Old 06-18-2013, 10:06 PM   #1
speedypollard
Member#: 286555
2007 WRX
Obsidian Black Pearl
Default Does replacement ecu need flashed?
Working on an '03 WRX in which the ecu isn't sending any voltage/signal to the knock sensor so I bought a good used replacement today. I'm curious if it will need to be flashed in order to work or if its just going to be a plug it in and go type thing.
speedypollard is offline   Reply With Quote
Old 06-18-2013, 10:10 PM   #2
04sedantyson
Member#: 233011
2004 04 sedan
should be plug and play unless your old one has a program in it
04sedantyson is offline   Reply With Quote
Old 06-18-2013, 10:22 PM   #3
speedypollard
Member#: 286555
2007 WRX
The bad ecu that's currently in the car has been tuned via opensource
Old 06-18-2013, 10:48 PM   #4
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Yes replacement ecu needs to be flashed with a copy of the tune from bad ecu.
wrxlaunch is offline   Reply With Quote
Old 06-18-2013, 11:20 PM   #5
speedypollard
Member#: 286555
2007 WRX
Yeah I was planning on getting the car retuned because its far from stock but was just curious if it was necessary in order to start up and run or if Subaru needed to flash it to match the new vin # or anything
Old 06-19-2013, 10:15 AM   #6
quazimoto
Member#: 70395
Kinda depends on the mods (which you didn't list). If you have bigger injectors/turbo than stock or a bigger aftermarket intake then there is going to be an issue.
quazimoto is offline   Reply With Quote
Old 06-19-2013, 11:16 AM   #7
StarburstAutos
Member#: 344253
03 WRX Sedan
primer black
ecu should send proper signal to start car but will prob run like crap if you have a tune on old ecu. But it should start
StarburstAutos is offline   Reply With Quote
Old 06-19-2013, 01:01 PM   #8
speedypollard
Member#: 286555
2007 WRX
Mods that may effect tune:
Injen cai
Walbro 255
STI pink injectors
Perrin fuel rails
Perrin fuel regulator
FP green turbo
MRT tmic
Nameless turboback exhaust
It's probably going to run like crap until its retuned but the point I want to confirm is it doesn't need to be flashed because my local Subaru dealer told me a used ecu needs to be flashed and if it doesn't then that'll save me $65
Old 06-19-2013, 01:44 PM   #9
quazimoto
Member#: 70395
Stock injectors are 420cc. STI injectors are 565cc (not to mention the CAI and the turbo). It will do more than just run like crap. Fuel will be flooding your cylinder walls. It's called "bore wash". All that fuel will be washing away the lubricating oil. Just buy a premade email tune.
Old 06-19-2013, 04:59 PM   #10
speedypollard
Member#: 286555
2007 WRX
Or swap the ecu in my tuner's driveway...
