Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 07-01-2013, 12:26 PM   #26
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
It will still show a value, but it takes a long time before that value gets to where it needs to be.
Old 07-02-2013, 11:20 AM   #27
WRXmeinMD
Member#: 354904
03 Wrx
MBP
Ohh its showing some values now this was after my 3rd gear pull to 6200 where it abruptly blew off by itself. I'll post the LV and log after work.
WRXmeinMD is offline   Reply With Quote
Old 07-02-2013, 01:09 PM   #28
JonnyV2889
Member#: 197384
2006 WRX Ltd
Get rid of that f'n bov.
JonnyV2889 is offline   Reply With Quote
Old 07-02-2013, 05:25 PM   #29
WRXmeinMD
Member#: 354904
03 Wrx
MBP
But but but its a synapse lol. The PO loosened the damn set screw in the back and also only hooked up 1 vac line. It would only hold 12-15 psi before I tightened it. I'm going to try to tighten it some more and a second vac line then If that's not it its gone.
I fixed the problem I was having with it actually coming off of the pipe.
Old 07-07-2013, 05:52 PM   #30
Andrewxxcarlson
Member#: 316415
2006 WRX
Originally Posted by WRXmeinMD View Post
This was from today after a reset, the previous one was after my BOV popped off of the pipe and I had to drive it 100ft to the parking lot of a pepboys...
You still have a leak, and you can't be sure your tuned to 22psi.
Boost leak tester. Or do the front o2. Or both. Depending on the year and mileage of your car it would be a good idea to replace the original o2.
Andrewxxcarlson is offline   Reply With Quote
Old 07-07-2013, 06:23 PM   #31
WRXmeinMD
Member#: 354904
03 Wrx
MBP
Im replacing the front O2 in a few minutes. Ill boost leak after that...
Old 07-07-2013, 06:37 PM   #32
WRXmeinMD
Member#: 354904
03 Wrx
MBP
Im not sure its a factory o2 seeing as the clip that's supposed to hold the plug in place is broke and was zip tied. Regardless im replacing the o2 for peace of mind. I also took off the intake as well as the silicone intake tube to check for possible leaks only to find that the PO installed the barb fittings with Teflon tape! WTF!
Im in the process of installing them back in with hose clamps then ill put everything back in as well as the o2 and get back with a LV tomorrow. Should be back to normal, well.... as normal as can be without a complete tune. (Working with Dux10)
Old 07-08-2013, 11:15 AM   #33
WRXmeinMD
Member#: 354904
03 Wrx
MBP
Nope, same damn thing. Starter signal low, O2 voltage high, o2 voltage low, two random no name codes and system lean. Going to check my grounds. Could the one on the trans be responsible for the speedo, starter, and o2 codes?
Boost leak testing today then intake manifold testing then cleaning MAF followed by ground cleaning/checking.
Hopefully followed by success.
Old 07-08-2013, 11:51 AM   #34
Andrewxxcarlson
Member#: 316415
2006 WRX
O2 sensor! Go do it nowwww.
Old 07-08-2013, 11:54 AM   #35
WRXmeinMD
Member#: 354904
03 Wrx
MBP
I DID and ITS STILL THE SAME!
Old 07-08-2013, 12:16 PM   #36
Andrewxxcarlson
Member#: 316415
2006 WRX
Mehhhhh, wtf I need reading lessons, you reset ecu?
Old 07-08-2013, 01:48 PM   #37
sidewayz
Member#: 5810
2001 S366 2.5RS
Replace with oem sensor?
sidewayz is offline   Reply With Quote
Old 07-08-2013, 02:56 PM   #38
WRXmeinMD
Member#: 354904
03 Wrx
MBP
Yep reset ecu and its a direct replacement sensor. Bad grounds?
Old 07-08-2013, 04:17 PM   #39
Andrewxxcarlson
Member#: 316415
2006 WRX
Get romraider then log, I hate learning view
Old 07-08-2013, 04:22 PM   #40
WRXmeinMD
Member#: 354904
03 Wrx
MBP
What do you need to see? I have a MAF scaling log.
Old 07-08-2013, 05:34 PM   #41
Andrewxxcarlson
Member#: 316415
2006 WRX
I just am not the most familiar with learning view. Have ya done your leak test yet?
Old 07-08-2013, 05:43 PM   #42
Member#: 51961
2005 STi
2012 WRX
Nothing wrong with learning view when it's used for the right job (checking to make sure a car is running correctly). It was never intended to be used for active tuning or rapid debugging since it takes WAY too long for the cells to fill up with their final values.
Old 07-08-2013, 09:14 PM   #43
WRXmeinMD
Member#: 354904
03 Wrx
MBP
Leak test done! Found a leaking pass rear injector seal! Got that fixed and retested and found my front right is slightly leaking too! Store only had 1 kit so guess tomorrow is another day.... feels a lil bit better though!
Old 07-09-2013, 01:28 AM   #44
Andrewxxcarlson
Member#: 316415
2006 WRX
That's what I'm talkin about! Gettin **** done!
Old 07-09-2013, 07:53 AM   #45
WRXmeinMD
Member#: 354904
03 Wrx
MBP
Yeah it was pretty easy (love subies) to get out. Pinks and stock injector seals are the same correct?
Old 07-09-2013, 10:02 AM   #46
Andrewxxcarlson
Member#: 316415
2006 WRX
I'd assume the seals are the same, different between top and side feed tho?
Old 07-09-2013, 12:11 PM   #47
WRXmeinMD
Member#: 354904
03 Wrx
MBP
I used a 03 wrx seal and didn't get any leakage soooo.?
Old 07-09-2013, 07:54 PM   #48
dux10
Member#: 235338
2002 Faggin Wagon
srp
all top feed injectors use the same seals.
Steve @ Pullz-On Tuning
dux10 is offline   Reply With Quote
Old 07-10-2013, 07:37 PM   #49
WRXmeinMD
Member#: 354904
03 Wrx
MBP
Thanks Steve, and thanks for all of your help so far! Truly making this whole E-tuning process simple.
AGAIN WELL WORTH THE $ YOU CHARGE!
