Old 06-24-2013, 05:48 PM   #1
bradze
Member#: 103208
2011 Outback
Azurite Blue
Default anyone taken a newish impreza autoxing or rallyxing yet?
my outback feels like a school bus, i'm begging my wife to let me use her '12impreza for rallycross but she says no because shes afraid of scratches. im just curious if anyone has any impressions they could share? it seems much peppier than my car and it does handle so much better. im just contemplating what I could do with it cuz once she hits 100k miles she thinks she needs a new car. she just hit 23k and its not even a year old yet...
bradze is offline   Reply With Quote
Old 06-25-2013, 08:31 AM   #2
AJB001
Member#: 338330
AJB001 is offline   Reply With Quote
Old 06-25-2013, 09:57 AM   #3
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
From youtube page:
James Wilson drives the 2012 Subaru Impreza 2.0i (FB20 engine, CVT transmission) to a 2nd Place finish in H-Stock. Stock 15" wheels and OEM tires, 19mm STI rear sway bar. My fastest lap was 0.3 sec faster, but the video was not as fun Great little commuter car, great AWD, good CVT transmission, and upwards of 36mpg.
Base model with cvt, stock rubber, with upgraded rsb. That's pretty crazy. Apparently finished 2nd. That's pretty cool.
Old 06-25-2013, 09:20 PM   #4
8crizzle8
Member#: 350064
2013 Impreza Sport
MBP
Originally Posted by myrt1987 View Post
From youtube page:
Wow that's surprising. I'd like to compare the handling of one with a 19mm rsb vs my 16mm stock before actually buying it.
8crizzle8 is offline   Reply With Quote
Old 06-26-2013, 10:11 AM   #5
79letour
Member#: 302570
2013 XV
DGM!
I believe he got rid of the car after the airbags failed. And iirc he couldnt get the rear end aligned properly.
79letour is offline   Reply With Quote
Old 06-26-2013, 01:34 PM   #6
cdlong
Member#: 147834
2013 Impreza Sport
1995 240sx
There were probably only 2 cars in H-Stock
I will probably run my car ('13 Impreza Sport 5 speed) over the winter when the DSP car is down for upgrades. Probably STF since the PAX is better than HS. I'm curious about the VDC, I haven't read enough on it yet, but supposedly it doesn't turn completely off? Has the minimal intervention caused any problems during a run? What happens when it does intervene, does it go back to full strength?
Any thoughts on the "launch"? My car is pretty slow off the line and has little pickup below 3k rpm (the altitude doesn't help). I'm worried it will be slow as a dog from the get-go. Has anyone dyno'd a '12+ or tried any launch techniques?
I certainly won't be serious about autoXing this car (not that I am about the 240sx either) but may do some upgrades over time. It's my DD commuter car so absolutely nothing that harms mileage and only a little hit to ride quality. RSB, shifter bushings, springs, shocks eventually, and maybe a CAI. Anything else worth considering?
cdlong is offline   Reply With Quote
Old 07-03-2013, 10:32 AM   #7
79letour
Member#: 302570
2013 XV
DGM!
James Wilson sure can drive!
Old 07-03-2013, 11:17 AM   #8
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
You can actually turn off the VSC completely. Someone on a crosstrek forum recently discovered how to do it, search the last few pages of the stability control thread in the Impreza forum and you will find it. It's as simple as pulling the lowest most 7.5 fuse on the right side of the fusebox (read the thread first before trying this to make sure I didn't explain that wrong). Completely disables stability control, traction control, throttle cutoff and ABS without affecting anything else.
Dirt Bringer is offline   Reply With Quote
Old 07-03-2013, 11:38 AM   #9
cdlong
Member#: 147834
2013 Impreza Sport
1995 240sx
I read the thread and it's all over the place. So many "you can do it this way" "No you can't, it doesn't work on my car" with little mention of what car, trans, etc. It's hard to know what's true. It'd be nice to have a comprehensive, accurate write up. I will have to experiment myself, maybe just the button will do it. ABS would be nice to keep though. I'm curious what James did in the video above.
Old 07-03-2013, 11:56 AM   #10
79letour
Member#: 302570
2013 XV
DGM!
I think pulling that fuse also puts it into "limp" mode. 4500rpm cutoff etc.
Old 07-03-2013, 01:07 PM   #11
cdlong
Member#: 147834
2013 Impreza Sport
1995 240sx
A different fuse does that I think.
Old 07-03-2013, 04:59 PM   #12
Dirt Bringer
Member#: 340297
Ice Silver
That's another fuse. This is a very recent development, and it doesn't disable the engine function at all. I really don't think that you would need abs for autox or snow conditions either. This works on all 2012+ Impreza and Crosstrek models from what I've been made to understand.
Old 07-03-2013, 05:05 PM   #13
79letour
Member#: 302570
2013 XV
DGM!
That would be AWESOME!!!!!
Old 07-03-2013, 05:53 PM   #14
Rememo
Member#: 340728
2013 Impreza 5-spd
Kudos to anyone auto-crossing the '12+ Impreza. With the seats lacking any real support, I'd be sliding all over the interior. Hell... I slide around the seat just doing some aggressive cornering during my daily drive. :-)
Rememo is offline   Reply With Quote
Old 07-04-2013, 07:55 AM   #15
bradze
Member#: 103208
2011 Outback
Azurite Blue
now I love the impreza so much more. im in pa right now driving my mom's Suzuki sx4 which has 5 less hp but weighs about 300lbs. less and it feels like a dump truck loaded with huge boulders in comparison to my impreza. and ya I call the seats slip n' slide in the impreza.
Old 07-05-2013, 05:22 PM   #16
cdlong
Member#: 147834
2013 Impreza Sport
1995 240sx
Need? not really. Want? Sure. It won't make you slower, and it could save you from flat spotting your tires or losing time due to locking up the tires and understeering off line.
Are you saying you'd rather drive around on public streets without ABS, or rather slide around a snow covered parking lot without ABS?
Old 07-08-2013, 10:30 AM   #17
Dirt Bringer
Member#: 340297
Ice Silver
If I was on a dirt road with relatively little traffic, or was dealing with a lot of snow, then yes (as ABS actually makes the car stop slower on snow). On public mainroads however I would never disable these safety features. I see no purpose or benefit in doing so, only increased risk.
