Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 09-29-2002, 06:48 PM   #1
V8ETR
Member#: 24306
Default High elevation=low vaccum?
What is you vaccum on a stock, or close to stock (turboxs) wrx 2.0L turbo in or around Denver Colorado? I would think it would be the same everywhere, but Just wanting to see if what i have is normal...Im around -0.05Mpa +or- .01Mpa on the stock gauge, a little less on warm up..
V8ETR is offline   Reply With Quote
Old 09-29-2002, 07:32 PM   #2
davidm_sh
Member#: 5994
2004 Impreza WRX STi
Java Black
I can't think of the conversion right now but depending on the day here in the Springs (~6000ft above sea level) I see about 12-14inches of vacuum and/or 32-38kPa as per my MAP sensor in the intake manifold at warm idle.
davidm_sh is offline   Reply With Quote
Old 09-29-2002, 08:35 PM   #3
V8ETR
Member#: 24306
Thanks....thats about what i get in inches also..i live in fort collins right now so its pretty close...i think the conversion is about -.05Mpa
Old 09-30-2002, 01:54 AM   #4
Weedy
Member#: 12340
2002 WRX 2.5L Hybrid
It's amazing what a few thousand feet of elevation will do to a car. I vaccum at 18in here at idle. Of course when I'm up there I get the same readings as you guys. The difference in how long it take for your turbo to spool at higher elev. is pretty depressing also. Anyways... Talk to ya later!
Weedy is offline   Reply With Quote
Old 09-30-2002, 11:11 AM   #5
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I was driving over a local pass this weekend, at perhaps 6000 feet, on probably a 6-7 grade, and i was in 5th all the way up. Boost was extremely high for such a grade, what could only be due to the higher elevation.
Back down in the valley, at ~4300, on a similar grade, the car barely gets into positive boost.
Dave
DLC is offline   Reply With Quote
Old 09-30-2002, 08:50 PM   #6
Ski Man
Member#: 5334
WR Blue
Question
Boost and vacuum on your guage are relative to local atmosphere no matter if you're at sea level or 12,000 feet. The fact that you have more elevated boost at elevation has to do with engine load and degrading engine and turbo performance at low pressure.
Two different issues. Also remember that out ECU does do some adjustments for altitude, including lowering the boost cut to try and keep in the turbos effeciency range.
Hope that helps.
Ski Man is offline   Reply With Quote
Low Compression/High Boost vs High Compression/Low Boost? JoeTX Newbies & FAQs 31 05-18-2006 04:06 PM
high elevation utec'ers MAD REX Rocky Mountains Impreza Club Forum -- RMIC 4 04-15-2003 11:23 PM
What to do? High Compression, Low Boost or Low Compression, High Boost. FlooredSubaru Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-29-2003 10:55 AM
High Elevation=vaccum lower? V8ETR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-30-2002 06:46 PM
Fuzzy logic boost controller at high elevation? WRXThis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-14-2001 08:08 PM
