Old 06-20-2013, 01:49 AM   #1
ksingh2463
Member#: 247537
02 MBP WRX
Default 2003 Idle/Drivability Problem
I recently swapped out the engine in my 2003 WRX (over 200K mi) with a high mileage replacement unit in good condition. It started up just fine the first time with no issues or CELs.
After a brief test drive, I fired the engine back up and it began to idle high. P0519 CEL (Idle Control System ***********Malfunction: Engine keeps running at higher revolution than specified idling revolution) popped up on the dash. At idle, the engine speed would occasionally oscillate between 1250 and 2000RPM and sometimes drop very low and run rough.
I then decided to take it out for another test drive to see if the problem would go away. Right away, I could feel that driveability had gone to complete ****, especially after engaging the clutch and giving it some gas in first gear. Going from partial throttle to off throttle in gear also doesn't feel as it should.
After doing some digging and research on the problem, I decided to clean out the IACV (this is the same IACV that was on the previous engine and never caused an idling problem). Didn't help any so I replaced it with another one. That also didn't solve anything. I then checked the throttle cables for excessive tension and they had plenty of slack. After doing all this, I tried swapping out the Neutral Safety Switch. I tried two switches from two different perfectly running cars and none helped solve the problem. I've also reset the ECU many times and that didn't help either.
Has anyone had a similar problem? If so, can you tell me what I'm doing wrong because I feel like I've tried just about everything. I've added a video below of how the car idles. Notice how the engine speed rises upon starting and then falls. In the video it stays around 1500 RPM but occasionally it will begin to oscillate.
Any insight or help would be extremely appreciated. Thanks in advance!
ksingh2463 is offline   Reply With Quote
Old 06-20-2013, 03:52 PM   #2
ToddMcF2002
Member#: 135007
2014 STi Hatch
Crystal Black Silica
Did you change the IACV gasket? I would think a vacuum leak there of any size would create havok. Maybe try cleaning your MAF or swap one out as a test. BTW when you resolve this *please* post the solution!
ToddMcF2002 is offline   Reply With Quote
Old 06-20-2013, 04:31 PM   #3
GulfCoastMotorworks
Member#: 358317
6266 Built Bugeye
GulfCoastMotorWorks.com
We had a car recently go through 3 used IACVs until one was operational......it happens.
GulfCoastMotorworks is offline   Reply With Quote
Old 06-20-2013, 05:10 PM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
did the rpm oscillation go away once you came up to operating temp?
If you didn't wait, the IACV is doing what it is supposed to.
Also double check your IACV gasket install to make sure it didnt get pinched. A pinched gasket can also cause rough idle.
fastnoypi is offline   Reply With Quote
Old 06-20-2013, 07:20 PM   #5
Blktrax
Member#: 220971
2002 WRX 213K Mi.
Original Motor and Turbo
unplug the maf, start engine,
if it idles smooth-er, maf is toast.
IACV is a response to a closed throttle condition, to manage what the maf sees.
also try disconnecting your throttle cables, if either the pedal or cruise cable is too tight, it wont allow the throttle to close completely, causing the same code.
These of course assume no vacuum leaks.
Blktrax is offline   Reply With Quote
Old 06-21-2013, 09:42 AM   #6
ksingh2463
Member#: 247537
02 MBP WRX
I made sure that the IACV gasket was installed correctly and I'm pretty confident that the IACV isn't the problem. Throttle cables have been loosened and it didn't make a difference. The MAF is the same one that came off the perfectly running engine and I believe it to be in good condition.
I believe I have an intake/vacuum leak somewhere. Before dropping the new motor into the car, I did swap out the throttle body but didn't change the gasket since it looked good. Could not changing the gasket cause a leak? Also will an intake leak on the turbo outlet hose cause an idling problem?
Old 06-21-2013, 10:57 AM   #7
StarburstAutos
Member#: 344253
03 WRX Sedan
primer black
thinking vacuum leak check the tb gasket that you didn't change. good start there then you can do the spray trick to see if there is a leak just use a can of carb cleaner or brake cleaner if you don't have carb cleaner and when you hit the spot with the leak the idle will change hard. this will at least get you in the right area for a vacuum leak.
StarburstAutos is offline   Reply With Quote
Old 07-02-2013, 03:49 AM   #8
ksingh2463
Member#: 247537
02 MBP WRX
Problem solved. No vacuum/intake leaks were found. Replaced the IACV for the third time and the issue was resolved. Just my bad luck with these things. Both of the ones I used previously were bad.
Thanks for the help guys!
