Old 06-22-2013, 12:12 PM   #1
scoobydiver00917
Member#: 358259
Default Cable to drive by wire, or vice versa
well i had a 2002 wrx with a built 2.0L engine, its now wrecked. I also have a 2004 sti shell with a full harness. so my question is, how do i get the wrx engine to work int the STI? since one is cable and one is drive by wire. what do i need to change and should i stick with cable or wire? i just need some options, thanks
scoobydiver00917 is offline   Reply With Quote
Old 06-24-2013, 09:53 PM   #2
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
you need a dbw throttle body, ideally the sti maifold also and it would bolt right on the wrx motor.
slowgenius is offline   Reply With Quote
Old 06-29-2013, 08:59 AM   #3
scoobydiver00917
Member#: 358259
any idea about the wiring?
Old 07-01-2013, 09:23 PM   #4
25rsti
Member#: 166324
I just swapped my bugeye wiring into my 04 STi shell. I drilled out the spot welds on both chassis' gas pedal brackets and then welded the bugeye gas pedal bracket into the 04 STi shell. Then I had to drill a hole into the firewall for the cable to pass through.
Old 07-12-2013, 09:24 AM   #5
scoobydiver00917
Member#: 358259
You swapped the dash harness and ecu? So literally take everything from the bug eye and put in the sti. The gauge cluster , ecu, everything. Is what your saying
