Old 06-19-2013, 09:37 AM   #1
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
Default Clutch Line Lubrication
Hey guys i searched for this issue but couldn't find an answer. Seems to me like a simple solution but i wanna run it by you guys.
So I hear a squeak every time i step on the clutch pedal. The noise is coming from the front of the car not the pedal so i assume its the clutch line thats under neath the tmic.
is it a simple i get grease and take of the tmic to lubricate it?
at idle i dont hear any squeaking its just when im pressing on and off the clutch pedal and im certain its not the pedal.
Also what kind of lubrication should i use?
thanks in advance for any help! all is appreciated!
pointblink19 is offline   Reply With Quote
Old 06-19-2013, 10:06 AM   #2
quazimoto
Member#: 70395
The clutch line is hydrolic just like your brake lines. There is no lubrication needed. The sqeaking could be the release fork or throw out bearing. The fork requires grease per the service manual. Try searching in the transmission/drivetrain subforum for solutions.
quazimoto is offline   Reply With Quote
Old 06-19-2013, 12:39 PM   #3
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
is there a diy on that?
Old 06-19-2013, 12:49 PM   #4
ShadowIMg
Member#: 31519
2012 Torque Egg
2001 2.5RS Coupe
ShadowIMg is offline   Reply With Quote
Old 06-19-2013, 06:26 PM   #5
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
I believe there is a silent recall on this.. The fire wall was made too thin/weak in the MC location and it flexes under the hydraulic loading from the clutch pedal/MC.
A brace similar to the ones for the brake MC will work or reinforcing the fire wall welding in plate 4x4-5x5 that the MC bolts through will stop the flexing.
dangerousatom is offline   Reply With Quote
Old 06-19-2013, 10:09 PM   #6
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
i lubricated the parts indicated, still the squeak :/
Old 07-03-2013, 12:45 PM   #7
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
any ideas? should i replace the line?
Old 07-03-2013, 06:39 PM   #8
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Its a simple hydraulic hose. There is nothing to squeak in the line.
Old 07-03-2013, 06:58 PM   #9
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
Put more grease!
pho_shizzle is offline   Reply With Quote
Old 07-03-2013, 07:24 PM   #10
dangerousatom
Member#: 70710
again
Old 07-14-2013, 07:07 PM   #11
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
sorry didnt catch that one ^^^
does anyone know if there is a company that makes a brace?
Old 07-14-2013, 07:10 PM   #12
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Thats for the new chassis. I have not seen anything about this for the GD
