putting it together on a budget, which we all know is never a good start.
Reliabilty isnt a big deal for me right now. im gonna be pushing close to 400 whp and babying the stock trans.
Old 06-18-2013, 08:12 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I wouldn't be so confident the 205 rods would be fine. I just tuned a JDM swap that swapped because a rod poked a hole in the original 205 block... I think 25 psi on EJ205 rods would indeed be a Gamble_WRX.
Concillian is offline   Reply With Quote
Old 06-18-2013, 08:52 PM   #5
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
I've been running around 26psi on a stock LB ej205 for the last 7 months and it's my DD. Putting out 375whp on e85 (full time). So far so good. No issues.
Fierysun is offline   Reply With Quote
Old 06-18-2013, 09:20 PM   #6
Gamble_WRX
Member#: 234783
2004 STi
its all in the tune. you need to detonate to break a rod like that. GeneralTJI ran like 470 through a Holset on a stock bottom end. it failed eventually, but i think he rode on the stock block for almost 2 years like that.
Old 06-18-2013, 09:31 PM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Well, you need to detonate to break a ringland on a 2.0L too... and you did that.
Old 06-19-2013, 02:52 AM   #8
Gamble_WRX
Member#: 234783
2004 STi
I sure did, my injector failed. Nothing to do with my tune, although that was my first assumtion as well.
